Question about GE Spacemaker JVM1640SJ Microwave Oven
Power is on and all seems to be functioning except just today it does not seems to generate any heat. Any item placed in the microwave remains cold.
  • GE Master
  • 6,771 Answers
The most likely problem is the magnetron, also the high voltage capacitor and diode can be a factor. If the magnetron proves to be the issue you are further ahead replacing the microwave oven.
Posted on Mar 13, 2011
  • michaelri472 May 04, 2011
    magnetron was warranty so i replced it but still no heat?
Troubleshooting
Repack it in the box and return it to the place of purchase for replacement
Oct 03, 2013 | Avanti MO902SST 1000 Watts Microwave Oven
Only microwave not working
Chances are you have a bad secondary / cook relay on the control circuit board. The relay can be replaced. See details here.
Jul 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Microwave not working (generating heat)
Please check the door switch for proper operation.
May 19, 2010 | Frigidaire PLMV168 Microwave Oven
Microwave works except not heating food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
The microwave Generator does not want to work.
By generator, I think you mean, the magnetron that heats the food, correct? Either the magnetron has fried or some part of the circuitry to it has fried. If the magnetron has fried, then you are better off getting a new microwave as the magnetron costs almost as much as a new one. Working on a microwave can be dangerous, so if you want to see if something else is fried, find someone with electronic expertise to test the components to the magnetron.
Let me know how this works out for you.
Benjamin
Apr 25, 2010 | Sharp R-1405 / R-140 Microwave Oven
Microwave seems to operate normally but does not heat food
Test it. Put a bowl of water in the microwave and place a small (1 or 2 sq inches) piece of aluminum fold next to it. Power the microwave on for 2 or 3 seconds. If the foil sparks, the oven is creating microwaves and should be functioning correctly. If nothing happens to the foil, then you have no microwaves being generated by the klystron tube.
You can spend 80 to 150 dollars to have the oven checked and repaired or you can find another on Craig's List in your community for less than 100 dollars. Alternately, you can replace with a new one for whatever you are able to spend (from 95 to 600 dollars).
Sep 20, 2009 | Maytag MMV4205 Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Everything on oven appears to work, but does not heat.
from what your describing it sounds as if you have burnt the antenna off of the end of the magtube if this is the case if your microwave is no longer under warranty due to the cost of the part you may be better off to purchase a new microwave.
Mar 25, 2009 | GE JE1540 Microwave Oven
Micro wave not heating
Hello jrsnelus,
The main purpose of a microwave oven is to generate microwaves to heat food in the compartment so if it doesn't do that, then chances are that a component has failed. The fact that everything else seems to work suggests that you at least have ac power getting to the controls. You more than likely have a bad magnetron tube , filament transformer or high voltage capacitor that failed as part of the microwave generating system and it is not something that the untrained person should attempt to fix. Even unplugged, the high voltage capacitor remains charged up sufficiently enough to cause serious injury to someone. I've always been an advocate of the good old saying that if the cost to repair exceeds the cost to replace...then simply replace it. Even if you get an appliance tech to examine it, chances are his fee and the components that he finds defective will more than offset a replacement appliance.. I wish I could have suggested a better alternative for you..
Regards,
Rick
Nov 25, 2008 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave does not heat food placed in the center of the turntable. Leaves a cold spot in the middle of the food.
This is normal. That's why I always recommend to my customers that the food be placed slightly off-center on the turntable. An analogy I refer to is stirring paint: If you stir paint with a stick by simply rotating the stick in the center of the can, it's far less effective than pulling the stick around an imaginary circle halfway bewteen the center and the edge.
Jun 09, 2006 | Whirlpool MH6150XMS Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
474 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
