Question about Canon Office Equipment & Supplies
I am unable to close the front cover on my ip4650 printer. How can I fix the problem, please.
Canon printers are always going wrong. It makes you doubt their cameras as well. Buy something else, though I can't suggest what!
Posted on Aug 23, 2012
3 Suggested Answers
SOURCE: " please close ink cover"
The cover for the Ink cartirdges has a switch on it. Try opening the cover, then close it again, the switch may be jammed. Try repeating several times if it does not do anything. If it is still the same case, then someting from the inside of the printer has caused the failure.
Posted on Jan 13, 2011
it said "close ink cover".
Posted on Apr 30, 2011
My copier marks open cover, please close the front cover is a savin 2055 dp
The front duplex cover has a broken door switch actuator tab, you need to replace the cover , see a dealer to either get part or have tech do it, it's an quick easy fix
Jan 05, 2017 | Savin Office Equipment & Supplies
How do i fix this "front/left cover open close cover"
Since you don't mention it I will assume that the cover appears to be properly shut. The sensor for this is likely a blade type or possibly a magnet type depending on the printer. Open the front cover and see if the plastic blade is present and enters the proper slot. If so then it is likely that the sensor inside is loose or has shifted so that the sensor no longer 'makes' when the covere is closed. If you are familiar with the disassembly of your printer you may wish to investigate and see if you can resolve. If not or if the unit is under service or warranty please contact the appropriate person.
Aug 11, 2016 | Office Equipment & Supplies
Fix error code C000
This error indicates that an internal error has occurred with printer, which may be resolved by resetting the printer. To help you reset the printer, please follow the steps given below:
-Open the printer's front cover, and then open and close the print head lock lever (do not remove the print head).
-Make sure all ink tanks are seated properly.
-Make sure all packing materials have been removed.
-Make sure no paper is jammed in the printer.
-Disconnect the printer cable from the printer.
-Close the front cover and turn the printer off.
-Unplug the printer from the power source, and then plug it back in after five minutes.
-Power on the printer.
If issue persists, it is recommended to contact your printer manufacturer for further help.
GuruAid.com
Apr 28, 2016 | Office Equipment & Supplies
Hp laserjet 5500 has close front covers when all are closed
Check for a sensor; out of place or missing or faulty.
Jul 14, 2015 | HP Color LaserJet 5500 Printer
My Brother MFC-8680dn keeps giving me a "Print Unable 72" error message. Any ideas how to fix?
According to Brother Solution Center:
The machine may not work properly because of the condensation inside of the machine caused by a temperature differential between the inside and the outside of the machine.
To clear the error message please follow the steps below:
  1. Keep the machine's power on and open the front cover.
  2. Leave the front cover open for 30 minutes.
  3. Close the front cover.
  4. Turn off the machine's power switch and turn it on again.
If you are satisfied, please rate or/and leave a testimonial. Thanks!
May 09, 2011 | Brother Office Equipment & Supplies
Message 'Clean Sensor' has appeared. Followed advise to open Cover D and close it again but to no avail. Has anyone got any other suggestions, please?
Follow the steps below to clear the "Clean Sensor" error message.
  2. Slowly close the cover again. c2600_close_cover_d.jpg This action will move the lever shown below and clean the sensor.
  3. Open and close the cover several times. Once the front cover is left closed the printer will start to calibrate.
Once complete, the error should no longer appear and the printer should resume normal operation.
Note: If the error message is still apparent after following the steps above, contact Epson for further advice.
Nov 16, 2010 | Epson AcuLaser C2600N Printer
The printer is giving me service error E527 what can be done to overcome this error
Hi Good day!!!
This error message "Service Req E527" means that the toner carousel housing the toner cartridges is obstructed, or is unable to rotate correctly. It can be caused by installing a toner cartridge incorrectly.
Solution 1:Check that the toner cartridge at the front of the printer is installed correctly.
Solution 2: Manually remove all of the toner cartridges.
Close all the covers, and then power the printer off.Open Cover B, and then remove the photo conductor unit (PCU).Turn the toner carousel by hand to line up a toner cartridge with the front of the printer.Open Cover A.If the toner cartridge is not in position to remove it, close Cover A and repeat the steps above.Remove the toner cartridge, and then close Cover A.Repeat all the steps above until you have removed all four toner cartridges.Reinstall the PCU.Close all the covers, and then power on the printer.Open Cover A and Cover B.Check thoroughly for any jammed paper, foreign objects or damaged parts.If you can locate an obstruction, remove it. Then, close all the covers and restart the printer again. If you can identify any damaged parts, there is an obstruction you cannot remove, or there is no change after restarting the printer, then contact Epson for further advice.Reinstall the toner cartridges (Follow the prompts on the LCD display), and then test the printer.
Don't forget to vote thanks!!!
Nov 02, 2010 | Epson ACULASER CX11NF All-In-One Printer
Unable to change cartridges no instructions with printer
Open the front cover.The carriage will come out.Open the covers and pull out the old cartridges.Then remove the tapes from new and pull in.Close all covers and follow the instructions on the screen of your monitor.
Sep 28, 2009 | Lexmark Z640 InkJet Printer
I have a service req E527 error on my Epson printer. how to fix?
To fix the E527 error, close the front panel (cover A) and open the top cover (cover B). With the photoconductor unit removed, the toner carousel will rotate. It only rotates if cover A is closed all the way. You can easily rotate the carousel to a position where you can remove/reinstall the stuck toner cartrdige. report_dis_text_13954 = 'We\'re sorry but you must be signed in to report inappropriate material. Click the button below to sign in or register.
  • Sign In / Register »
  • Cancel »
Jan 17, 2009 | Epson Aculaser C1100 Printer
Doc. Cover Open displayed
That usually means some sensor giving you trouble.
This is what brother recomends:
How do I clear the message Cover Open or Please Close Cover from the display?
The message Cover Open or Pls Close Cover may appear if the front cover
for the drum was not closed securely. Verify the cover is closed
securely by pressing the cover release button located in the front of
the unit below the Output Tray Support Flap and open the front cover.
Close the cover until it clicks into place.
If the message continues to appear on the display verify the drum and
toner assembly is installed correctly by following the steps listed
below:
1. Press the cover release button located in the front of the unit and
2. Remove the drum unit and toner cartridge from the unit by lifting it
up and out. Place it on a drop cloth or disposable paper to avoid
scattering toner.
3. Hold down the blue lock lever located on the right side of the drum
and lift the toner cartridge out of the drum unit.
4. Reinstall the toner cartridge into the drum unit by inserting it in
the drum until it clicks into place
5. Reinstall the drum unit into the unit. Make sure it is securely in
place.
6. Close the cover until it clicks into place
If that doesn't fix it, I guess you will have to talk to their support people.
Dec 15, 2008 | Brother MFC-8840D All-In-One Laser Printer
old marine
old marine
