Question about Refrigerators
I have a Westinghouse frostfree rj25m upright fridge/freezer. The freezer is working fine but the refrigerator won't cool. I want to fix it myself as it is an old fridge and really not worth spending $300 with a repair man.
    President:
  • 670 Answers
I am not sure if your freezer is working correctly if the fridge compartment is not at the right temperature. The way refrigerators work is that the fridge compartment is indirectly cooled by the freezer. The evaporator coils that cool the freezer, also cool the refrigerator. There is a fan in the freezer section that draws air from the refrigerator and blow them over the coils. The vent to the refrigerator could be blocked by debris or ice build up if the defrost circuit has failed. In order to check, you need to remove the back panel from the freezer section to check the condition of the coils/vent. Also check the fan in the freezer and see if it is operating. If the coil is encased in ice, then the defrost circuit has failed and that needs to be fixed otherwise the freezer will not cool to the correct temperature.
The way the defrost circuit worksis that normally the compressor has power for 8 hours, then the timer cuts power off and sends power to the defrost heater for about 45 minutes. The heater is attached to the coil and warms up the coil to melt the ice. When the coil reaches about 40 deg F, the thermostat which is in series with the heater, opens up cutting off power to the heater. This prevents the freezer from getting too hot. After the 45 minutes are up, the timer switches the power back to the compressor again to restart the 8 hour cooling cycle.
Any of the three components can fail causing you not to get the defrost cycle to work. Typically the timer stops advancing so you either stay in permanent cooling or defrost mode. Or the heater burns out so it can
Posted on Mar 13, 2011
Testimonial: "didnt know where to start at first, but this was enough info to help me out and fix the fridge. thanks."
  • Shelley Humphries Mar 13, 2011
    I have a Kenmore model# 253.73754300. The problem I'm having is the freezer works but when it goes into the heater/defrost mode, it won't shut off the heater . The freezer compartment will get completely warm nearly hot, defrost everything and then after a while the cooling system will restart to freeze again. It will then work normal until the next cycle when it happens again.Would the problem be the thermostat or timer switch?
  • Stephen Lam Mar 14, 2011
    Hi voodoolady24,
    When the fridge is in defrost mode, the heater should never go beyond about 40 deg F. If everything is melting in the freezer during defrost, the problem is with the defrost thermostat. It looks like a round cylinder that is connected in series with the heater. Its job is to cut the power to the defrost heater when it senses the coil has reached 40 deg F to prevent the heater from over heating the freezer. Have the defrost thermostat replaced. It should be available at your local appliance repair house or online such as repairclinic.com. Hope this helps you.
Fridge won't cool but freezer working fine
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 31, 2011 | Refrigerators
Frigidaire upright frostfree freezer keeps icing up, needing to be defrosted. whats wrong with it?
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 05, 2011 | Frigidaire 20.3 cu. ft. Upright Freezer...
My westinghouse refrigerator has stoped working but my freezer is working fine help. Model Bj513V Serial Number 72656346
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 18, 2010 | Westinghouse Microwave Ovens
Freezer working refrigerator warm
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 03, 2009 | Whirlpool ET4WSKXS Top Freezer...
Red alarm light is on on Westinghouse upright freezer
Most probably during transportation either the coolant(previously freon gas) may have leaked out so the pressure on the cooling pipeline causing the red alarm because the compressor will overheat if the fridge is kept running at very cold thermostat readings and no effect of cooling the fridge will ultimately result in the compressor getting burnt. However fist have look at thermostat setting knob which could have loosened during transportation and just pushed into the spindle without knowing the correct angle, thus even though it looks as if on high cool but could also be the lowest setting..........sodeep
May 19, 2009 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
GE Profile - Fridge Doesn't Cool But Freezer Works Fine
Had a similar problem with my Kenwood Fridge Freezer
If you're mechanically minded you could check if there's an opening and motorised flap (usually behind a cover) at the top of the fridge - Cold air from the freezer enters the fridge through this flap) The Sound you heard could have been the motor trying to open / close this flap. This flap can become frozen in the closed position - so cold air is unable to enter the fridge compartment) My fix was to thaw it with a hairdryer and reassemble. Another fix would be to empty the freezer and open the doors - it might take more than 24 hours but once completely defrosted if the flap is the issue it will have defrosted. Once plugged in again the door will open and cold air will start to flow into the fridge compartment. I had a quote for €195 for a call out / repair
I fixed it myself in an hour - Hope it works for you ...
Sep 20, 2017 | GE Profile PDS22MHR Bottom Freezer...
Fridge on Fridge freezer not working
Ok there is a drain pan under the evap. coil under the fan that may be clogged and full of ice there is a 3/4" hole the water drains out of that needs cleared if there is a puddle of ice over it , the ice will also effect the airflow traveling down the duct to the fresh food section of the unit.
If there is no ice puddle at the bottom of the refrigerator then make sure the unit is cooling well by making sure it has been running for 10 min. or so and checking the coil in the freezer , it should have a small layer of frost on it showing its getting cold the whole way through it. Let me know how this works.
Phil
Jan 02, 2009 | Zanussi ZI921 / 8FF Bottom Freezer...
Whirlpool Frig
Is that everything in your freezer or just in the fridge. Is this a frostfree model. Often if defrost fails in a frost free model then it is unable to duct cold air to the refrigerator side of things. To fix- turn it off for a day or two.
Mar 16, 2008 | Refrigerators
Refrigerators Logo
244 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
