Question about XRS 9330 Radar Detector
Everything sounds and lights up when I turn it on, but there is only a line displayed instead of the regular "L" ready symbol.
Today as I got back into my car, I turned it on and it went through the signals and then remained at the "ready" position as normal, however instead of displaying the normal "L" to say that it was ready, it simply looked like "_", like just the bottom of the L or a straight line. I noticed on my way home that all of the little detections that go off from electronic doors and the speed detector within my housing development were working, although seemingly strained, and that my display wasn't changing to tell the kind of band, never changing from the little line display.
I know the lights are all working because as I said before, when it starts up all of them light up perfectly.
I checked my manual and it says nothing about an error of this kind. Has anyone heard of this or know about what it is and what I can do to fix it?
Well, You have to press and release DIM button for 1 time (or 2x). that's all.
Posted on Dec 04, 2008
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
I black rectangle appears on the screen and finally dissappears after a few minutes. WHat is this?
This sounds like the closed caption is turned on and in the text mode instead of the regular closed caption mode. With the remote or in the main menu there is a way to change or turn off the closed caption. Regular caption is usually marked CC1.
Oct 21, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Doesn't heat anything
HI, there is only one in-line fuse link that is designated for the power board. this is concerning the Magnetron. this heating device has failed. replacing the Magnetron will fix this issue.
Jun 17, 2009 | Emerson Black Microwave Oven
Printing symbols instead of pictures
Uninstall and reinstall the drivers
May 12, 2009 | Office Equipment & Supplies
How do I switch from the green keys to my regular keys?
it sounds like you have turned on either your language bar settings and sometimes switch to another language, there is a function key you are hitting causing the keys to lock on that setting
Apr 01, 2009 | Acer Aspire 5920-6335 Laptop
Samsung 226bw weird display problems
At first you should clarify if your GPU or LCD is broken.
Do You have any chance to try another monitor with your Graphicadapter or to try your monitor on a different PC?
Moreover you should try it with a new cable.
The symptom of weird symbols sounds most likely like a overheated or wrong-plugged Graphicadapter
Nov 20, 2008 | Samsung 226BW Monitor
Clean machine/machine ready light won't go away
Have experienced the same problem for the last nine months. Was finally able to solve it today by following this guide: http://www.wholelattelove.com/articles/jura_capresso_cleaning_guide.cfm
Having cleaned the shower screen I ran the regular cleaning cycle and now the display indiucates "Ready" as it should do.
Sep 07, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Sound turns on when it wants to.
disconnect all of your speakers , then hook them back up one at a time when the radio starts to malfunction u have located which channel on the radio is bad.check ur wire installattion
Aug 30, 2008 | JVC KD-S5050 CD Player
LCD Display keeps flashing "INITIALIZING"
It needs to be plugged into a properly configured Avaya Definity digital port / wall jack. (NOT a regular telephone line as this can damage the polycom!!!) Does another Avaya digital phone work in that jack? If it does then call polycom for a RMA and eturn the phone under warrenty. If another Avaya digital phone does also does not work you need to check the PBX configuration or there is a wiring error at the jack or the PBX.
Jul 10, 2007 | Polycom SOUNDSTATION2 AVAYA 2490...
XRS 9330 Radar Detector Logo
258 people viewed this question
Top Cobra Vehicle Parts & Accessories Experts
John Nolan
Jason
Are you a Cobra Vehicle Part and Accessory Expert? Answer questions, earn points and help others
