Question about Home
How do you wire an outdoor ligh coming from an inside light switch
  • Rob Tyrone
    Rob Tyrone Mar 13, 2011
    how do you wire an outdoor ligh coming from an inside light switch
  • 827 Answers
First, sounds like that you need to have an electrician do this for you.
Posted on Nov 24, 2013
The lighs on the inside will not turn off
I'm not certain on your specific car, but if all the doors are closed, and the interior lamp switch is off (the dimmer for the dash lights), they should turn off. You could have a defective switch (long shot), or a short in the wiring, or the delay circuit that keeps the lights on for a time is defective. Without a diagram and some expertise in electrical circuits, this is a job for a real DIY or an auto electric shop.
Mar 28, 2014 | 2009 Lincoln MKX AWD
I want to replace my existing single bulb porch light with a 2 bulb motion activated light. It would be operated with the existing switch. Is this ok to do?
Yes. Must keep switch turned ON.
Outdoor lights will only come on when motion is detected, otherwise light bulb does not come on. So the indoor wall switch does not work as override since the motion sensor takes over as the sole switch.
Copy following link for wiring illustrations:
http://waterheatertimer.org/How-to-wire-occupancy-switch.html#motion
Other solutions include adding separate motion sensor light nearby and keep porch light so you can turn on-off when desired.
Another option is to add photocell to outdoor light so it turns on automatically at dusk.
Another option is to use outdoor yard timer with dawn-dusk capability:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
Another option is to replace indoor wall switch with with dawn-dusk timer, that can also be used as ordinary on-off switch so you can turn porch light on-off when desired. Timer such as Intermatic ST01C offers simple 2-wire connection.:
http://waterheatertimer.org/ST01C-program.html
Gene
h
Aug 18, 2013 | Electrical Supplies
97 lincoln mark viii oil pressure light always on. oil pressure good. new sender
test the faulty lamp , turn on the ignition switch to the START position The providing circuit shoudl ligh the warning lamp. If hte light does not come ON during the porve/out, disconnect the sender switch lead. Use a jumper wire to connect the sender switch lead to ground . With the ignition in the RUN position, the warning lamp shoud light. If the lamp is iluminated, replace the sending swith. If the light does not come on, either the bubl is buned out or the wiring is damaged.
God bless you
Sep 28, 2012 | Cars & Trucks
I am replacing a programmable timer switch that controls exterior garage lights. This switch is in the same box as a ac switch that turns on the lights inside the garge. There are 3 rolmex wires inside the...
Project is not clear.
Are you replacing the timer with a switch?
I have complete files on timers, so if you are replacing the old timer with a new timer, then add a comment and say which timer you are installing.
You have 3 cables. Assuming 120Volts.
Each cable has 1 black and 1 white and 1 ground.
White wires are twisted together and pushed to back of box.
Ground wires are twisted together and pushed to back of box.
Black wires are next:
(A) Cable A:
One of the three cables will have a black wire that connects to both the switch and to the timer.
So look for the black wire that connects to both switch and to timer.
This is the hot wire from breaker box. Connect this black wire to both switches including new switch.
(B) Cable B: One cable goes to garage lights. Black wire going to garage lights connects to on-off switch.
So the garage light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
(C) Cable C: One cable goes to outdoor lights. Black wire going to outdoor lights connects to new on-off switch.
So the outdoor light switch has 2 black wires: 1 black wire from cable A, and 1 black wire from cable B going to light.
Jun 27, 2011 | Hardware & Accessories
The outside unit does not operate. All i can hear when i turn it on is is ticks for a minute then turns off. I have reviewed the inside of the unit and no error light comes on except for a led light...
D25 code : Check power supply voltage to the outdoor unit is correct (1ph ?220 Vac ±10% or 3ph ?380 Vac ±10%). If OK, check fuses, if fuses are OK replace outdoor main PCB
D26:
compressor seized. Check compressor windings all equal resistance 1 to 4 Ohms, check to earth 50 MOhm minimum, check run current and Inverter outputs
Hope helpful?
