Question about Sylvania 6720FDF
Tv turns on for about 5 seconds and turns back off.
TV turns itself off??
Take a second look in the power supply where the power cord goes for bad caps----a few examples:
Good one on the left and puffed up one on the right
Extreme example of ones the arrows point to and notice all the perfectly flat tops on others
May 28, 2012 | Televison & Video
When you turn the tv on it go right back off Mitsubishi WS-55511 55 in. It about (5)yrs old I have try unplugging the tv for about 3 to 5 minute
Do this: When you turn it on and the green power light comes on and goes off:
On the front of the set press and hold BOTH the Menu and Input buttons at the same time for at least 5 seconds and then release both.
This model has a self check: The green power light will then blink a two digit error code: most common is 2 blinks, 2 blinks and a pause and repeat the error code at least 5 times.
Let me know what you find and I will tell you what it means.
I hope you get 2,2 as it is the most easy to resolve.
If this told you something you did not know rate this solution as very helpful as I do this here for free.
REGARDS, SD TECH
Aug 12, 2010 | Mitsubishi WS-55511 55" Rear Projection...
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=rca&dv=universalremote&md=rcr4258rcr4358&kw=RCR-4258&st=&ar=&dt=&so=&pg=1&file=others/rca/rcr4358-manual.zip
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Cheers!
Apr 27, 2010 | RCA RCR-4258 Remote Control
When I power up, 5 seconds later this back projector TV turns itself off
t does sound like a bulb problem, either its over heating and shutting off to protect itself, or its already shot. Give a TV repair shop a call and see if they can give you an approximate price, then decide to ditch or repair it.
May 30, 2009 | Televison & Video
TV doesn't turn on
I bought a LG 39" flat screen 6 months ago. TV has been working great until this morning. Power comes on for about 5 seconds and then cuts off. Have checked all connections and have unplugged from wall to reset, NOTHING!! And a brand new TV!! Any help would be great!
Aug 10, 2007 | LG RU-52SZ51D 52" Rear Projection...
T.V WILL NOT STAY ON: JVC AV-27F702 27" TV
This sounds like a protection system cutting in. This happens if there is a major fault and continual use would lead to a fire risk.
Aug 09, 2007 | JVC AV-27F702 27" TV
Screen tuns black after 15 seconds and comes back after about 15 minuts
The solder joints on the vertical output IC have cracked. This is a very common problem on those sets.
Nov 14, 2006 | Panasonic CT-27G34 27" TV
TV has green sceen and turns off by itself
you have the famous zenith shorted picture tube
Aug 07, 2006 | Zenith C27V22 27" TV
Sylvania 6720FDF Logo
20 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
