Question about Aqua Garden
The instructions on my Aqua systems garden backpack garden sprayer said "Select the right Nozzle for either jet or fan spray" There were no alternative nozzles provided. The sprayer I bought has a sprayer head with two nozzles - both emit spray at the same time in a circular pattern and together create quite a wide swath. There is no way to cut off the spray from the second nozzle or to carry out spot spraying. Do you have another type of head with a single outlet and the choice of changing to a fan or circular nozzle for spot spraying? Further The spares included a flexible lid 4.7 cm diameter and 1 cm deep with what appears to a spring inserted in the inner perimeter of the "Cap". It was not identified on hte spares list and I cant identify it on the componants diagram. What is it? Thank you in anticipation of your assistance Phil
  • 156 Answers
SOURCE: Sprayer does not spray
It sounds that you need a new foot valve. It is the rubber thing on the end of the cylinder that is connected to the pump handle. It is not sealing the air in as you push it in. Hope this helps.
Posted on Jul 06, 2009
  • 143 Answers
SOURCE: I have a roundup 4 gallon back pack sprayer and i
There is a store on Monaghan St. that has parts for all sprayers, you should get one there.
Posted on Dec 01, 2009
  • 98 Answers
SOURCE: Bought anCampbell Hausfeld airless paint sprayer,
no fluid gets to nozzle or comes from nozzle.
sounds like your fluid line is pluged or the gun is pluged at or before the tip
Posted on Feb 21, 2010
radar001
  • 1051 Answers
SOURCE: Sprayer valve is clogged
I've had some success by removeing the entire trigger mechanism and soaking it in solvent for a few hours.
Posted on Mar 24, 2010
  • 5 Answers
SOURCE: herbicide sprayer stopped working
sometimes the tube/straw on the inside of the sprayer where the water comes thru falls off its connection.If you put the end of the hose in the sprayer you may have knocked it off.Depending on sprayer it can be easy or a pain to put back on
Posted on Jun 29, 2010
Part for 4 gallon backpack sprayer bought June 28, 2012. Spray spindle #40 for One Stop Gardens Model 65040
fixya doesnt sell products notify one stop gardens they may sell parts or advise of a parts distributor in your area or do an online search using make and model
Dec 05, 2016 | Garden
Best spray tip nozzle for herbicide application, SOLO 425
tee jet yellow nozzle with metal inserts john deere/lesco sells them in packs of four these are best for 1 gal per k spot treating selective herbicide ......round up just use the adjustable cone
Jan 14, 2011 | Solo Backpack Sprayer
Sprayer Question
Hose end sprayers are the simplest and least expensive of the category. A sprayer jar is attached to a regular garden sprayer. Concentrated material is added to the sprayer jar. An adjustment on the jar determines the amount delivered. The force of the water through the hose pulls the material up from the jar and mixes and dilutes it with the water. A built-in anti-siphon device prevents unused material from being pulled back into your water supply. Compression or tank sprayers are the most common type of spray equipment. Concentrated material is added to the tank. Water is then added to a marked fill line. The remaining air is pressurized by pumping the handle a designated number of times. A control lever on the wand controls the spray pattern and amount. Compression sprayers provide a precise, on target, non-drift spray good for soil and lawn pests. Adjust the sprayer for a coarse, drenching spray, a concentrated stream or a fine mist. Tank capacities range from 1 quart to over 3 gallon for handheld models. Homeowner type backpack sprayers hold up 4 gallons. The tanks may be made from polyethylene plastic, galvanized steel or stainless steel. In addition to treatments for pests and diseases, compression sprayers are designed for applying cleaning solutions for decks and siding. Backpack sprayers are operated in the same manner as the handheld compression sprayer. The over-the-shoulder configuration makes it easier to carry the heavier load of material. Some backpack models also use a lever-style pump to maintain pressure without removing the unit form your back. Powered sprayers rely on a gasoline engine for spray power. Great for larger yards or gardens due to portability and capacity (12 gallons). Dusters are a slightly different breed. Dry powders (mostly for blooming plants such as roses) are added to a canister and applied by manually pumping. NOTE: Compression sprayers deliver liquid under pressure. Compression sprayers are powerful and efficient tools. This fact also makes them potentially dangerous. Always read the manufacturer's instructions and safety precautions carefully.
Aug 27, 2008 | Sp Systems 02sv320065 Farm & Home 2 -...
Sprayers support
It is recommended that gardeners have at least two sprayers, one for herbicide and one for pesticide. This is not a sales gimmick, the residue from many herbicides is difficult to completely remove form inside a sprayer tank. This leftover residue could potentially harm other areas if the sprayer is used there. Plus, it's not a good idea to mix pesticides. Make sure you label each sprayer appropriately.
Aug 27, 2008 | Aqua Cannon Adjustable Power Sprayer
Garden Logo
946 people viewed this question
Top Aqua Garden Experts
ray gallant
gbob59
Tom Chichester
Are you an Aqua Garden Expert? Answer questions, earn points and help others
