Question about Asko T721 Electric Dryer
How do you remove the front panel of a Asko T721 dryer. I want to replace the belt, but I see no screws for the top part of the front panel (I removed the bottoms ones with no problem).
    President:
  • 3,074 Answers
Http://www.ehow.com/how_6899980_replace-asko-dryer-belt.html
Posted on Mar 13, 2011
How do i remove the front panel of the asko t721 to replace a broken belt?
REMOVING THE FRONT PANEL
1. Remove the top cover.
2. Remove the lower cover.
3. Remove the door.
4. Remove the front drum frame.
5. Remove the four screws that secure the front panel to the side panels.
6. Remove the two screw that secure the bottom edge of the front panel.
7. Lift off the front panel.
_____________________________________________________
REMOVING THE TOP COVER
1. Remove the three T20 screws at the rear of the
top cover. (Keep the two star washers.)
2. Tilt the cover and pull it backwards.
REMOVING THE LOWER COVER
1. Remove the two 20 torx screws (A) at the
bottom of the lower cover.
2. Next, grasp the sides and pull it forward and
down.
25764946-gtkp3url2ghtdqenstp5bokb-1-2.jpg REMOVING THE FRONT DRUM FRAME
1. Remove the motor (see page 34).
2. T700/760: Remove the exhaust vent by
twisting it free.
3. Remove the wire bundle from the cable clamps
on the front drum frame.
4. Remove the fan housing cover (see page 33).
5. Using flat-nose pliers, take out the thermistor.
6. Open the front door.
7. Unscrew the four screws that secure the drum
frame to the front panel.
8. Lift out the drum frame.
REMOVING THE DOOR
Note : The front door must remain closed during the entire removal procedure (The door magnet will hold it
in place.)
1. Remove the lower cover (see page 24).
2. Unscrew and remove the three screws that secure
the hinge fixture.
3. Lift down the front door.
Dado
Jun 29, 2015 | Asko Dryers
Asko T702C Service Manual
That is a pretty easy fix without the manual. Take off the top by removing screws on the back top. Remove the sheet metal screws around the perimeter of the the back panel. Pull the drum off the front enough to drop the belt in front of the drum. Put the back panel back on. Now you can thread the belt back into place. The belt runs with the ridges on the spindle of the motor and on the smooth side on the tensioner.
You should replace the pulley idler when replacing the belt, also. I learned this the hard way and snapped a 5 month old belt.
Jan 19, 2014 | Asko Dryers
Asko T721 dryer. Support rollers started to fall to bits (dryer making bumping sound as it rotated) so I bought a new set and replaced them. Not a single electrical connection was removed bar the door...
  • If you took the drum out and took the belt off you may have put the belt on wrong as there is a switch under the drive or idler pulley that must be pushed on from the pressure of the belt on the pulley. Also go and make sure both breakers are ok in the breaker box as it runs on a 220 volt sys. and if one is tripped this type of thing can occur.
  • Good luck and please rate me if this helped! thanks again for choosing fixya
Oct 12, 2010 | Asko T721 Electric Dryer
The drying turns on, but does not spin
Welcome to FixYa.
Sounds like it has a broken belt based on your description of your Asko dryer "The drying turns on, but does not spin".
You can visually inspect it be either removing the lower access panel or the dryer top panel, the choice is yours and either way will let you check the belt.
To go infrom the top remove the screws at the back of the top, they will be three #25 torx head screws.
Once the screws are out, slide the top towards the back slightly and lift up. You should then see something like this...
Oct 01, 2010 | Asko T761 Electric Dryer
Belt/Drum Noise
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Jun 15, 2009 | Asko T761 Electric Dryer
Asko Dryer won't spin...need to tighten belt
Does the Motor turn... We have had many motors with bad capacitors .. check the white capacitors for cracks or metal coming out of it...the motors will run with out a load on the but put a few clothes in the drum and they will just hummm..
Jul 19, 2008 | Asko T721 Electric Dryer
ASKO T721 dryer - Squeaking
the dryer needs a service you need to replace the front rollers,jockey pulley and grease the jockey pin,check or replace the belt.remove the lint build up from the front frame and element assy.also check that the felt and rubber seal arond the front frame hasnt come out.you can replace it but its hard to get in and you may have to replace the front frame.i find its any easy repair but i see a lot of asko dryers (not because there bad they just need a service about every 5-7 years).hope this helps.
Mar 17, 2008 | Asko T721 Electric Dryer
Asko T700 loose belt, access from front?
I think you must replace the belt and the tensionarm. It MUST be done from the backside of the machine... Remove the backpanel, and the drum, change the tensionarm, and put the drum into the machine again. Put on the new belt, and mount it together again. Be careful for sharp edges! Hope this helps :-)
Jan 12, 2008 | Asko T700 Electric Commercial Dryer
Asko T721 Electric Dryer Logo
433 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
