Question about Campbell Hausfeld MIG / Flux Core Wire Feed Welder
How do i wire the plug for a 230v ac, 21 amp outlet
    Problem Solver:
  • 8 Answers
You will need a outlet location with two 120v legs and a neutral before you can do so. if you do not have this then go to hardware store and get a 240v breaker that will fit your breaker bucket. then wire the two legs and neutral to the location of your choice. i dont know if the plug looks like this one but it should be a 3 prong of some sort. the neutral will be marked and the two legs can go on either side. good luck.how do i wire the - lyonhart_0.jpg
Posted on Mar 13, 2011
Is it possible to wire an eagle model#c5160v1 208/230v so that yoy can run it on a standard 110/120 wall plug outlet
I believe an Electrician can change it in your breaker box, but if your appliance is a 230v, you need to have that amount for that appliance, in that outlet. Best to you!
Nov 22, 2014 | Dryers
AC Power Failure
Providing that you the outlet is putting out proper voltage, check the voltage output of the plug in transformer. Used a voltmeter set to AC and attach the leads under the plug in transformer (where the wire normally go) and plug back into the outlet. The voltmeter should be reading around 9 volts AC. If there is no a low or no reading, you have a bad plug in transformer. It can be replaced with a 9 volt AC 25 volt amp transformer. Battery may also have to be replaced, if it is depleted. If this does not fix the problem, you have a bad panel and it will need to be replaced.
Jul 26, 2012 | GE Security Simon Xt Wireless Control...
Can I plug in a 230V 15 amp window air into my 20 amp wall outlet or is the 20 amp wall outlet not giving me enough volts. if not then how can I do this without wiring up a new circuit/outlet?
The 20 amp would be enough for your AC as the initial current drain will be only when the motor starts ups and will reduce to about half on running.
So provided the AC has no fault of its own the present socket can be used and spcially if the socket quality -- must not heat while the AC is running.
Jun 16, 2011 | Maytag M6W12W7A Air Conditioner
We have just moved my girlfriends hot tub from her old home to her new place. I was intending to just put a plug on the wires and plug it into an external socket at my girlfrienSs new house. However when i...
Depending on if the motor for the tub is 120v or 215/230v follow these instructions....
120v - connect each black wire to it's own spade terminal and the green/yellow wire to the round ground tab on the new plug.
215/230v - follow the same procedure, but when complete, make sure that you are connecting to a 215/230v outlet, if it is a standard 120v outlet, you will most likely blow a fuse, or even worse the motor.
There should be a name plate on the motor that will tell you if the motor is 115v or 215/230v.
If the motor is 120v, you will have one "Line" wire, and the other is "Neutral" In A/C wiring it does not matter which is which due to the fact that the "Line" and "Neutral" alternate there current 60 times a second
If the motor is 215/230v then both the black wires are considered "Line", meaning that they both are carrying current at all times.
Hope this helps
Jul 31, 2010 | Home
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
Hi, the amps would be OK, but you have to have a 230 volt outlet to plug it into, or it will not run. There is no other way to do this unless you run a 230 volt line over to the window unit. You can do this from the outside of the house. This is all you can do unless you move the a/c to where you have a 230 volt plug, and I don't think you want that. This is the only way I am sorry to say.
Sincerely,
Shastalaker7
Jun 12, 2010 | Maytag M6W12W7A Air Conditioner
For a/c unit, is there an adapter available or do I need a new plug cord
Actually you should buy and install an AC wall outlet. An AC uses more amperage than most any other appliance due to the fact it has 2 motors the compressor and the blower / fan motor. An AC wall plug has larger terminals so that the plug does not ever heat. Changing the cord to a different and smaller terminal plug is a bad choice due to the danger of overheating the wall outlet terminals. You can buy the AC horizontal terminal outlets at any hardware store. Unless you have a 110V AC unit you will also have to run a 220V #10 Romex (3 wire) with ground to the outlet to be in code.. An AC unit 1 HP (10,000) BTU or larger requires over 15 Amps for start up. Those that are 20,000 BTU or larger obviously require more than 15 amps as a power source.
Thanks for using FixYa.
Kelly
Jun 01, 2010 | Heating & Cooling
How do I change the electric wire in a franklin ground water pump from 230v to 115v? I purchased a Red Lion 3/4 hp convertible ground water pump but must change the power and wiring from the pumps...
You have 4 wires coming out of the fuse box , one white , one bare, one black, one red, right? The fuse is a double pole, 220 volt, ?30?amp, guessing, and you are now wiring up to a 110 volt, motor which needs 20 amps, so, remove one wire from the breaker, red or black, shut it off first, pull the wire off, tape it and mark it what it was. leave the red wire on there, or the black, it doesn't matter, Now you have one hot, one ground, one neutral, hook them up to the pump, the box on the pump has screws, one silver, one brass, the brass is always hot, the colored wires are always hot, The silver screw is neutral, the white is neutral, always, and the ground wire goes to the ground screw, maybe outside of the box. You should be all set, tape off the old colored wire you didn't use and mark it . You might need it someday. Hope this helps.
May 31, 2010 | Plumbing
APC Smart-UPS RT 1000VA
Hello Dear Specialists I have a problem with the APC Smart-UPS smart 1000VA: when I insert the
power plug in the wall outlet in one ups , indicate the AVR Boost ups regulating low AC voltage, when I measuring the AC city power voltage that is 207v .whey this ups is not working about the AC low voltage? ,but it should be work from (170v ~ 230v) AC input volte.please solve this problem, which element of AVR from the ups is failed or wrong and give me free circuit diagram low & high AVR and charger and inverter circuits. thanks allot
Aug 20, 2008 | APC Smart-UPS 1000VA UPS System
Replaced window unit - new one won't power up (2nd model)
green light comes on when reset, when try to test goes out, power does not come on at all
Aug 09, 2007 | Samsung AW0503B Air Conditioner
Campbell Hausfeld MIG / Flux Core Wire Feed Welder Logo
434 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
