Question about Garden
My Laguna pressure flo 2100 filter has stopped working. Any idea what might be the problem.
  • 56 Answers
Have you tried turning the impeller gently by hand? Sometimes this gets jammed.
If it is running but water still isn't flowing you may have an air leak. You can locate one of these by running a hose along the seams and waiting for the pump to prime.
If the impeller turns easily but still will not spin when power is supplied your motor may be dead. If you feel a vibration or noise when powered up and the impeller still will not spin the magnet on the impeller shaft may have detached from the impeller drive.
Except for the motor all are easy fixes with inexpensive parts that should just drop in.
Posted on Mar 13, 2011
I could not get the lid on the PF2100, I tried the solution listed on this site. I was able to get it on with the rubber gasket by putting the lid upside down the putting the rubber gasket on the lid. ...
It sounds like the seal simply didn't seat properly. I recommend placing the rubber seal along the rim of the bottom canister and lowering the lid onto it vertically as uneven pressure can cause the seal to shift out of position. Make sure to check the rubber seal for pinched or hard spots and cracks as these will cause your leaking issue. It can take a few tries to get everything to sit just right. I always dread my bi-annual filter servicing for the same reason but with practice it becomes easier to get them to seat on the first shot. If you are running this filter on a freshwater pond with more than 800 gallons a very small amount of mineral oil (less than an 1/4 ounce) can be rubbed onto the seal to ease seating.
Mar 28, 2011 | Laguna Pressure - Flo Uvc Filter: Pf 2100
Do you carry uv-c t5 11w if so how much
It cost 12 dollars at the link below...
http://www.lightbulbsurplus.com/index.php?main_page=product_info&cPath=622_128_133&products_id=256
Mar 21, 2011 | Laguna Pressure Flo Uvc Filter 11w...
I set up a Laguna powerjet pump and a Laguna Pressureflow filter in my pond yesterday. The fountain from the powerjet works fine with good water pressure, but even if I turn the dial on the powerjet to...
Hi and welcome to FixYa I am Kelly. I suspect that the filter is not properly locked into position but.... I highly recommend you countact Laquna Experts. The can handle most 1st time install issues over the phone is just a short time. (Cordless phone recommened)
CANADA ONLY:
Toll Free Number 1-800-55HAGEN (1-800-554-2436) ..........Between 9:00 AM and 5:00 PM Eastern Time.
U.S. ONLY:
Toll Free Number 1-800-724-2436 ....................................................Between 9:00 AM and 4:00 PM Eastern Time.
U.K. ONLY:
Helpline Number 01977 556622 ......................................................Between 9:00 AM and 5:00 PM.
If they can not help you just repsond here and we will give it our best.
Thanks for choosing FixYa,
Kelly
Oct 10, 2010 | Laguna Pressure - Flo Uvc Filter: Pf 2100
New uva light not working, have been told about a reset button but unable to find it
On the bottom of the UV head where you just replaced the bulb. There are 3 screw holes and a 4th hole with the button in it.
May 10, 2010 | Laguna Pressure Flo Uvc Filter 11w...
Heat not firing, read-out indicates "FLO"
you may have a bad pressure switch.if you are getting flow thru the heater and this code is comeing on there are only two reasons.No flow or bad switch.
Jul 06, 2009 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
How do you for quickness put lid back on it takes ages to go back
Put the foam media in the base 1st. Pull to two cleaning handles on the lid up all the way before you put it on the base. Place the lid on the base then push it down carefully, alternating from side to side until it is all the way down all the way around. Then you can put on the locking ring.
May 17, 2009 | Laguna Pressure - Flo Uvc Filter: Pf 2100
Garden Logo
110 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
