Question about LG 24 in. LD-12BW5 Free-standing Dishwasher
Dishwasher is working fine however at the completion of the cycle and when it sits idle it seems to be flooding from under the filter area.Flooding is slow however but causes headaches when it breaches bottom door seals approx 40mm in bottom of unit over 12 hr period. Thanks Lindsay
  • 291 Answers
Your water fill valve is slowly leaking water into your dishwasher. Your need to turn off the house water valve, to your dishwasher, and see if the problem stops. If it does then replace the dishwasher water fill valve. If it doesn't stop, then you have water coming in through your drain lines, which is highly unlikely. You will have to check to make sure your drain line has a high loop in it, or install an air gap. Good luck, Appliance Specialists
Posted on Mar 13, 2011
Problem with restarting after sitting for half hour.
ever get a tuneup this decade?
is it flooding,
the operators guide says, crank wide open throttle to clear floods
does that work? y/n
if NO check for lost SPARK when it DONT start.
bingo?
if spark is good and not flooding does starter test fuel start engine.
for 3second, not at all , or runs. now.//??
this works on all cars. otto cycle.
Jul 24, 2014 | 1999 Suzuki Vitara
Bosch SMU50E15AU PROBLEM WITH FLOODING Does the
If dishwasher is flooding it is because the water inlet valve is not closing properly. Often they get stuck - you can replace the valve or take it apart and subject it to numerous on/off cycles after using wd 40 . That will loosen it up and save you some bucks!!!!!!!!!!!!!!!!!!!!!!!!!
Sep 04, 2017 | Dishwashers
My Kenmore 800 series washer leaks from under the front left during the spin cycle. I looked behind it and checked the connections but all seems fine in that area. What could be causing this?
Same problem! Flooded the laundry room and about 1/4 of the basement. Happens randomly, not every load. Checked all hoses, they are snug and don't appear to be leaking at all. During the wash cycle it you can hear it spraying water inside the washer and the floor starts flooding. I bought the washer Sept. 19, 2009 and have had this problem for about 5 weeks now. Sears refuses to do anything about it, because it's no longer under warranty.
Aug 07, 2010 | Kenmore Washing Machines
Dishwasher turns on but nothng happens.
drain pump blocked and has overfilled flooding base pan and activating anti flood device tip machine to the left to remove water and consult handbook on how to clean pump outlet.
May 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Water leaking from the bottom of the dishwasher.
ck the float it may be comming under the door . if water is still in tank after cycle / clean the screen in the bottom it is a lift out basket . ck for resstriction in drain line . all of thes will cause over fill and flooding . your model may have a pressure sw . sometimes food gets in the air line / remove tube and blow out .. mm
Dec 02, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwasher pump keeps running
This is caused by a water leak into the base pan,it will trigger the anti flood and the machine will continously drain out even with the door open,you need to establish what is leaking,if you leave the appliance standing for a few days it will start again as the water will evaporate however if the fault returns you will definetly have aleak on the appliance which will require further investigation.
Jul 29, 2009 | Neff 24 in. S5443X2 Built-in Dishwasher
I have a craftsman 25 cc string trimmer with fuel problems. After winter, ran tank of good fuel through it and it worked fine. Added fuel (unknowingly with water in it) and it ran on a slow idle and...
You shouldn't notice a difference if you remove the air filter. So I would replace it. Also if you are using compressed air to clean or blow-out the carb. Be careful, its not recommended and could make it worse.
May 14, 2009 | Craftsman 25cc Gas Line Trimmer
Dishwasher flooding
When you say that you tried other solutions.. it's hard to know which you've tried and which you haven't so I will suggest some basics first.. ( if you've tried them, then disregard)...
Have you checked or addressed the following:
  1. Cleaned the drain filter
  2. Checked the drain hose for crimps or restrictions
  3. Sure the drain system ( such as your feed thru the garbage disposal isn't clogged or restricting flow)
  4. Checked your water pump for an obstruction or you can determinbe if it is actually pumping
  5. The feed and returm hose ..to anf from the pump are not clogged, pinched or restricting flow.
These are the basics that you should have examined or confirmed aren't causing the problems you are seeing. One other as well.. are you sure your water inlet valve is completely shutting water from leaking in and over-filling the system? Check these items and you should be able to diagnose where the problem is.. Hope this helps you,
Sep 21, 2008 | Asko D1716 Built-in Dishwasher
My dishwasher is leaking water out of the bottom. Please help.
I do not recommend using dishwasher tablets, they get stuck in the sump and cause flooding.
Also try cleaning the filter in the bottom, under the basket. If it is full of food it can cause flooding.
Jun 10, 2008 | Dishwashers
LG 24 in. LD-12BW5 Free-standing Dishwasher Logo
274 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
