Wireless receiver for LG HB965TXW stays in standby mode. How do I fix the problem
If you have the solution please, email me.
strike_nsniper@hotmail.com
I've the same problem.
Thanks
Posted on Mar 20, 2011
  • hogiebbear Apr 11, 2011
    As do i! Anyone have a solution to this yet?
Button standby
The receiver is in protect mode, most likely due to a damaged amplifier. This protect mode, keeps the unit from turning on and causing further damage to itself and/or your speaker system. For more information, please visit my website at audioserviceclinic.com. Thank you.
Jul 27, 2013 | LG Lsb316 Sound Bar With Wireless...
Reconnect my wireless lg w95 receiver to my blue ray after it was unplugged
Wireless speakers connection
LED indicator of wireless receiver
LED Color Operation
Blue - The Wireless Receiver is receiving the signal of the wireless transmitter.
Red - The Wireless Receiver is in standby mode.
Off (No display) - The Wireless Receiver is turned off.
Initial setting an ID of wireless receiver
1. Connect the Wireless Receiver and the rear speaker (right, left) with the speaker cables.
2. Connect the power cord of the Wireless Receiver to the outlet.
3. Turn on the main unit and Wireless Receiver: The main unit and wireless receiver will be automatically connected. "MATE OK" appears in display window. Setting an ID of wireless receiver When the unit is manufactured, the ID is already set. If an interference occurs or you use a new wireless receiver, an ID should be set
again.
1. Turn on the main unit and turn off the wireless receiver.
2. Press and hold x (STOP) on the front of unit and MUTE on the remote control. "REMATE" appears in display window.
3. Turn on the Wireless Receiver. A new ID is set.
Nov 23, 2011 | Televison & Video
Receiver for LG HB965TXW stays in standby mode
Thisc an be due to a protection fault condition. The fault can be your output drivers- the MOSFETS/IC's fitted for both the channels, Use a meter after disconnecting to check for short in the drivers. Disconnect the positive and negative voltages to the output and see if the protect changes. Even a fault in the preamp stages that drives in high current into the output can shut the Amplifier. Sometimes this can be a noise like a HUM or HISS before the protect works. Faulty capacitors in these circuits also can cause similar issues and needs close observation.
You need to confirm and replace the specific stages or outputs. If not there can be issues in the mother board, maybe the protect circuit by itself is shutting off due to a faulty bias , maybe a leak in any voltage/current sensing circuit. Also disconnect the speakers and test, if the protect is off then check for short on the speakers.
Jul 09, 2011 | Audio Players & Recorders
Receiver stays on stand by
Turning On and Standby
On the AV receiver, press the [ON/STANDBY] button.
On the remote controller, press the [RECEIVER] button, followed by the
The AV receiver comes on, the display lights up, and the STANDBY indicator goes off.
To turn the AV receiver off, press the [ON/STANDBY] button, or press the remote
controller's [ON/STANDBY] button. The AV receiver will enter Standby mode.
If you have any trouble using the receiver, a simple reset could solve your problem.Note that resetting the AV receiver will delete your radio presets and custom settings.
To reset the AV receiver to its factory defaults, turn it on and, while holding down the [VCR/DVR] button, press the [ON/STANDBY] button. "Clear" will appear on the display and the AV receiver will enter Standby mode.
Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Onkyo TX-SR307 A/V Receiver
No signal from player to wireless receiver lg hb965txw
configure your player to your wireless player...
Apr 25, 2011 | Audio Players & Recorders
My LG ht303su dvd player won't eject and it says it's locked
my LG ht303su DVD player won\'t eject and it says it\'s locked
Jan 15, 2011 | LG HT303SU Theater System
Receiver stays on standby mode
Receiver either just stuck or held or having problem in amplifier output area.
Try to unplug it from AC outlet for couple of minutes and replug back in and power up, if works, fine and if does not, take it to local repair shop as it might requires some parts replacement in amplifier out area.
Feb 10, 2009 | Insignia Audio Players & Recorders
HK AVR130 Standby Button not working
I am experiencing a simular problem; amber light stays on ; no other lighting appears. this occured after leaving the avr in standby mode for a long time. I even tried to reset the unit as stated in the last page of manual after the trouble shooting advice - still no response - good luck!
Sep 18, 2008 | Harman Kardon AVR 130 Receiver
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
390 people viewed this question
 Grubhead
Grubhead
