Question about kawasaki Garden
I have a Toro Zmaster mower The engine is a FH580V KAI19. It was running fine. Parked the mower last night, tried to start it today and oil is coming out of the OHV cover and blowing by through the muffler. the engine runs for about thirty seconds blowing white smoke and oil out of the muffler. No oil was leaking in the trailer until I tried to start it.
    Sergeant:
    Champion:
  • 271 Answers
You could have a broken piston ring. check the oil level. if it is ok or low and still smokes or hard to start then you may have to overhaul the engine. let me know what you find.
Posted on Mar 13, 2011
Where is the oil drain on a toro zmaster
It should be on the right side of engine when standing behind unit facing front. You should see the oil filter and just below that you'll see a pipe with a plastic end. Turn whichever way it will turn and pull out. it doesn't come off so don't pull or turn hard.
Aug 23, 2014 | Garden
What is causing my kawsaki 580v to smoke
you check the oil with the dipstick resting on the tube, not screwed in
then check your fuel supply as it might have water in it
then remove valve covers and see if you have a valve guide seal that has moved
May 16, 2014 | Kawasaki Engines NEW 19 HP KAWASAKI ENGINE...
I put too much oil in the mower over the past couple months. Two days ago the mower began steaming. I shut it down immediately. Today I did an oil change and cleaned the mower up but after I started it,...
If you already changed oil and it is at proper level on dip stick let it run for about 5 minutes to burn out any excess oil in cylinder, if it continues to smoke you probably blew a gasket or seal on engine.If that is the case you are looking at buying a new mower unless if it under warranty or you have a cheap mechanic.
Aug 30, 2011 | Toro Lawn Mower With Toro Power Tools
My mower started spewing oil and smoking last night. what could be wrong?
That would be a broken compression ring that goes around the piston and keeps the oil in the crankcase...
That will mean a major engine overhall for you...
heatman101
Aug 19, 2010 | Toro Lawn Mower With Toro Power Tools
My mower starts and runs until the engine get hot.
the only way to test i think is with a known good coil or resistance check. also possible you need to check valve clearances
Apr 25, 2017 | Toro Lawn Mower With Toro Power Tools
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
The lawn mower is burning oil and engine is missing.
Sounds like you may have broke the ring around the piston. I wouldn't run it again until you get it fixed. You could cause serious damage, if you haven't already. GOOD LUCK!
Jim
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
433 people viewed this question
Top kawasaki Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
Phil Walker
Phil Walker
Are you a kawasaki Garden Expert? Answer questions, earn points and help others
