Question about Onkyo HT-S5300 Theater System
My hts5100 will not stay on, what is wrong, and how do i correct the problem?
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 13, 2011
Why does my phone automatically advances ahead 2 hours?magicjack problems
Perhaps you did setup the wrong time zone. (wrong country) Check the settings.
Jul 09, 2014 | Cell Phones
Outside temp will not stay on
You may have this posted in the wrong product category. Please select another category appropriate to the problem and re-post the problem so the correct expert will see and respond to the question..
This is for car and truck problems related to factory installed systems not add on aftermarket systems.
This post can't be removed or moved, please re-post the question in the correct product category. Thanks
Oct 26, 2012 | Cars & Trucks
Power washer will not stay on. We added gas. And possibly the old gas may have had oil in it. It will start but not stay on. What's the problem?
This is for car and truck problems.
Oct 08, 2012 | Cars & Trucks
The timing chain was replace on a 1995 Saturn SL1 1.9 SOHC, will not stay idling. What could be wrong, the timing was set correctly, according to the Autozone help repair site. At 12 o'clock when...
Could be that timing is out a tooth. If it was running fine before replacement i would say timing....could be wrong....just a guess really....hope this helps some and good luck..
Aug 14, 2012 | Cars & Trucks
ALBA tv screen turns itself off, but the volume stays on, what's wrong with it? how do I correct it?
Might be some loose solder terminal/s at its horizontal output section. The set should be checked.
May 11, 2012 | Proton MM2701VT 27" TV
How to correctly install the correction tape in a smith corona electric typewriter SD770
you have to turn the spool with the knob untill there is tension on the tape or it won't stay in place
Nov 08, 2011 | Smith Corona Wordsmith 100 Typewriter
My electric range #8053211 or 8053612 or #8273512 the broiler element stays on and the digital disply flashes "f3-e2, what wrong?
The F3-E2 error code says that the oven is getting too hot and the oven sensor would need to be replaced because the control board has detected that the sensor is not telling the control the correct tempature.HOWEVER a defective sensor will in way way make the broil element stay on and thusly i believe what is wrong is that a relay on the control board is stuck and the control board should be replaced.
I belive the reason your getting the F3-E2 code is because of the broil staying on and indeed the sensor is telling the control its too hot since the heat wont cut off.
GENE
Sep 28, 2011 | Whirlpool Electric Range
Screen
No, there is nothing wrong with your screen. The unit automatically zooms in and out depending on how far you are from where you need to make your next turn/change in direction. It cannot be "corrected", this is the way the unit is designed.
Dec 28, 2006 | Garmin StreetPilot c340 GPS Receiver
Onkyo HT-S5300 Theater System Logo
69 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
