INFORMATION - MEM- BAD- POINTER and not able to continue to use Autocad 97 program files
  • 981 Answers
LOL your computer had a soft error and you forgot how to use AutoLISP? Perhaps your office caught the force of the recent tsunami? Information isn't fatal; the warnings and alerts/failures after that should offer a little more detail on what makes a problem a showstopper. What actually happens?
It sounds like either memory went bad and your program won't start up as usual, or the installation (possibly including add-in libraries, etc.) was corrupted. Get an extra backup image on a fresh hard drive, try reinstalling on either one, and see if things improve. Failing that, give a bit more debug information, including verbose log excerpts, etc.
Posted on Mar 13, 2011
Error opening AutoCad file
This error can have a variety of causes....corrupt drawing, a program corruption, or a problem with your system configuration.
There are several ways to troubleshoot the problem: try opening another drawing ,uninstall any antivirus or desktop locking programs or update your graphics driver. If it useless so your file is damaged. In this case you can try to recover it with the help of https://www.fixtoolbox.com/autocadfix.html
Feb 21, 2017 | The Computers & Internet
Corrupt DWG files
AutoCAD RECOVER command?
If doesn't help, try it:
DWG Repair Kit
This professional AutoCAD DWG repair tool features a uniquely efficient data analysis core and an interface that both professionals and novices with appreciate. The program will show you how to repair DWG files online in seconds even if you have never worked with data recovery tools of any sort!
For more information: http://www.dwg.repair/
Also look here: https://social.technet.microsoft.com/Forums/en-US/fb2d8693-9551-43b7-9310-584471d60a56/autocad-files-corrupted?forum=w7itproappcompat
Feb 17, 2015 | Autodesk AutoCAD 2007
My autocad cant start because ac1st16.dll is missing. what should i do? please help me guys...
If you get the above error, copy all the files from C:\Program Files (x86)\Common Files\Autodesk Shared to C:\Program Files (x86)\AutoCAD LT 2004 For some reason, AutoCAD installs the DLLs in the Autodesk Shared folder, but needs them in the AutoCAD exe folder location. Hope this helps! Ben
May 21, 2012 | Autodesk AutoCAD 2006
AutoCAD 2010 won't start after reinstall.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-2010-does-not-start.html
Issue:
When you try to start AutoCAD, you briefly see the splash screen and the program does not start.
Solution:
This behaviour can be caused by corrupted license information.
Please check if there are any errors listed in the ACD2010ENGAdlm.log file in the folder:
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm (Windows XP)
or
C:\ProgramData\Autodesk\ADLM (Windows Vista) (Please note the file name may be slightly different for localized product versions, for example for the German version the file name is ACD2010-DEUAdlm.log)
If the log file shows errors regarding the product information table file, for example "Unable to locate the Product Information Table File" or "Product Information Table file is not found", you will need to:
  1. Uninstall all installed 2010 products
  2. Delete the ADLM folder mentioned above, and
  3. Reinstall the products
Oct 14, 2010 | Autodesk AutoCAD 2010
When I open a file that is associated with autocad, autocad opens the file and the program at the same time. But if I already have autocad open and click on another file, instead of autocad opening that...
Turn off your single document interface. Type OP and hit enter. Then select the system tab and check off the SDI (it should be towards the upper right of the dialogue box.
Nov 24, 2009 | Autodesk AutoCAD 2006
I have a File moreless a Drawing from AutoCad that is an ARD File. Is there a program that can open an ARD File if you don't have AutoCad?
Doesn't look good. The creation program is 3D and it looks like the only program that will open it is. ArtiosCAD
Oct 16, 2009 | Adobe Illustrator CS2
Unable to load autocad 97 on windows vista
I don't believe Autocad will work at all on Windows Vista.
The only other solution I can think of is to download Virtual Box from http://www.virtualbox.org/
You will need to have an XP cd to install, and basically you will be installing an XP virtual machine, at which time you can then install Autocad 97 onto that virtual machine.
Hope this helps!
Jul 19, 2009 | HP Media Center m1080n (PC099A#ABA) PC...
Opening dwgs. in autocad 2004
Try rebooting your computer, then relaunch AutoCAD. If your .dwg file will not open then open the backup file. Sometimes the .dwg file goes crazy and the backup file will save your life, most of the time. Also make sure that your machine has enough memory to run AutoCAD. Memory is either your best friend or your worst enemy when working with AutoCAD. I hope this helps.
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
AutoCad R14 to Vista - bab-Mem-Pointer error message
You are still using AutoCAD R14? If you are that might be the problem. If you are running Vista, then AutoCAD R14 might be too old of a version to run. You will probably need to upgrade to a newer version of AutoCAD. I know this isn't a solution, but I am just trying to look at it from a different point of view. You can also go to autodesk.com and join their discussion groups. It is free and you can post questions. You usually get a fast response with an answer that really helps. I will do a little more research and add more when I get a chance. Good luck and I hope that I helped.
Feb 22, 2009 | Autodesk AutoCAD LT 2008 - Upgrade for 5...
I had a cad drawing and I was messing around with it and lost it tried recover and can't recover it. I had someone resend it to me and every time I get it it changes to a file I can't open it is white page...
Most CAD programs such as AutoCad have a history of recently opened files. In AutoCad go to TOOLS/ OPTIONS/ FILES/ Automatic Save location. There you should find a file with the same name but a different file extension such as .BAK (AutoCad back-up) You can set AutoCad to automatically save to any time period, such as every 15 minutes.
Make a copy of this .BAK file so you keep that unchanged, Then change the file extension of the copied .BAK file to .DWG. Then you should be able to open this file. A file with an extension containing the $ symbol needs to be recovered using the programs recovery tool, in FILE/ DRAWING UTILITES/ RECOVER
If you're using a different CAD program look for this backup file wherever the programs Autosave files are set to be stored.
One other possiblity is the file extesnsion is set by your computer to open with another program for some reason. Right click and hit "open with"
Let me know if this helps
Jan 07, 2009 | Computers & Internet
Computers & Internet Logo
239 people viewed this question
David Payne
David Payne
