Question about Acer Computers & Internet
Mine s an acer aspire4741Z model,my bluetooth is not working,what must I do?
    Sergeant:
  • 154 Answers
Use Windows update to download the latest patches.
Then try the Acer online drivers repositary and download the necessary bluethooth driver. A restart after installation should help.
http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=2434
Posted on Mar 13, 2011
How do I get the acers 5742Z drivers installed? I have down loaded all the bluetooth drivers,and none work.
You can get all the acer 5742Z drivers from this web :
http://www.acer.com.au/ac/en/AU/content/drivers
Get your correct model of your bluetooth and download the drivers. There are two different model of bluetooth model which is atheros and broadcom
Sep 28, 2013 | Acer Aspire 4720 Notebook
Internal bluetooth card
You did not state your model. Not all Acer models have internal bluetooth cards. Search in your model's documentation to find out if your model has one. Mine (Aspire 5738) hasn't, and I was looking for the same solution a long time before I found out.
Feb 18, 2013 | Acer Aspire Computers & Internet
Wen i press the bluetooth icon it doesnt flash up or light up i cant get it to work please help me!!
Not all ACER's have the bluetooth card, check on ACER website to see if your model does.
Get the model number off the bottom of your case.
If your model has bluetooth and it itsn't working, try reloading the driver.
Dec 26, 2010 | Acer Computers & Internet
Bluetooth connection on Aspire 5535-5452 latop
yes its true, there is no bluetooth device on the PC. You need to order for it separately.
My friend uses an acer product, and he had to get an external blue tooth device. Even though the blue tooth software is installed and visible on the control panel.
You might end up buying an external blue tooth.
Take care.
Jan 13, 2010 | Computers & Internet
ACER Aspire 7535G, can't get the bluetooth to work.
First of all check that you really DO have a BlueTooth unit. Acer uses the same chassis for models with and without Bluetooth, so the button being there doesn't mean necessarily there's something under it.
For example this one 7535G on eBay does not have a BlueTooth.
http://cgi.ebay.it/NOTEBOOK-ACER-7535G-824G25MN-250-GB-4-GB-LX.PCE0X.086_W0QQitemZ230389757718QQcmdZViewItemQQimsxZ20091019?IMSfp=TL091019235001r2963
If you do have bluetooth:
Check the Bluetooth is active in the BIOS, and if you have a single button model ("one button to rule them all") check the button configuration - there should be an Acer hotkey utility somewhere to do that. Very often, the button is set to control only one device between WiFi, optional internal cell modem, and BlueTooth. Normally that is WiFi. Set it to "Both". This, I repeat, if you DO have a 'single button' device.
Also, check you have the original Acer drivers. I once mis-installed a set of wrong Widcomm drivers without realizing it, and almost went crazy troubleshooting it.
Nov 12, 2009 | Acer Computers & Internet
My bluetooth is not working am using accer spire 4730z pls i need
hi,
alot of Acer laptops have the bluetooth button and an internal connector for a bluetooth module, but not the actual bluetooth module itself. I have an Acer 3050 and this is the case - its just simpler and cheaper for the company to build all the cases the same and just withhold the module inside - if you look carefully at the specs and labelling of the laptop itself, it probably does not specify bluetooth as a feature (they'd tell you if it was there). I have a friend with a higher model Acer than mine: case is identical except his has a dual core cpu, webcam and bluetooth in it.
Never trust the store ads - they are cut and paste together by people with little clue about the actual product.
If you want bluetooth, you can buy the module on ebay for $25 and you might need the connector cable to connect it to the socket. You can also find those ultra small usb bluetooth connectors on ebay for about $8 - might be a simpler solution: they are really small and barely stick out of the usb slot so you can leave it in there.
May 11, 2009 | HP Pavilion dv6000z Notebook
Bluetooth
I am having ACer 5500 Lapto Computer. I format my system and i installed XP professional. i installed all the driver softwares but the bluetooth device is not detecting, it show there is no bluetooth device check the device. How should i rectify the problem please help me. 5500 is consists internal Bluetooth.
Nov 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Acer aspire 4720z
hai
no, for that purchase one usb bluetooth device and connect it externally to the usb slot, get it installed using the CD pack
good luck
Rabby
Jun 17, 2008 | Acer Aspire 4720 Notebook
Acer Aspire 5610 Bluetooth not working.
I may be wrong but acer laptops have the bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a bluetooth symbol under the laptop. If you do not see it, there is no bluetooth. Also, if you press/move the bluetooth button, and the light doesn't turn blue, there's no bluetooth module with your laptop (only the button), so your laptop did not come with bluetooth.
Nov 25, 2007 | Computers & Internet
Computers & Internet Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
