Question about Garden
John deere 510 backhoe engine runs fine powershift works fine but no powersteering, front bucket, and no rear boom controls. first found hydraulic pump to have stuck pistons so i replaced the pump now the rear boom moves a little but no powersteering or front bucket movement
Where do I add hydraulic fluid to a John Deere 310 B backhoe
There are several places for checking and adding fluid. What seems low, the bucket hydraulics, or the drive hydraulics (ie: tranaxle)
Jul 09, 2016 | John Deere Garden
Where is the serial number located on a john deere 510d backhoe..so i can find out the year of the backhoe
Diane, JD 510D VIN# Location: On older models plate is attached on outside of frame behind either left or right front wheel. On newer models VIN plate is attached just above left (Highway) side cylinder arm. Same location as Caterpillar. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
http://cppsocal.org/wp-content/uploads/2014/04/Heavy_Equipment_Catalog_Vol_5.pdf
https://www.oswca.org/uploads/combatting-heavy-equipment-theft-2015.pdf
Thread where is Serial number for 1977 John Deere 510 hoe
Serial number plate location for john deere 510d backhoe Google Search
Jun 20, 2016 | John Deere Garden
How to troubleshoot swing motor problems on a 1963 jd row cropper backhoe?
just like any hydraulic system there is A (IN) and a (OUT) on every cylinder and motor on tractor (even steering) loosten (NOT remove) the hose fitting thats on (A or In) to motor and attempt to move joint/device with controls if a steady drip of fluid is present then your problem is device (cylinder,motor) if no drip then follow hose up to power divider or solinoid or hand valve and attempt same procedure , keep moving up the line till you get a steady drip of fluid and last device in liine is the problem device , repair or replace it
ALLWAYS turn off motor and release pressure from hyd system before you attempt to completly remove any device from system for replacement , and note that booms and arms and heavy stuff will relax(fall) with no pressure in system , prepare for this to happen (blocking,chaining)
May 11, 2014 | John Deere 420,1020,2010,2020,2510,2520...
PTO Issues
replace the pto solenoid as it has an internal short causing the fuses to blow.
Jun 02, 2013 | John Deere Garden
The hydraulic steel line on my 2010C bucket loader broke and I dumped a good amount of fluid before shutting everything off. Replaced line and filled tank up, everything worked fine for about 1/2 hour,...
Like other hydraulic systems, there is probably a procedure for bleeding the lines after loss of most of the fluid. You may still have air trapped in the system and once it works its way to the cylinder, the cylinder is working with air instead of fluid and the air compresses instead of doing work.
Sep 16, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
163 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
