Question about Mitsubishi WD-65733 65" HDTV
I was watching tv on my Mits WD65733 then there was a big boom,and it shut off and there was a red light that said lamp?? it was like a gun shoot going off,it is the lamp??
    Genius:
  • 1,030 Answers
Most likely it coulf be th bulb.. check owners manual on removing th bulb...the bulb then can be check visally
Posted on Mar 13, 2011
Reznor UDAP-100 heater miss fires when it shuts off. It also blows a big flame out when it ignites after the room temperature stablizes.
When a heater kicks on and a boom occurs, it is known as "delayed ignition". Sounds like the alignment of the pilot/ignitor and the main burner(s) is not correct, thus causing the boom at the end of a burning cycle.
Apr 21, 2017 | Heating & Cooling
My TV will not turn on. I just replaced the tv lamp 2 weeks ago. Help!!
did you use original Mits Lamp or a generic?? most mits DLP tvs wont run long or at all with generic lamps
Sep 30, 2012 | Mitsubishi WD-60C9 60" DLP HDTV
My lamp on my Mitsubishi WD65733 DLP TV actually blew up while I was watching it (kablooey). So, I bought a new lamp and replaced it. Now, the picture and sound comes on for about 30 seconds then it turns...
No check for bad capacitors on Power supply board they will be vented swollen or puffed up on top.
Go to Encompass Parts Distribution and look up your Model number.
May 09, 2010 | Mitsubishi WD-65733 65" HDTV
RED LAMP LIGHT!!
Check to make sure your lamp is not blown.
Make sure you installed a Mits original, and not a generic.
Make sure the lamp is seated and secured properly, as slight movement can cause a loss of connection.
Slide your set out to the side and peer into it through the slats. Can you see the lamp fire on?
Your symptom does not indicate that it could be a problem other than the lamp and the installation thereof, however---there is an instance where 2 capacitors will blow on the power supply and cause a red lamp light to show. Furthermore, the light engine itself could be causing the problems.
But, since you just installed the lamp, I would look over your installation.
Apr 09, 2009 | Mitsubishi WD-62531 Projection Television
Mits wd52525 bulb replacement
Good Day Cawhite;
You replaced lamp and still get flashing light.
1. TV's 'ballst may be bad.
2. If lamp comes on for 2-3 seconds, the problem will most likely be the caps in the power supply. (to see lamp turn on you have to take off back or front (inner panel).
Hope this was helpful.
Good luck, Big Irish.
Jun 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Status Light Flashes Red
first did you getthe lamp from miths and if notyou could have bought a bad lamp. you need to get a lamp form mits if you did not buy from them. if you did buy from mits have them replace the lamp it has a 90 day warranty. try hitting the menu and device / input buttons for 5 sec and repost the blink code. it is a 2 digits blink code. (ex. 23 or 33 or 26 like that)
Apr 20, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Replacment lamp
Check your ballast and air filter. I am checking to see if I can get some detailed info on your set. It is a WD52525 correct?
Jan 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mits 62525
take the lamp back out and reset the lamp
Dec 27, 2007 | Mitsubishi WD-62525 62" Rear Projection...
Booming noise
10 years is about life for these, booming noise like a gun shoot?
i would suspect a cap blew up can you open the back and see any burn marks or paper ?
Nov 26, 2007 | Hitachi 50UX26B/27K 50" Rear Projection...
Mitsubishi WD-65733 65" HDTV Logo
139 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
