Question about Speed Queen CTS97AWN Front Load Stacked Washer / Dryer
Washer, Speed Queen CTS97AWN, final rinse and spin lights begin to flash when it is about to spin. Sometimes it will spin when the spin cycle is selected, other times the lights will flash. The service manual suggested that it might be a problem with the machine control board. I have changed the board and the problem still persists.
  • 209 Answers
SOURCE: Washer stops dead immediately prior to final rinse
this sounds like the conditioner solenoid, this is the cold water valve that works as the final rinse is suppose to work, just before the final spin, check valve connections for open circuit electrically, work safe unplug from power supply first, if i have helped please rate me
Posted on Oct 02, 2007
  • 1314 Answers
SOURCE: BELT REPLACEMENT
look real close in the tub holes to see if a small object like a nail or screw is jamming it then try to turn the tub by hand and let me know the results
Posted on Dec 30, 2007
  • 156 Answers
SOURCE: Green grease? stains from my older Speed Queen washer.
your seals and gear case needs replaced
Posted on Feb 25, 2008
  • 351 Answers
SOURCE: speed Queen home washer will not spin/drain
check belt size
Posted on Mar 29, 2008
SOURCE: Kelvinator or (Speed Queen Top Load washing machine)
I have a Speed Queen AWM373W top loader with the same problem. We recently had the kit and belt replaced because it was leaking water. That is fixed now but it takes forever. The other night I tutned the drum by hand and it worked fine. Did not had the same problem since but I am watching it.
Posted on Jul 07, 2008
Why won't my washer start a cycle? Start button LED just flashes. All other lights are steady. Door lock sounds like it engaged, but nothing happens.
There should be a way to enter the washing machine into service mode to view an error code. Check your user manual and then you should have your answer!
Jul 23, 2014 | Washing Machines
Why does my washer stop in cycle
Raise and lower your lid six times to reset timers.
Sep 30, 2017 | Speed Queen CTSA0AWN Front Load Washer
Washer is skipping cycles
Many select their own possitions for the timer to reduce water usage. Often it is border line where the spin cycle is activated. Try from the beginning, and if it still malfunctions, not question, the timer will need to be replaced. (very basic machine with no noncense activations).
May 23, 2010 | Speed Queen AES17AWF Electric Dryer
The washer quits at rinse and spin dry cycle
I've had the same experience with my Speed Queen washer. Approached the accredited Speed Queen agents for assistance, when tech support was deployed to diagnose the problem.
In the end, I was told that the "timer" went bust. So the wash cycle seems to work 100%, but when it comes to rinse and spin the contacts on the timer don't make contact, and the motor waits in anticipation for it's next command, and that the high pitch noise heard.
Jul 04, 2009 | Speed Queen AWS52NW Top Load Washer
SPEED QUEEN TOP LOAD WASHER HA4011W. Motor trips at SPIN start
I would call whoever repaired the washer back out and have them diagnose.
Jan 23, 2009 | Speed Queen AWS52NW Top Load Washer
28+ year old- Speed Queen Heavy Duty top loader
It sound like you drain hose is siphoning off the rinse water, It needs a standpipe make sure the drain hose is at about the height of the top of the washer, Make sure the drain hose isnt stuck in the drain it also needs an air cap. the drain hose should not lay on the floor to run to the drain
Please let me know if this doesnt solve your problems
Aug 31, 2008 | Speed Queen AWS52NW Top Load Washer
Washer will not drain after wash cycle or the spin cycle
check to see if your pump is slightly plugged with a sock or ?
Your top loader should pump out in about a minute and a half when totally full of water.
Aug 11, 2008 | Whirlpool GSC9455 Top Load Washer
Speed Queen CTS97AWN Front Load Stacked Washer / Dryer Logo
98 people viewed this question
Top Speed Queen Washing Machines Experts
Terry Schneider
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you a Speed Queen Washing Machine Expert? Answer questions, earn points and help others
