Question about Garden
I need a chain 20 .325-78 - Garden
  • 95 Answers
Ereplacementparts.com or jackssmallengine.com
Posted on Mar 13, 2011
A year ago i had the chain replace now the chain is very lose when i change my gears it pulls then goes
Hi, Diane whenever you replace the chain a new one will stretch a lot the first 2 or 3 hundred miles and needs to readjusted after that you need to check adjustment every 1000 miles fork over the extra bucks and get an o-ring chain with regular maintenance (o-ring chain oil) it will last 3 times longer than a regular chain for more information about your question and valuable free downloads that you will need please visit the websites below. Good luck and have a nice day.
03 The Riders Edge How to clean adjust and lube your chain HD ring bike chain critical maintenance
How to instal an ring chain
How To Use Motorcycle Chain Breaker Tool
Mar 02, 2016 | Goes Motorcycles
What size chain do i need for this bike
Why don't you just take off the old chain and take it with you to the bike store, since you have to return your new chain anyway and buy a new one. You don't even need to know the size, because they will match the old chain with the new chain. No guesswork required.
May 10, 2014 | Jamis Durango 2.0
I have a Poulan 295. I needed to replace the chain. It is a 20" chain. There is bar oil in the resevoir. The chain will not stay on the bar (it seems loose even when fully tightened). I replaced...
If you replaced the bar AND the chain, you'll need to make sure the chain is the correct chain for the particular bar you've used. If you're only replacing the chain, you need to make sure the chain has the same # of drive links as your old chain (maybe one or two more, if you've had some removed because of chain stretch).
On that particular model, for a 20" chain, you could have a 78 OR 80 drive link chain (drive links being the part of the chain that rides in the groove of the bar). The correct drive link count is determined by the bar you've installed and should have been made clear by whoever you purchased the bar from. Some brands use an 80 drive link chain, but MOST use the 78 drive link chain.
If the bar you purchased uses the 78 drive link chain, but you have an 80 drive link chain, then no matter how far out you adjust the bar, you may not get the chain tight enough. PartsBuggy shows a listing of which bars use the 78 drive link chains here.
Aug 29, 2011 | Poulan Pro Chain Saw 46cc 20"
Does it have a timing belt or chain and when does it need to be changed
Hello there and than you for choosing fixya
Your vehical has a timing chain see the pict and price below around any where around the 100 to 120,000 mile mark the chain should be changed
Timing Kit/component/Timing Chain
Price:
$33.99
Mar 30, 2011 | 2002 Jeep Liberty
When i put it in reverse the chain slacks up
well first off check make sure the the chain gears of inline if nt then u need to line them back inline then put chain back on check the slack in the chain if its too loose u will need tighten it up but if u cant tighten the chain up due to chain streched out then u may need to take a few links out of the chain
Sep 12, 2010 | Polaris ATV
Need a chain for 14in electric poulan chain saw the normal 14 in chain does not list the electric saw as one it will fit
Hello Jennifer;
The number of drive links, pitch and gauge of the chain need to be determined to answer your question. If you take your saw or just the chain to a local chain saw outlet a new chain can be fabricated in a very few minutes. This will save shipping and handling fees as well. While there get the numbers mentioned above. Once you have these you can likely find a low kickback chain in a local home center the next time the chain needs replacement.
The FAQs here can likely answer all your questions.
http://www.oregonchain.com/pro/service/faq.htm
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Aug 10, 2010 | Poulan 14 in. 2.0 Peak Horsepower Electric...
Bike chain broke on my 21speed promax A series MGX,how do i replace it?
You will need to first determine what the chain broke. If it is because of where you will need to replace the can with a new on. If it was anothe reason then you have a couple options.If you want to repair this yourself you will need to have a bicycle chain tool. Otherwise your local bicycle shop can reinstall the chain for a very low cost, less then the cost of a new chain tool.
If you are going to install it you can remove the bad link and reinstall the chain, however this will likely make you chain too short.
If you are going to replace the chain:
1. Lay the old chain out completely.
2. Cut the new chain the same length as the old chain. If using the quick link provided then make sure to cut the chain with two male ends and make it one link shorter then the original chain.
3.Start installing the chain from the rear derailleur. Start putting the chain in from the lower pulley(wheel on derailleur). Push over the lower pulley and under the upper pulley. Then back up behind and over the cassette (gears on the rear)
4. Now continue pulling the chain to the front. Go through the front derailluer and down around the chainrings.
5. Connect with the other end of the chain.
6.Use the quick link provided with the new chain or push the pin back into the chain (unless in is a shimano chain, then use the provided new pin)
Jul 12, 2009 | Mongoose MGX Maxim Dual Suspension...
Loose chain
I had a few chain driven polaris atv's they tension when weight is on the quad, the rear arm pivots and applies tension to the chain , other then that there should just be guides for the chain. If the chain is still loose with operator weight the chain may have play in the pins and need replaced.
May 05, 2009 | Polaris ATV
Chain length
For a honda 1999-2000 CBR600
you will need a 108 chain link. This is the standard link considering your front teeth has 15 and rear has 45.
If you're not sure of the chain length, buy the 120 link 530 Heavy Duty chain. THe longer the better, you can always cut the chain (using a chain cutter and repair kit) if its excessive.
I recommend you buy the gold chain-type.
Mar 16, 2009 | 2005 Honda CBR 600 RR
Garden Logo
13 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
