Question about HP Office Equipment & Supplies
Had to restore computer to factory settings. Installed HP printer, however have no idea what I did, but lost language connection, have been getting french. I am elderly so please explain in simple language. Thank you
  • 76 Answers
Pls. go to hp.com using a browser then pls. look for the tab Support & Drivers and click it. On support & drivers page, pls. tick See support and troubleshooting information. Then on for product: option, pls. type in your printer's Model no. and click either the >> button or GO button. It will redirect you to Product search results. All you have to do is to select the printer type that you would like to troubleshoot. then look for the link Manuals and download it. It has a complete details on how you can setup and configure your printer. look for the settings on how to change the language on your printer.
Hope this helps and pls. rate this thanks.
Posted on Mar 13, 2011
RESET TO FACTORY SETTINGS
What type of Laptop ? and operating system on it ?
Restoring your laptop to factory settings can take up to an hour to perform, depending upon the type of laptop and operating system on your machine. Prior to performing a system recovery, you should remove any external peripherals, such as ExpressCards, PC Cards, and USB-connected printers and hard drives. Turn on the laptop. Press the "F8" key until the "Advanced Boot Options" screen appears. Select "Repair Your Computer" using the arrow keys. Press the "Enter" key. Choose your "Language," then "Next." Login with an administrator-level username and password. Click "OK. Select "Dell Factory Image Restore," then "Next." Tick the check box next to "Yes, reformat hard drive and restore system software to factory condition." Click "Next." Click on "Finish" after the computer has concluded the factory restoration. b> Restore on an HP b> Insert the HP recovery disk. Restart the computer, and press the "F11" key. Press the "F" key to "reinstall factory settings." If your computer's operating system is damaged, you may only see "perform a full system recovery" as an option. In this case, press "R." Insert any disks if prompted by the restoration program. Otherwise, permit the computer to restart as needed. b> Restore Via Disks (Generic) b> Insert the "Recovery Disk" or "System Recovery Disk." If you have more than one disk, make sure you insert "Disk 1" or "Part 1." Press any key to boot from CD if prompted to do so. Choose a "Full System Restore," "Restore Factory Settings," or another option worded similarly. Confirm that you want to perform the restoration. Press "Next," "Yes," or "OK," as needed. Press "Finish" or "Restart" when prompted by the computer. Hope this helps.
Dec 23, 2012 | Computers & Internet
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
Reset hp 1515n
? Restore defaults-used to reset all customer-accessible menu settings back to the factory default
settings (except language) via the control panel or software
NOTE: This service menu item does not reset factory-settable settings, including formatter
number, page counts, factory paper settings, language, and so on.
NOTE: Before restoring defaults, print a menu structure report and a configuration page. Use the
information on these pages to reset customer-specific settings.
CAUTION: All HP Jetdirect settings are also reset. Be sure to print a configuration page before
restoring defaults. Make note of the IP address that is listed on the Jetdirect configuration page. You might need to restore the IP address after performing a cold reset.
Restore the factory-set defaults on the (HP Color LaserJet CP1510 Series Printer
1. Press OK to open the menus.
2. Use the Left arrow or the Right arrow button to select Service, and then press OK (Select).
3. Use the Left arrow or the Right arrow button to select Restore defaults, and then press OK.
The product automatically restarts.
Jul 13, 2011 | HP LaserJet CP1515n Printer
Want to restore dell 9400 inspiron to factory settings ,.forgot hardware reset pass word, i disconeected memory battery while replacing kry pad
I you restore your laptop to factory settings, all data and software installed would be lost. i f you are fine with that or u have backed up the data already, follow the below process:
I have assumed that you have windows vista or windows 7:
  • Power off the laptop. Remove any peripheral devices such as speakers, printers or flash drives that are not necessary to this operation. Power on the laptop while holding down the "F8" key until the advanced boot options menu appears.
  • Move the arrow key to "Repair Your Computer." Hit the "Enter" key.
  • Select the language settings to be used for the recovery process with the arrow keys and hit "Next." Log in, if necessary. Press "Next."
  • Choose "Dell Factory Image Restore" OR "Complete PC restore" to restore the drive's original factory settings, and click on "Next."
  • Check the box next to the "Yes, reformat hard drive and restore system software to factory condition" option. Select "Next" and the computer will recover itself based on its configuration settings in the recovery partition.
This will take your computer on the day you bought it. You will get all application back which were pre-installed and will loose everything which you put by yourself.
Cheers!!!
May 10, 2011 | Dell Inspiron 9400 Notebook
Have HP Photosmart C5280 installed and have been using it for several year. For some reason now will not talk to computer, have checked all connections - what else can I check. Computer and printer have...
Please perform this reset
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Sep 19, 2010 | Office Equipment & Supplies
Sda
To change the device control panel display language
1. Press MENU/ENTER.
2. Use the < or the > button to select Common settings, and then press MENU/ENTER.
3. Use the < or the > button to select Language, and then press MENU/ENTER.
4. Use the < or the > button to select the language that you want.
5. Press MENU/ENTER to save your selection.
The device automatically restarts.
If this does not work you can always reset the printer to factory settings,but keep in mind you have to set it up again.
To restore the factory-set defaults
2. Use the < or the > button to select Service, and then press MENU/ENTER.
3. Use the < or the > button to select Restore defaults, press MENU/ENTER, and then press
MENU/ENTER again to confirm your selection.
Hope this helps good luck thanks.
Mar 23, 2010 | HP LaserJet 3015 All-In-One Printer
A student has reset the menu to Russian.
My company uses nothing but HP printers some are connected to the network while others are locally connected to a computer. I have worked with this exact model.
First, the easiest thing to try is to power cycle the printer. Hold down the button to turn off then turn back on. You can also unplug it from its power source then plug back in.
Power cycling this printer should reset the language to default (English) or it will let you select the language when it comes back on. If that doesn't work then you can try to change it using the installed software.
Considering the fact that someone accidentally changed the language, I am assuming this printer is connected directly to a computer that you all have access to and this is not a network printer.
If this is a local printer (connected directly to the computer via USB or parrallel port) then you should have an HP Toolbox app or some other program that allows you to configure software related settings for the device. Open this tool and you should find an option for the language. This may not be available, depending on how the installation was handled (if it was installed using the CD provided by the manufacturer or installed using downloaded drivers).
Try this out and let me know if it helps.
Mar 26, 2009 | HP Color LaserJet 2600n Printer
Lost Stuff
Yes. Once we restore the computer is set back to factory settings all the functionalities along with sound and cd/dvd drive will work fine as the software,drivers along with saved data and corrupted files will be deleted and a fresh copy of windows will be installed.
In order to perform a restore back to factory settings follow the steps below:
1. Turn off the computer completely.
2. Make sure the computer is connected to power adapter.
3. Press the power button to turn it back on and at the same time simultaneously keep tapping the ' F11 ' key on the keypad until you see a screen says 'welcome to hp recovery manager ' . you may here few beep sounds during this process. Select ' destructive recovery' option and follow the onscreen instructions to complete the process.
Note: This process may take an hour to complete and make sure to take a back up of your important data on to a cd or dvd as the process completely deletes all the files on the computer.
Thank you.
Nov 28, 2008 | HP Pavilion dv6000z Notebook
35 people viewed this question
Seeker5211
Seeker5211
