Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I accidently dropped a few staples in the back of my Epson Stylus NX110 printer where the paper guide is located and was wondering how I can clean it out. Would I have to unscrew the top? I have shook the printer and a few fell out but I think there are still a few more in it because when I try to print it won't feed properly.
  • Dorothy Gray Mar 13, 2011
    I already knew I had to unscrew the top and I wasn't comfortable doing that. I will just take it in to a shop and have someone look at it. Thanks anyway.
  • 72 Answers
You will have to remove the unit from power and unscrew casing screws. If you're not comfortable with this, then you should take it to a local service facility so they can do it properly for you.
Posted on Mar 13, 2011
My epson stylus nx110 will not power on. whats going on?
Find something electrical and plug it in to the wall socket to prove you have power there.
Make sure the wire is plugged into the back of the printer it is has a removable lead. Check if there is an off switch in that area.
Still nothing? It needs to go back.
All the details on your printer including troubleshooting tips are here. I recommend Canon or HP.
Epson Stylus NX110
Jun 27, 2016 | Epson stylus nx110 All-In-One InkJet...
My epson stylus NX110 is printing blank pages
Printer heads clogged or cartridges are empty or defective.
Feb 10, 2014 | Epson stylus nx110 All-In-One InkJet...
My printer wont recognize paper
Remove all of the paper from the tray and shine a flashlight into the printer. Look for any torn pieces of paper or other debris that could be blocking the paper sensor.
Pull the paper guides back as far as they will go, then reload the paper tray. Push the paper guides until they are tight against the paper on all sides. If the paper guides are loose or not properly adjusted, the printer may not sense that the paper is in place.
Look inside the printer if you have a unit with a single paper tray. Locate the print rollers, then look for a small plastic flag that moves up and down when the paper feeds into the printer. Jiggle this paper flag until it moves freely. If the paper flag is out of place the printer may not recognize that there is paper in the tray.
Pull each tray out of the printer carefully if you have a unit with multiple trays. Find the print rollers and the paper flag. Jiggle the paper flag until it moves up and down freely, then replace the tray.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Feb 22, 2013 | Epson stylus nx110 All-In-One InkJet...
Ok my Epson stylus NX110 isnt working like it was yesterday now the paper gets stuck half ways i mean i can hear the printer still running and all but the paper doesnt roll down???? what should i do???
  • Turn the printer off.
  • Please inspect the paper paths and look for any stuck papers which may cause paper jams.
  • Look through the feeding tray and remove manually any visible stuck papers.
  • Turn the printer on and print.
Hope this helps.Thanks!
Sep 29, 2011 | Epson Office Equipment & Supplies
How do I LOAD CARTRIDGES INTO MY EPSON STYLUS NX110 PRINTER
Follow the link below:
http://files.support.epson.com/htmldocs/nx110_/nx110_ug/wwhelp/wwhimpl/js/html/wwhelp.htm
Click "replace ink cartriges" on the left of the page
and then select "Remove and install Cartriges"
May 04, 2011 | Epson stylus nx110 All-In-One InkJet...
Printer jamed after putting in more paper and accidently pushed the power button off. Will not respond to anything I have tried.
Reset your Printer by following these steps for your Printer Model:
EPSON Stylus Color 900, 980
Pressing and holding LOAD/EJECT and CLEANING buttons, press POWER button, You will see blinking INK OUT led.
Release all buttons.
In 2-3 seconds time press and hold CLEANING button for 10-12 seconds.
EPSON Stylus Color 3000
Pressing and holding PAUSE, LF/FF and DOWN ARROW buttons turn on printer.
EPSON Stylus Photo 785, 895
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Error led.
In 2-3 seconds time until led is blinking press and hold for 10-12 seconds Roll Paper button, until all leds will blink.
EPSON Stylus Photo 890, 1280, 1290
Pressing and holding Maintenance and Roll Paper buttons, press POWER button, You will see blinking Power led.
Feb 27, 2011 | Epson Stylus Photo 785EPX InkJet Printer
Replaced the ink cartridge now it will not print
*** I'll be more than happy to help you on that.
there is a great possibility that the nozzles of your printer are clogged by dried inks.maybe cause by the previous inks that you just replaced. we can check that by printing a nozzle check pattern.
1. Load a few sheets of plain paper in the sheet feeder. 2. Turn off the Epson Stylus NX110 Series. 3. Hold down the nx110_tx110_ug.1.98.1.jpg Stop button as you press the nx110_tx110_ug.1.98.2.jpg On button to turn the Epson Stylus NX110 Series back on. When the nx110_tx110_ug.1.98.3.jpg On light begins to flash, release the nx110_tx110_ug.1.98.4.jpg Stop button. nx110_tx110_ug.1.98.5.jpg 4. Check the nozzle check pattern that prints to see if there are gaps in the lines. nx110_tx110_ug.1.98.6.jpg 5. If there are no gaps, the print head is clean and you can continue printing. If there are gaps or the pattern is faint, clean the print head. Using the Control Panel 1. Load a few sheets of plain paper in the sheet feeder. 2. Make sure the Epson Stylus NX110 Series is on and the ink light is off. 3. Hold down the nx110_tx110_ug.1.99.1.jpg Stop button for three seconds to start the cleaning cycle, which lasts around one minute. The nx110_tx110_ug.1.99.2.jpg On light flashes throughout the cleaning cycle and stays on green when the cycle is finished. Caution:
Never turn off the Epson Stylus NX110 Series during a cleaning cycle or you may damage it. 4. Run a nozzle check to confirm that the print head is clean. You may need to clean the print head up to 4 times. You can also turn off the Epson Stylus NX110 Series and wait at least 6 hours. Then try printing again.
Feb 16, 2010 | Epson Stylus NX115 All-In-One InkJet...
Missing installation software
Yes indeed. Here is the main support page for your printer:
Epson NX110 Support (Save it to your Favorites for future reference.)
Click on Drivers & Downloads.
Select your operating system from the drop-down menu. (Windows or Mac)
Since you are installing a new printer, select the Drivers and Utilities Combo Package. If you have Windows, make sure you select the correct one: 32 bit or 64 bit system. If you are not sure Comment back.
When you click on the package name it will expand and there will be a Download Now link. Click it.
You may get an option to receive emails from Epson at this point. You choose Yes or No, and Accept the EULA.
You will then get a Download pop-up. Best thing to do is to select Save and direct the download to save it to your Desktop. Once the download is complete, close the window. Close all of your open applications.
Prepare your printer (Power, ink installed, paper) as in the Setup guide. Make sure you do not connect the USB cable at this point.
Run (double-click) the file on your desktop to begin installation. Connect the cable when prompted by the software. That should get you going.
If you have any problems, just Comment back.
Thanks for using Fixya.
Note: In case you did not get the startup guide or user manual, there are links for them too on that main support page.
Sep 29, 2009 | Office Equipment & Supplies
EPSON R300 PRINTER NOT FEEDING PAPER INTO MACHINE.
Take all the paper out,Make sure non of the paper is folded under on the stack. check the paper-feed area for debris,(papreclips, staples post it notes etc).
Check the tray and its guides are secure and it the correct positions.
Open the machine check the paper path for debris, bits of paper or anything the looks out of place.
Once you have checked and cleared everything, close uo the machine and try again.
If you are inclined, you can clean the paper rollers with alcohol.
Hope this is of some help
Ed
May 11, 2009 | Epson Stylus R380 InkJet Photo Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
546 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
