Question about HP Photosmart C6180 All-In-One InkJet Printer
I attached my hp C6180 printer to my cpu, turn the power button on ,but the light kep blinking. please help.
  • 100 Answers
This same error started occurring on my printer and eventually it would constantly power on and off. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers.
Posted on Mar 28, 2011
Hello. i have the hp Photosmart C6150 printer. for
Press the button on the printer, to turn the printer off.
Then, press the switch on the power-bar, to completely cut the power to the printer.
Turn the power-bar on.
Turn the printer on.
Jul 06, 2010 | HP Photosmart C6180 All-In-One InkJet...
Led lite on power module turns on but when you plug the module into printer it goes off and printer won't tunr on hp c6180
Check the logic board for failed capacitors. My C6180 started showing ink system failure messages and eventually would power on and off every 20 seconds or so. This was caused by a few failed capacitors on the logic board. i the attached picture of my C6180 logic board you can see the bulging tops of 2 capacitors (indicating failure). I replaced 4 capacitors (cost ~ 60cents) and the pinter is working great. If you are not comfortable doing a little soldering, you will have to find some help (took my 25 minutes).
Jun 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
HP a1050y no power I tried all suggestions posted, and everything
Try Unpluging the power supply and press and hold the power button for about ten secs - leave it off for about two min and plug it back in and turn the computer on.
see if that work,
Thanks
Mar 31, 2010 | HP Pavilion A1050y (PU131AV) PC Desktop
How do i reboot my hp c6180 printer
This seems to works for me and doesn't appear on the HP support site nor in the manual...
1. Power down the printer (use on/off button) and remove power cable. Wait 2 minutes.
2. Hold down Help and OK buttons together while plugging in the power cable.
3. I held the buttons for around 5 seconds and when I released them, the printer seemed to go back to a hard reset - all sorted!
Hope this helps!
R
Jan 22, 2010 | HP Photosmart C6180 All-In-One InkJet...
Cannons450 paper jam- removed paper but yellow light keps flashing and nothing prints
At the printer icon cancel/delete all print jobs.
Turn it off by unplug the power cable, and the then turn it on.
If its still blinking, push once the on/off button or if there is any paper feed button
Sep 06, 2009 | Canon Office Equipment & Supplies
HP C6180 won't turn on
To begin with, try resetting it by following these instructions. If you are using a usb cable, unplug it as well and wait at least a few minutes before reconnecting.
See also here and here. (different) It's possible you have too many devices plugged in and the printer is starved for power, or it's somehow grounding out.
If that doesn't solve the problem, you may find alternative solutions here. or here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jun 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
My photosmart hp C6180 keeps saying printer alignment failed and it will not print anything with black ink. I have replaced the black cartridge 3 times. What do I do? It will print all the other colors...
C6180 reset:
Perform a semi-full reset to set all user menu settings, telephony parameter settings, country/region and language UI, fax memory settings, fax journal information, speed dial and broadcast lists, personal header information, and junk fax settings to the default settings. Performing a semi-full reset of the All-in-One
  1. Use the On button to turn on the product.
  2. Remove the power cord from the product.
  3. Press and hold the # and 6 buttons.
  4. While holding the buttons down, connect the power cord to the product.
  5. Continue to hold the buttons down until the color graphics display becomes blank, then release the buttons.
  6. Use the On button to turn on the product. The reset information appears on the color graphics display.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01457329&cc=us&lc=en&dlc=en&product=1153494
Or a Full reset:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00720248&cc=us&lc=en&dlc=en&product=1153494
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Jun 12, 2009 | HP Photosmart C6180 All-In-One InkJet...
MY HP PHOTOSMART C3100 ALL-IN-ONE SERIES {BLINKING BUTTONS}
Hi
Please see this link for details on resolving the blinking light issue on your HP C3100 Printer---
C3100 Blinking Lights
Please do rate this solution as FixYa if found helpful and revert for further assistance.
Thanks
Rylee
Apr 29, 2009 | HP Office Equipment & Supplies
HP C6180
unplug the printer and then plug it back in. turn it on and Hold the 6 and # button until the printer shuts off, this should do a hard reset
Apr 02, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
Seeker5211
Seeker5211
