Question about Samsung HL-S5087W DLP TV
Two days ago-My Samsung HLT 5075sx started to make cracking noises then it shut off. I just replaced the lamp 4 months ago so i don't think that is the problem. Yesterday- i tried unplugging it and plugged it back in. It worked and appears the lamp will flicker, then the crackling noise, then the tv will click off and the three lights will blink continuously. Does anyone know what could be wrong??
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Samsung Expert
  • 177 Answers
Hi allenax,
I think cracking noise come from the color wheel, read this solution too:
http://www.fixya.com/support/t8668062-samsung_56_in_dlp_took_power_bump or
http://www.fixya.com/support/t7554644-suamsung_tv_hl_t5675s_blinking_lights.
Thanks.
Posted on Mar 18, 2011
I have a 50 inch DLP samsung and it wont power on after making a lot of noise (I replaced the lamp) worked fine for a few days now the red light and the right side green light is blinking. any sugge
The answers above are correct. It's either the lamp or the color wheel. Testing the lamp is pretty straight forward. Use an Ohm meter to see if the it's filament has continuity. It's unlikely that a good color wheel would fail immediately after changing the lamp. Look to see if some wiring is out of place and rubbing the wheel causing the noise you described. A jammed but otherwise good color wheel would cause the TV to shut down and display an error code.
Sep 12, 2014 | Samsung HL-S5087W DLP TV
Hello, I have a Samsung DLP HLR5667 and it blew a lamp 4 months ago, I replaced the lamp and it worked fine for about 2 months and started shutting off after only running for about 90 seconds. I reset the...
You need to replace your color wheel. This is a very sensitive part and you need to take care when replacing. If you feel comfortable I can walk you through it. If not, I would take it to a authorized service center.
Apr 18, 2011 | Samsung Televison & Video
My Samsung Dlp model hlt5075s was working great with great picture for last 2 years. This afternoon I went to cut it on and it the three lights on the bottom right started blinking(standby, time, and...
The projection lamp life is over.2 years has not been replace projection lamp,tv on daily watches like 4 or 5 hours a day?u need to replaced the projection lamp.
Sep 12, 2010 | Samsung HLT-5075S Television
Tv started to shut off here and there, then the
Hi,samsung has 3 major failures.The 1st one is the lamp, which averages 6000-8000 hrs 2-4 yrs.When it's about to go bad it shuts off and on or image won't come at all.You can find your part here:http://www.discount-merchant.com/SearchResults.asp?Search=BP9601472A Another problem that causes tv to shut off is the ballast,which is the board that powers the lamp.It makes clicking sounds and will cause pic to flicker.The other problem is the color wheel .The color wheel is a rotating disc that has a gamma of colors it spins at high rpms.The light of the lamp goes through it to create the colors on your tv.When it starts to go bad you will get color distortion ,black and white picture and sometimes you will hear humming noises.Have a bless one!
Apr 12, 2010 | Samsung HL-S5086W 50" HDTV
Tv wont stay on
Have you checked the lamp? If the tyv is 3 years old and the lamp has never been replaced,it's time.The crackling noise also sounds like a blown lamp.
May 10, 2009 | Samsung HL-S4266W 42" HDTV
Samsung HLP6163W Problem- TV keeps turning off!
Well, I have had the same exact problem and since my hlp6163w is still under warranty, I had a technician come out to repair it. And...the winner is a bad ballast. The Ballast has also affected the bulb. So, the answer is you need to change the Ballast and the lamp to get the problem resolved. A faulty Ballast will always destroy a a lamp. Sorry for the bad news as this will cost you a total of $400.00 to replace. It sounds like there is a defect in the ballasts that were made for this particular set and a recall should be made. Hope this helps!
Jun 11, 2008 | Televison & Video
Samsung hln4365w - no pic. or sound. it whistles a few times when powered on
We have the same DLP set and had the same problem. The Color Wheel, P/N BP96-00250A, a $200 part needs replacement to eliminate your problem.
May 24, 2008 | Samsung HLN4365W 43" Rear Projection...
Samsung hln567w dlp tv
after 3 years it is a good chance that the lamp is going,,however if it plays its melody when it turns off there is a possibility thateither the lamp door switch or the thermostat are failinf
Nov 28, 2007 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Samsung HL-S5087W DLP TV Logo
115 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
