Question about LG WM2016C
I have a wm2016cw washer and can't find the manual. It is giving me an OE msg. I know that means drain error but how do I fix it?
    Scholar:
  • 106 Answers
Here is the knowledge base information. http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6273
If you check all these, and still getting the error, you'll need to get the drain motor replaced. This is not a simple task, as the entire front of the unit must be removed to access the drain pump area.
Top must come off, control panel detached, door gasket outer ring needs to be removed, door lock also much be unplugged. The front panel of the unit also needs to be removed as well.
Posted on Mar 14, 2011
I"m getting the OE signal.
Here is a tip that I wrote that gives more detail about how to fix the OE codeon LG washers....
LG Washing Machine OE Error Code
heatman101
Aug 12, 2011 | LG WM2277H Front Load Washer
I have the error code OE showing up, and the water is not draining from the washer. What should I do?
OE - drain error - 5 minute time out drain time error. check your pump/filter for blockages. Clean out the trap from the bottom, something is jamming the drain motor.
The LG error code OE simply means "the pump is blocked". Presumably the water isn't being emptied properly. As with all error codes it is possible that there is a cause other than the exact description in the error code explanation but basically this error means as far as the washing machine is concerned it thinks the water isn't pumping out. A pump, or filter blockage is the most common cause but it could be caused by other faults such as a faulty pump, or even a blockage in the drain hose or somewhere else in the system etc.
Jun 22, 2011 | LG WM-2277HW Front Load Washer
Won't drain during cycle, drain motor noise before stopping with OE drain error?
Here is a tip that I wrote that gives more detail about how to fix the OE code on LG washers....
heatman101
Sep 03, 2010 | LG WM0642H Front Load
Getting an OE error code on WM2016CW washer. Have checked the hose for bends and emptied the drain filter? Still getting error message?
OE error is because the machine is slow to empty..Check and see if the machine is draining slowly or not at all..Sometimes coins get caught in the impeller itself...The type of pumps used on LG machines can fail because of muck and detritus getting behind the impeller back plate..Dismantle pump. Mark pump and body to help with re-assembly. If impeller comes out of motor body, you'll have to feplace the pump motor..Universal pump motors are generally ok.. Gravity drain to empty machine.. Good luck....Nomess
May 19, 2010 | Washing Machines
My lg front load washer stops and give me an error message OE
LG themselves have some information on this error code..
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 27, 2009 | LG WM-2277HW Front Load Washer
LG WM2016CW won't drain
The impeller may have come off the pump motor shaft. Generally, you will notice a louder sound when the pump runs if this happened.
Unplug the machine. Remove the filter recess by removing the one screw inside and using a putty knife at the left and / or right edge and popping it out. Pull the machine out about 18 inches and tip it back, resting it against the wall. Remove two more screws behind where the recess was holding the pump housing on. Reach under the machine and remove pump. There is a tab to depress under the pump housing to release it from the base. The pump motor is held onto the housing by three screws. Remove them and inspect the impeller to see if it has come off the shaft. If it has, pushing it back on will not solve the problem, as it will come off again. Install new pump motor and reassemble. Clean washer tub with the longest, hottest cycle and three Ah-fresh tablets, Whirlaway hot tub cleaner, Smellywasher cleaner (smellywashercleaner.com) or Tide washer cleaner. Repeat. From now on, use only 1 tablespoon of HE laundry detergent per load (1/2 T if 2X concentrate) and only 1 teaspoon of fabric softener per load if you use it. (these machines use very little water, and thus require reduced amounts of additives to work properly)
Feb 08, 2009 | LG WM-2277HW Front Load Washer
LG Trom wm2077gw OE error code and won't come off and empty macine I washed a comforter and it shredded part of it and is stuck on OE what does this mean and how do I fix it. Thanks
OE means it has not fully drained with in 10 mins. You may have something in the drain. Open the little door on the front, ust the small hose to drain it first, then take out the button trap. If you don't see anything, you can also check your drain hoses and if you want tilt back the unit, support it with something and look in the bottom hose make sure you don't have a sock or something there.
Sgt 48
May 20, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG WM2016C Logo
359 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
