Question about Garden
Iam looking for owners manual for a miller 625 plasma cutter.
    Problem Solver:
  • 12 Answers
Http://www.millerwelds.com/products/plasma/
Posted on Mar 13, 2011
Has cup fault
Check connections on holder and at the main unit. blow out the unit with air to eliminate conductive dust as being a problem. Also make sure cup seating area is clean.
Jan 11, 2012 | Spectrum Miller 625 Xtreme Plasma Cutter...
Miller plasma cutter spectrum 625
make sure your air pressure is high enough and volume does not drop below minimum.
Nov 27, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I have a Miller Spectrum 625. The problem I am having is that after cutting for three seconds the torch quits cutting. Have had it looked at a Miller repair center. They said they cut with it for over...
Hi:
I found similar problem with few customers and one issue (should I said the standard issue) is the source of air. You need a steady pressure and flow of air into the machine. Check your air compressor you will need at least 6 cubic feet per minute (360 cubic feet per hour) and a 90 psi of pressure. Since there is no way to check the flow (unless you have an online flow meter at you air pipe) check the pressure at your air tank (reservoir), if the pressure drops below the 70 PSI then that's the problem; your compressor can't stand the flow. Other than that check your ground clamp and make sure it's making a good contact.
Good Luck.
Sep 15, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Hola buen dia necesito que alguien me ayude respecto a una pza de la targeta electronica de la maquina spectrum 625 numero de parte es el siguiente IOR CO621V SA55BA60 . la pza que necesito...
Hola Erick:
Yo te puedo ayudar a conseguirla. Checa el link del diagrama de partes y dime que numero de parte es de acuerdo al diagrama.
http://www.millerwelds.com/om/t2239c_pt_mil.pdf
El numero que pones es el numero de la tarjeta y no lo puedo localizar. asi.
saludos.
Jun 13, 2011 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Cant get it to arc or blow?
cant get the plasma to give me a continous arc
Mar 17, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I can cut for about 4 min. then Cup Error
look at your duty cycle 40 % duty cycle is 4 min 10 min sraight is minimum 100%, but good machines weld for 3 or 4 shifts till they get turned off
my 2 cents
Feb 25, 2010 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
I bought a used miller spectrum 625, can put on
The consumables on the torch head could be incorrect or not installed correctly. check these.
Sep 28, 2009 | Miller SPECTRUM 625 SPECTRUM PLASMA CUTTER...
Operator instructions
When all else fails, Read your owners manual.
Miller has a good site. millerwelds.com
Look up Miller Plazcut, the pdf contains instructions on how to use your cutter.
Apr 11, 2009 | Welding Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
