Question about Maytag Dishwasher
Soap remains in dispenser after completed cycle and dishes are not clean
  • 10,865 Answers
Hello laura.... there are three possible causes of the dispenser not opening:
1.Timer
On many dishwashers, a plastic actuator arm mechanically links the timer to the detergent cup. When the timer reaches the proper time in the cycle, the timer activates a lever that opens the detergent cup. If the linkage is broken or defective, the cup stays closed after you've closed it. Check the link and repair or replace it, as necessary. 2. Bi-metal switch or wax motor A bi-metal switch is a simple electrical device that deforms when electricity is applied to it. The degree of this deformation can be engineered to concise standards. The timer energizes the bi-metal switch inside your dishwasher door--directly behind the detergent cup--when the detergent cup should open. When energized, the bi-metal switch deforms away from the detergent cup latch, which opens the detergent cup. If the bi-metal switch is defective, it may not deform enough to open the cup. If that happens, you need to replace it. On some dishwashers, the bimetal switch is wired through the heating element or motor circuit. If the element is broken (or open), or if the motor is drawing low current because of a low-fill situation, the bi-metal switch doesn't open properly. Newer dishwasher models use a wax motor instead of a bi-metal switch. It's a sealed unit with wax that heats up and pushes a piston through to open the door. The wax motor, controlled by the timer, mechanically opens the door. 3. Detergent cup, itself The detergent cup itself can become clogged with old dried detergent that prevents it from opening. Sometimes just cleaning the cup takes care of the problem. If not, you probably need to replace the entire cup assembly That said, one way around this is to simply add the soap or the soap tab into the dishwasher proper, not into the cup. Joe Thanks for choosing Fixya!
Posted on Mar 13, 2011
  • 213 Answers
SOURCE: dishes not clean
water valve under dishwasher that let the water come in is not opening all the way causing either low water level or no water to come into the dishwasher. with out the proper amout of water the soap cant be disolved. replace water val to solve problem
Posted on Nov 21, 2007
rickzilla
  • 706 Answers
SOURCE: dishwasher soap remains in the
Try cleaning the soap dispenser with white vinegar so that it is free of all detergent, then try using about 1/4 less detergent than you have been to see if you still have any remaining in the dispenser. Also, make sure your drain filter is free of all sediment so that the system can pump the water out freely. Lastly, if you are still getting some soap remains, then try using a sanitary setting that uses the hottest water and see if the excess soap is properly dispensed. Your water temp may not be getting hot enough so this test should help identofy the solution. Hope this helps !
Posted on Aug 20, 2008
SOURCE: dishes not drying and soap
servis. dasant speen.
Posted on Oct 12, 2008
  • 14 Answers
SOURCE: Amana ADW862EAS Dishwasher. Dishes remain unclean. Soap reidues bellow the dispenser. Need to replace dispenser lid?
could be pump
Posted on May 26, 2009
  • 677 Answers
SOURCE: top rack of dishes is not clean
the problem sounds like your water. www.dishwasherfilter.com has an amazing product out that fixes this problem once and for all. it is a small filter that filters the hardminerals out of your water before entering the dishwasher. it is very affordable and guaranteed to work or your money back. you will be amazed how clean your dishes look.
Posted on Aug 11, 2009
Hi. My problem is with my dishwasher detergent dispenser. It does open (at least it is open at completion of cleaning cycle), appears to deliver soap to dishes (as they appear clean), however, from the...
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem
Detergent Cup does not Open
heatman101
Feb 14, 2011 | Maytag MDBH985AWB / MDBH985AWS 24 in....
Washer will not dispense soap from dispenser.
make sure that the soap dispenser if clean and free of residue build up. if this is clean you need to replace the dispencer
May 19, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Soap dispenser problem?
Check the water supply. Start cycle then open the door after it fills and check water level and spray action. If everything is soaking wet, there is probablyl a pizza pan blocking the soap tray.
Jan 05, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Soap doesn't empty from dispenser
Assuming you are using the correct detergent powder, check if the dishes are remaining dirty.
The water from the impeller may not be rushing up enough due to blockage or limited movement of impeller arm. Follow the insructions to clean the impeller, filter etc or check base of drawer for obstructions to impeller arm.
Dec 04, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwasher does not rinse clean
run the dishwasher empty: use 1/2 the amount of soap you usually use in the soap dispenser close it then put white vinegar in the open dispenser and, run the dishwasher
Apr 22, 2009 | Dishwashers
OLD KITCHENAIDE MODEL KDI-20 LEAVES SOAP GRANULES ON DISHES.
I have this same problem, plus the pre-wash soap dispenser doesn't open sometimes even though a service guy replaced that. Could he have replaced just one side and not the other? this dishwasher also has a new motor. sometimes it washes beautifully. but other times it does not. even if both dispensers opened.
Dec 04, 2008 | KitchenAid Dishwashers
Whirlpool gold quiet partner IV
You probably need to clean the filter; here is a site to show you how to do it: http://01tutorials.com/video/1686251/how-to-clean-the-filter-on-a-whirlpool-gold-quiet-partner-iv-dishwasher/4107
Sep 20, 2017 | Whirlpool Gold 24 in. Built-In Dishwasher...
Soap dipenser
Try this... Wipe out the soap dish with white vinegar and a soft cloth.. make sure you get everything off the edges of the door and look for any nicks, blemishes or deformation of the dispenser door to make sure it is not mechanically binding up when it is cycled open. If Ok.. then.. clean your drain filter.. then.. start a wash cycle using the hottest setting ( without any dishes) .. and after about 10 minutes or so.. stop the process and open the door and add in 2 cups of white vinegar.. Let it complete the wash cycle.. When complete..try running a dishless cycle on any setting with detergent ( use about 1/3 less than you usually use) and see if that dispense adequately. If that works, then the next time you load the washer. make sure you don't have anything up against or limiting the door from opening. Hope this helps..
Sep 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwasher soap remains in the soap dispenser following the complete cycle. I have had the washer for a year and a half. The first year, no soap remained in the dispenser. Now about 1/8th of the soap...
Aug 20, 2008 | Whirlpool Dishwashers
Dishsoap stays in soap dispenser
ok, either a spring, trigger prob, on the latch, or a electronic prob. ok so to see if the latch is ok (or not) look closely for soap residue and scum, that may be hindering the latch or spring under. use metho, and warm water to clean this part. secondly go down to a white goods repair place and take your electrical component, button, lights its all one unit, simple unscrew it, i do think you will need a set of torque screws for that tho... anyhow ask the guy to get you a new or second hand one and install it. the timer will run, and the clip will release. good luck!
Sep 25, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Maytag Dishwasher Logo
220 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
