Question about Samsung Digimax L730 Digital Camera
Samsung L730 My camera appears to be stuck. The lens usually pops out when it is turned on. However, when I turned it off today, it remained out. I tried removing the memory card and battery. Also, it won't turn off unless I remove the battery. When it is on, the screen is black and the usual green light goes off after initially pressing the power button. Is there a way to reset it?
  • 1 more comment
  • troysie Sep 20, 2008
    yes i have the same problem,wont turn off its like its frozen HELP!!!!!
  • dbtv Dec 20, 2008
    My camera appears to be stuck.  I took 3 snaps -whem I tried to switch off the lens did noy close in full - the lens are now out and the camer cannot be switched on - I tried switching the baterries and the memory card but it does not switch on or close the shutter - I just bought the camera new a month ago
  • klll Dec 21, 2008
    I have the same problem - did anyone else manage to fix it?
  • 797 Answers
This camera would have to be tested more, but it sounds like a ccd or sensor problem.
If this camera was made around the year 2000 or after a bit, then it could be a ccd problem common with many Sony made ccds in this period.
A loose connection internally could also cause similar problems.
Posted on Aug 01, 2008
Dropped my L730 digital camera and since then when viewing pictures taken, there are lines across the screen...?
Sounds like the shutter has been damaged and is stuck open, which overexposes photos and gives a 'venition blind' effect - the shutter and/or lens unit would need to be replaced. Probably marginal given low replacement costs.
Jun 02, 2010 | Samsung Digimax L730 Digital Camera
Zoom lens will not open on L730 camera
hi,
its lance problem , its most probebly happens with them, you just well servise the lance , if you are a technition then try it at home otherewise contact authored person
Aug 31, 2009 | Samsung Digimax L730 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Try removing the batteries and memory card. Let the camera set for awhile. Put the batteries back in but not the memory card, restart the camera. Does it work know? If it does, turn the camera off put the memory card back in. Turn the camera on, does it work now? If it doesn't, replace the memory card.
Dec 27, 2008 | Samsung Digimax L730 Digital Camera
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
My samsung L730 lense is stuck
i have the same problem with these camera. to get it fixed just take out the battery wait for a few sec and put the battery back on, then switch the camera on. for the lens just gently move/force the lens to open, then turn off the camera wait for a few seconds then turn on the camera back on see what happens. and if still persist keep doing it till gets back to normal.
this sometimes happens to my camera from time to time i think it just its wear and tear.
one more problem with this camera is that it'll go blurr, just do the basic turn off or take out the battery wait a few sec and then turn it back on.
hope this will help u.
Nov 08, 2008 | Samsung Digimax L730 Digital Camera
Lens is stuckpartly open power button does nothing-won,t turn off
mine has done this and I have grabbing the lens and pulling it out at the same time as I turn it on. It is a pain but it now works
Jun 24, 2008 | Samsung Digimax L730 Digital Camera
Samsung L730 stuck
I tried turning it on, removing the battery, replacing the battery, and turning it on. This didn't work. When I repeated this but also removed the memory card, it did work.
May 22, 2008 | Samsung Digimax L730 Digital Camera
I encountered this issue today while taking a photo of my dog she licked the lens... the LCD screen went all blurry and I was unable to take any photos. The thing kept beeping at me and I was about to throw it in the bin until I had a good look at the lens. As there was a picture coming through on the LCD I knew it wasn't completely stuffed however as the camera couldn't focus an image it gives the unhelpful beeps which apparently translates to clean the lens! So i gave it a clean and presto it was fixed!
Just be careful when u clean it make sure u don't scratch the lens with rough material or use chemicals. Hope it works.
Feb 17, 2008 | Samsung Digimax L730 Digital Camera
Samsung Digimax L730 Digital Camera Logo
218 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
