Question about Bissell 2080 QUICKSTEAMER Upright Vacuum
I am trying to find an instruction manual on line for my 2080E Bissell Petwasher Power Brush as I have moved into new property and need to use it but not sure on how to as its been a while since I last used it.
  • 694 Answers
Bissell power steamer brushes will not turn
Hello, this is Ava with Think Crucial.
There are a number of reasons why your brush roller is not turning. General maintenance to your vacuum is crucial and will help it work at peak performance.
First things first lets focus on the brush roller. Unplug the vacuum and turn it on its side. Look for any noticeable clumps of debris or hair strands that may be caught in the brush roller. Remove these obstructions, probably best to do so with a scissor if it's hair or long pieces of carpet fibers. After removing the debris try manually rotating the brush roller to uncover other hidden clogs. Another thing to take note of is the condition of the bristles on the roll itself. Are they loose or worn down? These are signs that your brush roller is in need of replacing.
While checking out your brush roll you might as well take a look at your vacuums belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
You can purchase a wide variety of high quality Bissell replacement parts for your Bissell vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=bissell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 25, 2016 | Bissell Power Steamer Shaft w/ Head Hose
Bissell instruction manuals
Remove the cover over the brush bar...there may be screws or
numbered release tabs...start with tab #1. Pull the brush bar out
of the slots on each side and slip the belt off the pulley. Make sure you buy the correct belt and that the groove in the brush bar and pulley are lined up when you put it all back.
Regards,
Dennis
Aug 15, 2014 | Bissell Vacuums
Bissell 3750 brush not moving has new belt suction works well on vacuum
There are a number of reasons why your brush roller has stopped moving. General maintenance to your vacuum is crucial and will help it work at peak performance.
While checking out your brush roll you might as well take a look at your vacuum's belt. Your belt should be replaced about every three months. After regular usage, the belt will stretch out, lessening the tension on the brush roller. Lesser tension diminishes the brush roller's turn rate and speed. If the belt feels loose then it certainly is affecting your vacuums suction as well as your brush roll not moving at all.
https://www.thinkcrucial.com/collections/vendors?q=Bissell
Ava B.
Sep 17, 2011 | Kenmore 22812 Bagged Canister Vacuum
I have a lift-off bissell vaccuum and as I vacuum often the power brush will turn off and on. How can I fix this?
Ava B.
Jul 16, 2011 | Bissell 37604 Lift-Off Pet Bagless Upright...
Bissell pro heat brush is not spinning. the belt is on and spinning but brush is not moving
There are two belts a brush belt and a pump belt. For a kit with installation instructions contact
BISSELL Consumer Services at
1-800-237-7691
Mon-Fri: 8am to 10pm ET
Sat: 9am to 8pm ET
Apr 19, 2011 | Bissell Vacuums
I bought a Bissell 1695 power steamer from a friend without a manual with instructions nor the attachments. Can you help please??
Hello, I went to a local repair shop & was told that I may as well trash this Bissell 1695 model because very few parts were available & none were what I needed. Of course, I have to research things for myself & to try to keep from buying a new power steamer. Called Bissell Customer Service. CSR told me that the model was discontinued, none of the parts that I need are available & referred me to five authorized KY dealers (all of which are an hour or more driving time away). I am going to call all of them tomorrow & hope I can find a solution to one broken pivot arm that holds rotating brush roll. I found a helpful website that has a schematic and lists all parts that are available to order (& unavailable). There is also one service note regarding the parts that I need that says the entire base assembly with brush motor must be replaced because of a design change. Of course, it's not available either. Hope this helps some. The website is: hescoinc.com
Dec 19, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Bissell 2080 QUICKSTEAMER Upright Vacuum Logo
241 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
