Question about Orbit 2-Dial Hose Faucet Control Timer #62015
Orbit hose control valves do not shut off completely
Orbit automatic faucet timer will not shut off
Try to spray with a lube like wd 40. sounds like the mech is hung up with a foreign material. Spray-rinse-reinsert fresh batt.
Jul 29, 2014 | Orbit 2-Dial Hose Faucet Control Timer...
Can this valve be repaired?
Check to see if the company has a rebuild kit for the unit.
Jun 06, 2014 | Orbit 51016 3/4" Brass Anti-Siphon Valve
Timer has shut off to this valve but water keeps going through valve
Hi Check
There is no dirt in the valve
Normally Shut
Dirt will lift the diaphram
May 07, 2014 | Orbit Irrigation 67790 DripMaster 4-in-1...
Just hooked up (water lines only, no control wiring yet) a 3 station Jar top Manifold. One of the valves is open while the other two are shut. Have taken apart and see not apparent reason for it to be...
Make sure the bleeder is closed or solenoid is tight. Sometimes valves just fail without a obvious reason. Suggest purchasing the same jar top valve and rebuilt it using the new diaphragm, spring, bonnet and solenoid. This should correct the problem.
Apr 13, 2014 | orbit"" 1"" jar top valve"
Receive short message on controller box for valve2 sprinkler on orbit snap wire connector
Disconnect the wire at the valve and try again. If no short connect the wire to adjacent valve and see if it shorts out. If no, replace the solenoid. If you still get a short message the problem is in the timer circuit board. Replace the timer.
Aug 26, 2013 | Orbit Irrigation Products 57253 3-Valve...
Model 57882 9 station timer I did set up station 1 where do I begin in order to set up station 3
Question is not clear.
Do you have programming problem with the timer?
Or problem locating sprinkler heads?
Or a sprinkler valve problem?
Add a comment with detailed information.
Sprinkler timer turns ON-and-OFF.
Timer does not advance the sprinkler to next station. The sprinkler valve advances to next station when timer turns OFF.
For example, when timer turns ON, then station 1 starts watering.
Timer turns off, and then sprinkler valve automatically advances to station 2.
Timer turns on again, and station 2 starts watering.
Orbit resources:
http://www.orbitonline.com/support/
http://www.orbitonline.com/lib/media/InstallationGuide.pdf
http://www.irrigationdirect.com/media/manuals/owners-manuals/orbit/Orbit-WaterMaster-57880-Controller-Owners-Manual.pdf
Aug 02, 2011 | Orbit 57882 9 Station Super Dial...
I am looking for a battery water timer that does not need pressure to operate. Just gravity. Any ideas?
Google search: 'battery operated timer' and 'battery operated hose end'
Smarthome shows the Orbit: and has manual:
http://www.smarthome.com/31035/Orbit-57860-Battery-Operated-Sprinkler-Timer-with-Inline-Valve/p.aspx
The manual says 'turn down water pressure.' It looks to me like this timer opens and closes the valve with or without water pressure.
Sounds like it would be perfect timer for above ground cistern where gravity cause water to flow when valve is opened.
Amazon shows battery operated hose end, but doesn't show manual:
Hose end timers are not going to have a pressure gauge.
http://www.amazon.com/Hose-End-Battery-Operated-Timer/dp/B0001O0DXO
Apr 18, 2011 | GARDENA Water Timer
The instruction manual got wet and I cannot read how to program the Orbit Watermaster 62015/91600. please advise
Assuming you have the four dock kind, here's the link to the pdf manual online. Otherwise, you can search their website for the correct manual.
http://www.orbit-irrigation.com/lib/media/62032-24ErE_001098.pdf
May 12, 2009 | Orbit 2-Dial Hose Faucet Control Timer...
Orbit 2-Dial Hose Faucet Control Timer #62015 Logo
42 people viewed this question
Top Orbit Hardware & Accessories Experts
Craig Butler
Craig Butler
appman67
appman67
pawnpower
Are you an Orbit Hardware and Accessory Expert? Answer questions, earn points and help others
