Question about Philips Magnavox 20MS3442 20" TV
Hi, I have a philips tv model C122 mr2048, worked well but disconnected, to reconnect only demo screen appears and I can not do anything with the buttons and the remote control, as I can remove the demo and return to normal my tv? thanks
SOURCE:
rey jr
  • 149 Answers
SOURCE: philips magnavox model 25ts54 c122.
hi there, you do have a power supply section problem, check the bleeder resistor which is 100K ohms or up. do some test. ty
Posted on Dec 26, 2007
SOURCE: Philips tv turns on by itself and is stuck in demo mode
Change the eeprom
Posted on Mar 17, 2008
SOURCE: Philips model HD2528-C122 value for capacitor C506?
I could still make out 68 over 2kv on the burnt capacitor. Replaced with a 680 pf 2kv that I bought at a local TV repair shop. works great.
Posted on May 29, 2008
  • 2337 Answers
SOURCE: Magnavox TR2510C101
Pressing the volume up and volume
down buttons on the set simultaneously should work.
Good Luck.
Posted on Aug 01, 2008
techjuli
  • 157 Answers
SOURCE: TV seems to be in some kind of sales demo mode
To disable the Demo mode, perform the following:
  1. Turn GA_googleFillSlot("TL-IMU-Article"); on the TV.
  2. Simultaneously hold down the Vol+ and Vol- buttons on the front of the TV. Do not use the remote control.
  3. Hold for about 6 seconds
  4. Certain model TVs may turn off, others will not. But in either case, the Demo mode should be disabled.
Posted on Nov 30, 2008
Philips DVDR7260h
Hello
Disconnect the recorder from power outlet for one minute and reconnect it again. If the recorder still don't operate well, you have to reset it to factory default settings.* Disconnect the recorder from the power outlet. * Press and Hold down the STANDBY/ON button on the front of the recorder whilereconnecting it into the power outlet. * Release the STANDBY/ON button when STARTING appears on the display. * Wait until the recorder's demo starts scrolling; press STANDBY/ON button again to turn ON the recorder. [All information stored in its memory will be erased. The first installation menu will be appeard on the TV screen. OK.
Feb 02, 2012 | Philips Televison & Video
Magnavox Demo TV
Could you please provide the model number of your TV?
It appears that the TV demo was activated by accident.
Jul 23, 2008 | Philips Magnavox 27MS343S 27" TV
PHILIPS MAGNAVOX MODEL 19PR15 C122 HAS NO SOUND
Check speaker. Audio circuit. Mute signal
Apr 01, 2010 | Televison & Video
Television won't turn on
Sounds like a power supply problem, you'll have to take it to a repair shop to fix that unless you know electronics. Good luck.
Nov 15, 2008 | Philips Magnavox 27MS343S 27" TV
May 27, 2008 | Televison & Video
Philips tv demo
Try holding the volume up and channel down buttons on the set at the same time. Give me the model # if that doesn't work.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
TV Volume goes up when channel is changed Philips 20S240
I don't think the IR sensor has anything to do with it. It sounds like a surface mount micro processor to me...
Jan 02, 2008 | Philips Magnavox 27MS343S 27" TV
Philips magnavox model 25ts54 c122.
Dec 24, 2007 | Philips Magnavox 27MS343S 27" TV
Screen is black
on that tv you have to check just for circuit of high voltage - check
transistor near flyback transformer - delfo
Dec 11, 2007 | Philips Magnavox 27MS343S 27" TV
Tv won't stay on!
Replace C506.......680PF / 2KV..........................+ solder any
and all bad connects......+ replace 47mf/25v cap in horiz drive circuit................T.
Nov 26, 2007 | Philips Smart 25TS54C 25" TV
Philips Magnavox 20MS3442 20" TV Logo
52 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
