Question about Jetta Radio Wire Harness Wiring Stereo Plug W Amp
How do I get factory amp to work with after market radio with correct wiring harness
    Problem Solver:
  • 10 Answers
not much can help without seeing all fittings but if you nip to motorworld they have most connectors for aftermarket and they got decent guys who fit the systems they sell,
hope this helps
Posted on Mar 13, 2011
Can i hook up a parakeet model number PWM 16 to my factory stereo in a 98 Ford Expedition
About 3,970 results (0.89 seconds) Search Results
    Ford Bluetooth® Wiring Harness - Crutchfield
    www.crutchfield.com/.../Ford-Bluetooth-Wiring-...
    Crutchfield Corporation
    Rating: 4.5 - ‎16 reviews - ‎$19.99 - ‎In stock
    Reinstall the factory radio and mount the Bluetooth kit, and you're ready to go. ... 16Reviews ... harness so that I could hook up an aftermarket amp to my factory radio.... works like it's suppose to. says it doesn't work on an 09 Escape but had no .... I purchased this harness to install a parrot ck3100 in my 07 Ford Edge.Missing: pwm
    70-5521 wiring harness for ford with 6 CD premium sub amp ...
    ? 4:30
    https://www.youtube.com/watch?v=0jqNafnki0o
    Aug 9, 2013 - Uploaded by codieraji
    Metra 70-5521 Radio Wiring Harness for Ford 03-Up Amp FordPremium stereo radio 6 CD changer with sub amp inputs. ...16:47. How to wire an aftermarket radio / I Demo install with metra harness and antenna ... How to hook up stock amp/sub to aftermarket head unit "ford sport trac" - Duration: 3:01. Pat.Missing: parakeet ‎pwm ‎98
    Car Stereo Wire Harnesses - Radio Wires for all Car Audio ...
    www.installer.com/main.php?page=harness
    Car Stereo Wire Harnesses - Car Stereo Installation Wiring - Stereo Harness ... If you
Feb 09, 2016 | Ford Cars & Trucks
No sound aftet market radio put in it light up but no sound
Make sure you have the correct wire harness and all speaker wires are hooked up. If so make sure your ride doesnt have a factory amp. Some bose or infinity factory sound systems have a factory amp that you may need to bypass
May 15, 2014 | Cars & Trucks
I need installation instrutions
for starters get a harness that plugs into your factory radio harness everything in color code so it helps plus dash kit for after market radio you need to wire the remote wire for your amp to blue wire on harness or your acc wire on harness run amp power wire down one side of car & remote wire and rca wires down other side of car so you dont get any engine noise most important make sure you get a good ground to amp if there is any paint or rust where you ground amp use sand paper to clean surface you want good contact with metal hope i was helpful if you need anything else leave another message and ill try my best to help
Mar 06, 2013 | Car Audio & Video
Color code radio wiring harness 2006 dodge charger
buy a harness .. much safer , without cutting factory wires
Mar 05, 2013 | 2006 Dodge Charger
Where is the 4 channel amp located in the 94 nissan quest.?I am trying to install a stereo and there is no sound due to the amp. I need to know how to wire with the built in amp.
I just installed an after market radio in my 94 Quest.
The easiest way is to buy a Nissan Quest Radio Wiring Harness for Premium Sound. It will have the complete wire hookups. You can also hook up the blue wire from the new radio to thefactory (I think Blue or Blue/White) wire on the harness. That will turn the factory amp on.Hope this helps ,good luck
Jan 07, 2011 | 1994 Nissan Quest
I put an after market cd player in my 2003 acura 3.2 tl type s. all the speakers are working fine but i am not getting any sound out of the factory subwoofer, it is not working. any idead what i did wrong...
You got to connect the blue amp turn on wire. If still dont work. then you got to find the factory amp find the two wires that sends frequency signals to the amp. You will see a total of 7 wires. So you've got to use process of elimination. Use a multimeter.
1.Constant 12 Volt
2. Ground
3. Amp turn on
4. + output wires going to the + of the subwoofer
5. - output wires going to the - of the subwoofer
6 + input wires going to the radio harness
7 + input wires going to the radio harness
6 & 7 are like the rca's you plug in at the input of an aftermarket amplifier and and on the other end plug in the output subwoofer of the Radio.
So on a factory amp you wont see any RCA's its all wires. Once you find the first 5 just remember the last 2 wires.
If you want your radio to control the gain and volume of the Subwoofer get a long RCA plug it on the back of your radio that says sub output and then cut the other end of that RCA and connect the positive the + input wire on the amp and the negative to the negative input wire on the amp.
If you dont know whats positive or negative just go ahead and connect it and experiment. You will know if your in phase when the subs sound boomy. Then the connections are correct. If it sounds Tinney then the connection is out of phase. solder then tape all connections with black electrical tape. Dont leave any power wires exposed or else cause a short and blow fuses.
Good luck
Apr 07, 2010 | Car Audio & Video
Installing an aftermarket stereo, spliced the wires and have everything connected including the remote wire to the factory amp wire but still no sound.
There is no remote wire on these newer trucks....03 and up....u have to buy the harness....although i didnt....i have an 03 gmc sierra and just pulled the schematic and matched the wires. And there is no programming to do on an aftermarket stereo.....I work for GMC and we cant program aftermarket stereos......if u buy the right harness ...and its over $100 then everything should work just fine.....and this does not disarm ur alarm system either....mine still works fine....hope this helps
May 08, 2009 | 2003 GMC Sierra
Wiring after market stereo to factory wiring equipt with factory amp
you have to get the cable that conects your factory deck harness to the aftermarket deck, and that will allow you to use your factory speakers and amp, the wire harness is availiable at canadian tire or any stereo shop
May 05, 2009 | 2001 Pontiac Grand Am SE
Replacing factory radio
With that year vehicle it is recommended that you use a special harness because it has an factory amp and in order to get the proper wiring it requires the harness also if you don't use the harness you will loose your onstar and vehicle chimes and warning sounds.
Oct 08, 2008 | 2004 GMC Envoy
Jetta Radio Wire Harness Wiring Stereo Plug W Amp Logo
70 people viewed this question
Top Jetta Car Audio & Video Experts
xxxxxx xxx
Are you a Jetta Car Audio and Video Expert? Answer questions, earn points and help others
