CPU powers on but monitor shuts off
I would like to take the necessary steps you provided for me buy is there a layout of the motherboard so that i can find the video card for my HP Pavilion 7940 desktop pc?
    Champion:
  • 209 Answers
Time of this report: 3/24/2006, 22:21:35
Machine name: HP-PAVILION7940
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: 00101680 7940
System Model: 15515700051231
BIOS: Version 2.09
Processor: Intel Pentium III, ~1.0GHz
Memory: 254MB RAM
Page File: 139MB used, 294MB available
Windows Dir: C:\WINDOWS.0
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
it seems that your desktop is an asus motherboard. as shown above, that is an AGP. you can buy an AGP video card
Posted on Aug 01, 2008
Monitor Going To Sleep If Powered On
It means your system is not able to Provide Display to your monitor.
You may try the following steps to troubleshoot display problem
Here are the Few steps which you can do by yourself to bring back the display(if your Luck is GOOD:D )
1step-
Open the Case and check if RAM is properly fix.. just take out the RAM, Clean it and fix it back properly.
2step-
search for CMOS battery on the motherboard.. just remove it for 10-20 seconds and fix it back.
3-step
Remove the CPU Fan and CPU and Fix it properly.
It happen when you shift your PC from one place to other.
ALL the best and if it works than please give ranking.
Aug 02, 2012 | Acer Aspire (AST180-US340B) PC Desktop
When i turn on the computer, the fan keeps spinning and making noise and the monitor is black screen. i tried many ways to resolve it but unsuccessful.
If your monitor is black but everything is still spinning, first off if you have opened up your PC check for certain if everything is connected again properly (especially the 4 pin connector near the CPU) and also the cable to the monitor and the monitor's power cable of course.
First of all try to connect your monitor to another device and see if it works. If it does not then your monitor is broken. if it does, let's go to the next step.
If everything is connected properly inside the PC, the odds are very high that your CPU and/or motherboard are broken. If possible try replacing the CPU and motherboard with another one if you have one lying around. If you don't you can either buy a new CPU or motherboard or if you want to take the more simple way, which is actually more recommended, go to your local PC shop and have your PC fixed.
Jul 24, 2011 | HP Compaq Presario SR2030NX PC Desktop
When i plug to the cpu monitor cut off the power and green light is blinc
Do one think just plug out Monitor to CPU cable , just on monitor only if so can you able to see one small icon go top to bottom its like keyboard, if you can see that, you don't have any problem on your monitor.
step 1 - just remove ram slot and insert again try to ON your system now
step 2 - take your cpu and connect to other monitor and check where it getting on or not , if monitor get ON and work good mean you don't have problem with your CPU , problem was in monitor to cpu cable ,so change your monitor cable its just cost of 4 to 5 $.
step 3 - take your monitor connect to another CPU , check weather you getting same problem if it work good mean, your CPU motherboard have problem just call your hardware engr to solve it,
GOOD LUCK ! if your problem solved don't forget to rate
Dec 31, 2010 | Samsung SyncMaster 913V 19" Flat Panel LCD...
"no signal" on monitor, my cpu fan is working fine but beep sound is not coming
Hi
Try this steps:-
1.Please check your power cables properly.
2.Remove the monitor cable from CPU and turn on the monitor and see are you getting the dispaly or not.
Oct 04, 2010 | Intel Motherboard
HOW TO INSTALL MOTHER BOARD
These general instructions are intended to supplement or simplify some of the information in your motherboard manual Step 1 Make sure to read the manual that came with the motherboard - instructions differ for each one.
  • Step 2 Ground yourself with any professional grounding equipment you have. Otherwise, ground yourself by touching the computer power supply.
  • Step 3 Place motherboard on its anti-static bag.
  • Step 4 Configure motherboard: Set jumpers or DIP switches for CPU, voltage(s), and bus speed, if necessary. If your motherboard is configured by software, you will need to configure it after you complete the physical installation.
  • Step 5 Position motherboard in case. Line up holes in board with holes in case.
  • Step 6 Insert spacers, plastic stand-offs, washers and screws, as necessary. Tighten screws carefully, but securely.
  • Step 7 Make sure motherboard is not touching metal anywhere.
  • Step 8 Make sure slots and connectors fit into openings on back of case.
  • Step 9 Connect motherboard to power supply.
  • Step 10 Connect CPU fan, if you have one, to power supply.
  • Step 11 Connect reset and power switches to power supply.
  • Step 12 Connect LED indicators to power supply.
  • Step 13 Connect case speaker to motherboard.
  • Step 14 Check all connections.
  • Step 15 Test motherboard (and configure in CMOS if necessary) before installing other components of computer system.
  • TIPS AND WARNINGS
    • If possible, do installation in an uncarpeted area.
    • Be careful not to touch any chips. Handle board by its edges. Static damage (and even oil damage) may cause a failure months after the incident.
    • If you do not understand these instructions or you lack good manual dexterity, have a qualified technician install the motherboard for you
  • Mar 20, 2010 | Intel D946GZIS Motherboard
    My system start's and after 60 seconds it's shotdown
    hmm sounds like a faulty motherboard first if you know anything about the insides of a computer try unplugging the HDD the ram and the disk drives and if you have a floppy disc drive unplug that as well. basiclyunplug everything exept screen power supply keyboard and CPU if the problem carrys on it looks like youll need a new motherboard
    Sep 25, 2009 | MSI 649 Neo-V Motherboard
    No Power to Motherboard...
    Here are some steps.
    Attach the monitor in your CPU and plug it, see if the monitor powers up. If it did, then no problem in your power supply,
    Detach the RAM or Memory of your CPU and put it back in, in the different slot. and power up your computer.
    Check the cpu power switch if it is correctly attached to the motherboard.
    Oct 26, 2008 | EliteGroup K7SOM (K7SOM W/CPU) Motherboard
    No display on monitor but cpu is running
    The main problem is in the RAM or MEMORY CARD, just detach it and place it back or on another slot beside it.... if this dont work, buy a new memory card. but this usually works
    Oct 26, 2008 | Asrock P4I45GV R5 Motherboard
    Fan error during boot-up
    Power supply, that can be the cause. Did you try disconnecting few devices to check if the CPU fan has enough power to turn itself on. Usually motherboard will have two connectors for the CPU fan, you may try connecting it directly to the power supply. Also Check through the BIOS and see if there is a setting to disable the CPU Fan monitor (Hardware Monitor??) It should be where the temps and voltages are. The BIOS in most computers has an option to monitor a CPU fan. If none exists, then the option needs to be disabled. I am assuming the error is occuring during the BIOS stage of bootup. If the error occurs in Windows, it may be that some software has been installed to monitor a fan that doesn't exist. Sometimes monitoring software comes on the motherboard CD and someone may install it, thinking it is a driver. It is not necessary. Good luck!
    Jan 13, 2006 | HP (D9820-60007) Motherboard
    Computers & Internet Logo
    188 people viewed this question
    David Payne
    David Payne
