Question about Uniden DECT 6.0 Cordless Telephone Expansion Handset
I can't get the cordless hand sets to work. It has the word Searching written across the little screen. I have 3 handsets and paid alot of money for this phone. How could I solve this problem. I can't call out or receive calls from the handsets.
  • 60 Answers
Unplug the battery and replug it back in... it should search for the base. are you running a wi-fi router?
Posted on Mar 13, 2011
Hi, Bruce Kelly I have a Uniden DECT1480-3 That the screens on all hand set's say's SEARCHING. I can not get a dial tone so I am unable to make a call or recieve a call. Their is no dial tone and all of...
All of the handsets appear to have lost their
registration to the base and will need to
be first de-registered then re-registered.
It may be necessary to do this in three stages.
First be sure that all of the handset batteries
are fully charged.
1.
Clear one of the handsets of its registration:
hold down both the [END] and [#] keys
at the same time until the display shows the
SYSTEM RESET menu.
Since the handset is not recognized by its
base, select "Base Not Available".
Confirm the choice by selecting "Yes".
This handset will now display
"Handset Not Registered"
2.
With "...Not Registered" displayed, place
the handset into the base unit cradle.
The handset should now dieplay
"Handset Registering"
After ~30 seconds the display should show
"Registration Complete" and will have a
handset unit number.
If the unit shows "Handset 1" (doubtful)
then just repeat steps 1 & 2 above for each
additional handset in turn. This can also be
the route if you do not care what the numbers
are and do not exceed the maximum count
for your system ( some are 4, 5, or even 12 ).
If the handset is a number other than 1 you
may want to clear the base & re-register
all of the handsets:
3.
Using the now-registered and working handset
(number x), press both the [END] and [#] keys at the same time until the display shows the
SYSTEM RESET menu.
This time, choose "Deregister HS" and the
System Reset Menu will prompt you to
select from the list of registered handsets
which one you want to deregister: choose
one that is NOT the one you have working.
Cycle around deleting them all until only the
one that is working is left: select that one and
the system will be ready to start re-registering
all handsets again from Handset #1.
Start at process (1) above, then (2).
Good Luck!!
Apr 07, 2017 | Uniden Dect1480-3 Dect Cordless Phone, W/3...
I have a D1680 system with one accessory handset. The hand set on the base is showing Searching although it is on the Base. It rings when a call comes in but when picked up it says out of range. The...
1. Press & hold End and # at the same time until you see the System Reset menu.
2. If you still have the base the handset is registered to, select Deregister HS, then select the handset you want to reset. If you don't have that base anymore, select Base Unavailable.
3. To confirm, select Yes. The handset displays "Handset not registered"
Now you want to register the phone again.
1. Place the handset in the base; the display should say Handset
Registering.
2. Wait until the display says Registration Complete (about 30
seconds), then pick up the handset and press Talk/flash.
You should now have a dial tone
Oct 16, 2013 | Uniden D1680 Cordless Phone
I have a 3 pack of cordless Uniden Dect 6.0 phones, my phones were all working properly, now they are not. All 3 of the phones say searching on the screens and they all have a blinking red light on them.
hi that means for you to check the connect of the phones and make sure they are all plug in if this does not work take them to a company near you that repairs cordless phones..
Jun 12, 2011 | Uniden DECT 6.0 Cordless Telephone...
Panasonic KX-TG2356 Cordless Phone key pad
Open the hand set by Removing battery, remove 2 screws under battery, carefully open handset casing by prying open with thin bladed screwdriver, remove pc board by removing 3 retaining screws, on opposite side of pc you will see contacts for handset buttons clean with eraser and reassemble handset.
Jan 24, 2010 | Panasonic KX-TG2356 Cordless Phone
Uniden Cordless handset
we purchased the uninden 3 pack bundle they worked fine when installed now one handset will light up but the screen comes up blank and the handset won't work also if this can be corrected i would like to know how to purchase one extra hand set and charger
Sep 30, 2008 | Uniden DECT 6.0 Cordless Telephone...
GE 25942 dial tone problems
After waiting for over 24 hrs for an answer from FixYa and then they wanted $10.00 and trying to fix it myself, I gave up. Threw all that c$$p into a box, took it back to the store and got my money back. It just wasn't worth the time and aggravation.
Jul 19, 2008 | GE 25942GE2 Cordless Phone System
Searching....
The problem of searching.....
After trying all the technician's suggestions had failed; I disconnected the base to return it to the store for replacement. Then I decided to try disconnecting and reconnecting power and phone line, placed handset back on base and the phone reset itself and is working fine...
Recap:
Disconnect power and phone line from base for about 30 seconds and reconnect both power and phone line to base and place handset back on base; it should reset...
Linda
May 05, 2008 | Uniden DECT 6.0 Cordless Telephone...
Cordless phone keeps reading, "lift handset"
This would normally happen when the cordless handset was still in the charger stand. Are you saying it will still tell you to lift the handset after it's removed from the charger stand or base? I would not waste money buying a new battery as it is most likely not the problem but if you have more than one handset you should try swapping batteries. Removing and re-inserting the battery may reset the phone and clear up the problem as well.
Jul 05, 2007 | Coby CT-P8700 Phone (CTP8700)
Uniden DECT 6.0 Cordless Telephone Expansion Handset Logo
149 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