Jan 04, 2011 | Sanyo Split System Air Conditioner
I have installed a 2-way dimmer switch in my dining room. I was able to install it and it works great. However, on the other side of the wall where I installed the switch, I have another single way...
If I understand correctly new dimmer is in different box than outdoor switch.
And outdoor switch controls different light than new dimmer.
Both new dimmer and outdoor light are on same circuit breaker, and that breaker is not tripped.
Outdoor problem could be related if loose wire inside dimmer box also feeds over to outdoor switch. More below.
Here's how I would troubleshoot problem.
1) Check outdoor bulb(s). This step can be big time saver.
2) Pull outdoor switch out of box a bit so you can see and test wires.
3) If wires are pushed into quick connects located on back of switch, these connects get loose. Moving switch usually causes loose wire to connect again, so turn switch ON-OFF and see if outdoor lights work. Sometimes switch works fine after quick connects reconnect. If quick connects are bad, use tiny screwdriver in slot next to connect-hole to release wire. And then connect wire to screw terminals on switch. Or replace switch.
4) Turn switch to OFF, use tester and test both screws on switch to bare ground wire. Tester should light up on one screw. If tester does not light up, then switch is not getting power, and that wire has to be tracked back to see where short is.
a) Look if one of the black switch wires is connected to other switch, or connected to other black wires inside same box. This wire might have come loose.
b) Look at white wire inside same box and make sure they are twisted together and covered with wire nut.
c) Now here is where dimmer could be related ... if white wires are joined together in dimmer box, they could have come loose if they were not properly twisted together and covered with wire nut.
http://waterheatertimer.org/How-to-twist-electric-wire.html
5) Turn switch to ON and test again. Tester should light up on both screws. If switch does not light up on both screws, then switch is bad. Replace switch.
Add a comment if you need more help.
Dec 01, 2010 | Leviton Decora Light Dimmer Switch
15265 In-Wall Digital Timer - I am replacing an Aube with this new timer. Timer is to operate a wall plug (outdoor soffit). Timer is inside. The old switch had 3 wires - only two were connected (I think...
GE -15265 manual
http://waterheatertimer.org/pdf/GE-15265-manual.pdf
Ah, the usual how to connect 4 wires to the old 'was-3-wire and now-2-wire' problem.
I tested and wired these timers.
Aube timer has internal rechargeable battery, and therefore does not need another wire to run internal clock.
GE timer has extra wire to run internal electronic clock, just like alarm clock is plugged in.
Heres what to do in simple format
1) Timer-green-wire connects to bare ground wire.
2) Old timer has 2 wires. Take both wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This action will complete circuit to internal clock.
4) If electric box does not have white wires described above, then connect timer-white to bare ground. This works because bare ground and white neutral both connect to neutral busbar inside breaker box.
5) Turn on electricity, push in timer door for manual override. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
If light does not come on, double check that outdoor bulb is good, and that breaker not tripped.
Timer can also be reset in event of short. Reversing red and black wires will not short timer.
Add a comment of you need more help
http://waterheatertimer.org/See-inside-main-breaker-box.html
Nov 30, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
96 suburban brake ligh don't work
you may have to change the brake light switch at the top of the brake pedal stop by your local GM dealership in the parts department and they be able to print you off pictures and diagrams but check on the part at your local part store because it maybe cheaper wish you the best of luck Michigan Man.
Dec 27, 2009 | 1996 Chevrolet Suburban
Inside unit running outside want come on temp on
check circuit breaker in house panel labeled a/c or outdoor unit
check box near outdoor unit for a breaker or fuses
some thermostats have a 5 min delay when switched to a/c
check for external reset buttons at outdoor unit some are red depending on brand
check that all wires are intact at outdoor unit------none cut or hanging and not hooked to anything?
Jun 19, 2009 | Honeywell Programmable Thermostat Heater
Home Logo
24 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
