Question about Mitsubishi VS-50603 50" Rear Projection Television
How to get TV Guide plus to stop installing, have no remote and I don't see a home button on the TV.Cancel button does nothing.What do we do?
I am having this same problem... Any solutions??
Posted on Jun 15, 2011
Guide plus issue
bestbuy has universial tv remotes.
Mar 21, 2012 | Mitsubishi CS-36509 TV
How can I turn off the guide plus option, I'm want to use my cable remote, when I? turn on the TV with the new remote the guide plus comes up and I have to clear ir with the original remote
You should be able to unplug the TV and let it sit for a few minutes and when you plug it back up and it wants to go through the setup cancel out of it.
Jan 08, 2010 | RCA F32648 32" TV
How do i stop the tv guide plus from loading?
when this has happened to me in the past; if I remember correctly I hit home, stop, cancel, etc any of those gets it to send me the banner that if I stop now......it is not going to CANCEL loading!!! I'm thinking YEAH!!! and then I select the prompt to cancel. I then hit menu again, to cancel and I believe I select home...Now perhaps you think I SOUND a bit "iffy" it would be true; seeing how it has been at least 3 months since it has happened and I sure not going to go and hit that ****** to walk you thru it(he he) sorry but I know you know how it is!!! GOOD LUCK DON'T GIVE UP AND DO YOUR BEST TO NEVER HIT THAT TVGUIDE+ AGAIN (i have many times and its always a pain in my brain)
now get her done!
Mar 02, 2009 | Mitsubishi VS-50603 50" Rear Projection...
I can not get my tv to work with dish network
The RCA guide will not work with the dish remote. You can get the guide to close if you press the White TV button then press cancel. Remember to press the SAT button after you close the guide.
Nov 19, 2008 | RCA 32F531T 32" TV
Help me remove the Guide Plus Grid on my RCA television
Simply enter 00000 for the zip code and complete the set up process; if you're in Canada, select the USA as your country and use the zip. However, you MUST complete the set up, including allowing the TV to search for appropriate code. In the long scheme of things, location and codes don't really matter because you won't see the GUIDE again.
Mar 08, 2008 | Televison & Video
RCA TV f27422 TURN OFF THE GUIDE PLUS
Hello, I have had my TV for 3-4 years and have dealt with this stupid guide popping up for the last 2 when I got curious to see if it was something I wanted to use. FINALLY I came across a solution - so far so good but tomorrow it could be back? I did not have the option field some suggested to use. So saw another suggestion for something else and so far so good. When going into the setup guide. Select the USA, place all 0's in the zip code area and NO for everything else.... no VCR no cable, etc.
Hope this helps..
I also was able to do this without the remote - IF you can get the menu to pop up you just have to use the numbers to select what you need. Found the remote and saw nothing different as far as menu options. Good luck.
Jan 17, 2008 | RCA F27442 27" TV
Autoprograming
get the original remote.....i had to. it costs $95 thru best buy(special order it takes 5 days)
Sep 15, 2007 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi CS-32509 TV
Unplug the TV for 4 hours or more. This is called a 'Hard Reset'. Then plug it back in, turn it on and let the TV do it's thing. It will set itself up. Just follow the TV setup prompts. Guide Plus is a feature on the TV. Much like a TV guide showing all channels, shows, description of shows, times, etc..
Jun 30, 2007 | Mitsubishi CS-32509 TV
Guide Plus Demo
I have serviced lots of these, and as far as I know the CTC203 chassis has nothing like this, nor did anything made by Thomson before or since, so I am mystified. Adjustments are made with the remote or the front panel buttons using software and there are no "pins," test connectors, switches, or anything similar present on it. Usually the Guide Plus stops working entirely (which is nice for most users, as it is just an annoyance). Now if you unplug your TV for long enough for its microprocessor to reset, it will start with the Guide Plus screen. This is by design and can't be stopped without modification. Corruption of the set's internal program causing something strange like this is possible, but unlikely. (It was a problem on earlier models). Leave your TV plugged in and see if this problem goes away. If this is not the cause, you will have to take it in for service. Any demo modes can be turned on or off with the remote or the buttons on the set.
Feb 24, 2007 | RCA F27649 27" TV
Have a problem with mits. vs-55601
The cancel button on the Base unit doesn't seem to work for this, you have to use the "Cancel" Button on the remote. Once you hit "Cancel" on the remote, the scan should exit, and then the buttons on the base unit should work again (barring any other issues). You should also be able to allow the scan to finish (takes a while especially if no signal on the channels), and when it's done it will exit. Hope that helps. Buzz
Aug 20, 2006 | Mitsubishi VS-55601 55" Rear Projection...
Televison & Video Logo
74 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
