Question about Gateway FPD2185W 21 in. LCD Television
I have a Gateway monitor (FPD2185W) that flashes a Gateway icon when I first turn it on. If I unplug it will display the desktop of the computer. What is the problem and is it worth fixing?
  • 36 Answers
The power printed circuit board is failing by the
information that you have given, but with additional information we may find
the actual cause and a solution to it. You may email me at: Sprint6@zoominternet.net or explain
better the symptoms it is having.
Posted on Mar 23, 2011
My screen is black on my gateway w340ui what needs to b repaired n how much?
Screen is black? Does it look like the computer booted up all the way, if so maybe your icons are on the desktop.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
Apr 16, 2012 | Gateway Computers & Internet
My screen turns black upon startup. For awhile when my screen was on, it would flicker on and off but remain on. Now, the only time I can see the screen is when I unplug vga cable then plug back in but...
You mention a VGA cable so I assume its a stand alone monitor for a desktop PC.
It can be repaired,this fault is usually indicative of a capacitor, maybe two or three bursting in the
a) Power supply.
b) Back Lighter.
or
C) Inverter.
As its 6 years old, I would suggest replacing would be the most cost effective resolution.
Jun 10, 2011 | Gateway Computers & Internet
I have the FPD2185W. Off and on now I get small,
Check to see if there are any magnetic or electrical power supplies located recently moved near the monitor area.
Nov 13, 2009 | Gateway FPD2185W 21 in. LCD Television
I just bought a new computer,(Dell) and like my
normally you dont need an application to install it just plug your new monitor and your OS (XP or Vista) will automatically setup your new monitor..hope this helps..ITTech7574
Aug 29, 2009 | Computers & Internet
Gateway monitor fpd2185w goes to sleep and then shuts off
I suggest to mess around with the monitor buttons and see if you can disable it from sleeping from there. If not then try enabling it to sleep on your computer settings. A good restart after any changes is always helpful.
Jul 07, 2009 | Gateway FPD2185W 21 in. LCD Television
FPD2185W Gateway monitor
If they dont due anything Contact Monitor Depot Link was below BBB they fixed mine for 99.95 works great Let me know how it turns out
Oct 24, 2008 | Gateway FPD2185W 21 in. LCD Television
Gateway fpd2185w tft lcd monitor repair
Probable failed power supply. If you look at the screen on an angle after your system has finished booting and see faint images, it is the backlight or is associated high voltage power supply that has failed.
If you see no 'shadows' at all, then the main supply has failed.
Either one of these could be a separate supply since many manufacturers buy from specialized companies.
Aug 24, 2008 | Gateway FPD1975W 19" LCD Monitor
No signal from computer to monitor 8/13/08!
I had the exact same problem!! Drove me crazy for days. Couldn't find any answers online, contacted Gateway tech support and they told me my warranty was expired but they'd be happy to discuss my issue for $2 per minute. Gateway can **** it!!
At first I thought the problem might be a malfunctioning NVIDIA card, a problem with my DVI cable, or the monitor itself. But, after turning off the computer, unplugging the DVI cable, replugging the DVI cable and restarting the computer, I noticed I could get the firmware flash screen to show, including the BIOS menu boot and the Gateway system reinstall screen to show. As soon as the Windows flash logo would display, however, the monitor would drop out and display the dreaded "No Signal" error.
This indicated the problem was a software one and not hardware! The cable, monitor and video card were all working fine. Then I remembered that Windows installed its automatic update a few days prior. In fact...
THE PROBLEM TURNED OUT TO BE A WINDOWS UPDATE INSTALLED A FEW DAYS PRIOR.
After succesfully booting into safe mode (F8 during the flash/bootup screens), I went to Add or Remove programs in the control panel, clicked on the "Show Updates" box on the top, and uninstalled the Windows update from a few days prior to the occurance of the error. After a reboot the problem was solved.
I hope this will help anybody else struggling with this error!
Aug 15, 2008 | Gateway FPD2185W 21 in. LCD Television
Open Questions:
See all Gateway FPD2185W 21 in. LCD Television Questions
Gateway FPD2185W 21 in. LCD Television Logo
73 people viewed this question
Top Gateway Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
