Question about Car Audio & Video
Bought 2005 *** a used vehicle. factory nav. does knot turn on.Purchased a used cd,turns out 2 b older 2003. System says so
  • 643 Answers
Not sure i understand your question, could you please clarify?
Posted on Mar 13, 2011
Radio/nav screen won't turn on
Its not reading the disk which means it has a internal fault so remove the radio and seek profession advice
Nov 29, 2013 | 2005 Maserati Quattroporte
I purchased a 2002 Range Rover Borrego recently.
I have experienced many electical demons with all my British cars. The nav units can and do fail. I had a goofy one this summer and the only way it got fixed was to replace it. The module not the head unit
Mar 24, 2010 | 2002 Land Rover Range Rover
How to install a cd/radio in a 2003 Pontiac Sunfire Went to Future Shop, they have the player, but i would have to buy hundreds of dollars of wiring because of the computer system in this year of vehicle....
The 2003 sunfire does, in fact, need extra wiring!
You'll need a mounting kit $20-$30 (required for all radios)
Wiring adapter harness required because of OnStar/Factory Amplifier/Navigation etc will run approximately $140 for the most expensive one.
Depending on the factory installed equipment (nav/onstar/amplifier) will determine which wiring harness you require.(1 of 4 available for this yr/make/model)
A normal standard wiring harness runs about $15 and looks like this....
Yours will look more like this one....
There is no way around the cost - as the other electronics in the vehicle are dependent on it.
THanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 30, 2009 | Pioneer DEH-P2900MP CD Receiver...
Garmin sat nav wont turn on
Maybe this will help you?, I am giving you the link to the whole manual in detail that you can download in PDF.... This will tell you everything about your unit and trouble shooting and company contact numbers. I hope this helps if so, please rate my free help and some kind words would be nice in the comment section. Respectfully, Mike
Here is the Link>>
http://www8.garmin.com/manuals/2675_OwnersManual.pdf
Dec 12, 2009 | Garmin Nuvi 205T Sat Nav GPS Receiver
I was told that 2006 dts had either onstar or radio/dvd/cd/gps system not both i spent over three hundred dollars at gm dealer for hm to diagnose this and that even though my dvd nav is factory it will...
ok this is what I just found concerning your issue.
Now this is just the beginning so Im sending this complete in sections for you.
  • Turn ON the ignition. The Cadillac emblem screen appears on the navigation radio.
  • Press the POWER/VOLUME button on the radio.
  • When the navigation disclaimer screen appears, press the I AGREE button on the display.
  • Press the NAV button on the radio. The display should show the current position of the vehicle. The navigation map should be clear and have clear color.
  • Press the voice switch on the steering wheel. Speak a valid voice command. The system should repeat your command and then perform the function.
  • Does the system operate normally?
  • Nov 10, 2009 | Car Audio & Video
    2005 Volvo CX 90 DVD Player will not turn on.
    Hello Sorry if this seems an obvious solution, I think if you put your sat nav DVD in the rear DVD player it will recognise it and operate - only use audio CD's in the front. Hope that solves problem, sorry if not.
    Peter
    Apr 06, 2009 | 2005 Volvo XC90
    Missing operating instructions / manual for Honda Sat Nav system
    did any of you find one? i have just bought a SECOND HAND 2004 CRV but no sat nav manual - nothing on the net- any help appreciated.
    Jan 12, 2009 | 2004 Honda CR-V
    Peugeot 406 factory fitted sat nav
    If you have the factory fitted nav then this is an integrated system and you will need to get the clarion repaired. If you give me a call I can advise you how to arrange to have the unit repaired 0161 428 2020
    Dec 18, 2007 | Car Audio & Video
    Dodge RB4 GPS system
    Sounds like the J1850 bus is not connected to the RB4 radio.The speed sensor info is received thru the bus which alows the nav to function and calibrate itself.Or as I have mentioned before, there may be problems on the NAV pcb.There have been many issues with the nav pcb assy.
    Jun 23, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
    Gps is not working
    I know the is a old post but i will provide some answers to the question.
    1 the radio has to be connected to J1850 bus to talk with the sensors in the vehicle
    2 check nav ant for broken wire.
    3 check nav ant socket (center pin) should have no less than 4.95 volts DC with radio on.
    4 Problem more than likely on nav PCB .
    I have run across MANY problems on the nav pcb.
    May 23, 2007 | Dakota Dodge RB4 Navigation, CD, AM/FM,...
    Car Audio & Video Logo
    13 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
