Question about Honeywell Heating & Cooling
My wife disconnected all the wires to the thermostat, I do not know what goes to what. Reading the installation docs I get it that white is to white yellow is to yellow green is to green. But for the power Red it could go in three places RC R or C with the jumper on RC R. Any help would be appreciated. it going to get cold for the family.
    Guru:
  • 257 Answers
The Red wire goes to the RC-R with the jumper as you are using a one transformer unit. The C is for common and is usually blue in blue in the units I install.
The colors stand letters stand for
W - Heat
Y - AC (outside unit)
G - Fan
Thank you for choosing FixYa.com
Justin
Posted on Mar 13, 2011
I have a Trane XE1000 High Effeciency heat pump, installed in 1989, in the house I am renting. I'm having issues with the air and I think I hooked the thermostat up wrong. I have 8 wires coming out of...
The white wire goes to W2, the green wire goes to G, the red wire goes to R, the orange wire goes to W or O, and the Yellow goes to y. If this is a digital thermostat you will have to go to the set up mode to set the system up for a heat pump or the reversing valve in the outdoor unit will be in the heat mode. If there is a C on the thermostat you will need to put the black wire there on some Trane models.
Jun 06, 2011 | Heating & Cooling
My thermostat wires got pulled out of my outside unit and need to put them back but dont know where to start. The wires coming out of unit are blue and yellow and the norm thermostat wiring witch wires go...
Hello Cadbiad Jason,
I understand that your wires go to you outside unit (condensor) have been pulled out. To start with you have two thermostat wires look like telephone wire, and three power wires a ground usually bare or green, a white 120 and a black 120 volts.
I would be glad to help you with your problem. The first thing you need to do is shut off the disconnect box located by your unit as you do not want to get shocked by 220 volts.
1. Disconnect all power to the unit and turn off the thermostat.
2. Take the service panel off the side of the unit (1/4 or 5/16 screws)
3. The service panel you will notice a contactor this contactor will have two connections on the front and back for the white and black wire one side is for power from the disconnect the other side is the power going thru the unit to its parts. Make sure all of these connections are tight.
4. On the sides there are spade connectors one of your thermostat wires goes to one side and the other one goes to the other side (it does not matter which one goes where on a two wire non heat pump unit) you can wire nut each wire to the the ones if they are still usable. If not you will have to crimp new ends on your wires.
5. Replace the service panel
6. Turn the disconnect back on
7. Turn on your thermostat and make sure the unit turns on
If you have any further questions about this unit please fell free to post them to this thread and I will be happy to assist you. Thank you for choosing FIxYa.com
Justin
Mar 26, 2011 | Goodman Heating & Cooling
I just bought a Honeywell 5.2 Day RTH2300B Programmable thermostat to replace my old mercury thermostat for my gas fireplace. When I took of old thermostat it only has two wires. A white wire and a black...
I just installed a Honeywell 5.2 Day RTH2310B Programmable thermostat and I had to deal with the same situation: 2 wires, one white one black. After reading the edvice in one of the blog, the solution that worked for me was: BLACK ON Rc terminal and WHITE on W terminal. My furnace is running fine now. Hope it helps.
Dec 06, 2010 | Honeywell Focus 6300B 5-2 Days...
I purchased the lux tx9000ts and the 4 wires i have are red,blue,green,white how do i install plz help or the wife will kill me
We will try to keep you alive here... :-)
Red wire on the R terminal
Green wire on the G terminal
White wire on the W terminal
Blue wire on the C if no A/C and on the Y if you do have A/C
Thermostat Wiring and Terminal Designations
heatman101
Oct 13, 2010 | Heating & Cooling
I need a diagram on abaseboard heater
The common usually goes staight to the unit, and the other wire, goes through the thermostat, and the ground wire hooks directly to the chasis of the heater.
If it is a 120 Volt, the white wire should be the common, and the black runs through the thermostat.
If it is a 220 Volt, it doesn't matter which wire goes through the thermostat.
Mar 31, 2010 | Cadet Manufacturing 6F1500W Baseboard...
I have a mobile home with just heat but the air cond come with it
You will now need a 4-wire thermostat as well as 4-wire thermostat cable since you now have cooling in addition to heating. The 4-wire cable should have a red, green, white, and yellow wire. Some cables have a blue wire in place of the yellow wire. The red wire, which is 24 volts hot, goes on 'R' terminal. The green wire, used for the indoor fan, goes under 'G' terminal. The white wire, used for heating, goes under 'W' terminal. And the yellow or blue wire, used for cooling, goes under 'Y' terminal.
Aug 05, 2009 | Heating & Cooling
Thermostat wires
just put a jumper between rh aand rc and use red, yellow you hook up to y1, white goes to w1, common is either black or blue.
Mar 27, 2009 | Honeywell Programmable Thermostat Heater
Wiring
On the Goodman control panel each wire is marked (on the PCB board) Y, R, B, W, Br etc. These should also be letters next to the screws for the wires on the thermostat. match the letters/colors to both sides.
Nov 08, 2007 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
41 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
