Question about Philips DVD740VR DVD Player/VCR
A vhf tape got stuck in the machine. I could see the tape itself was caught on some moving prongs. now i don't know the proper setting for the prongs and cannot get any vhs tapes to play.
  • 577 Answers
Hi, if VHS tape is in you have only one solution..to disassemble DVD/VCR ..Can you do it ? you may try !!t
Here's how to do it..
* 1 Turn off the COMBO. and unplug it.
* 2 Remove the 4x screws off COMBO on the sides and take off the DVD/VCR casing.
* 3 Look for the Tape which messed up with VCR transport mechanism ,try to release tape of the transport with your hand..
* 4 Since EJECT feature works with power only ,while you keep the tape off from transport plug the device to power and turn it on..Don't worry,you will see the eject mechanism starts moving back on forth,keep the tape off it and let it eject..
* 5.When tape is out .If it destroyed badly normally you should not use it however if the recording in is valuable for you you can cut the chewed portion and
splice it back together .(Pls see the video included...How to fix a broken VHS tape.)
* 6 While it is open,place another Tape to see if mechanism works properly. and eject it...
* 7 Replace the casing and the screws. Plug the player in and turn it on. Now player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
http://www.youtube.com/watch?v=Q1PJWA2KGyg
Posted on Jul 12, 2011
Bobbin stuck
I'm guessing you're meaning the " bottom" or "seated" bobbin. Generally speaking, anytime a bobbin won't come up, it's because of a thread, broken part, button or some such other surprise. Could be a small cut-off that's just now gotten caught up or the thread from the bobbin is caught up in itself and the bobbin has "locked up." The other reasons could be...is there an additional locking mechanism, like you might have for the fabric foot. Do you see anything that could be a broken part or needle blocking the way. Just take a look around in there w a light that is stronger and/or more flexible, wiggle a thin screwdriver or something...could be the bobbin "jumped it's track." Try rethreading everything and see if you can get a forward stitch AND a backward stitch. Don't force anything if you feel any resistance, could be simply that you stopped and cut (again, little thread) at just the wrong part of the stitch locking process. And when all else fails, go in from under the machine, this might be a chore if you have a more sealed up bottom plate, but perhaps you can pop it (the bobbin) out from that angle. Just be careful not to force anything into moving and if you have one of the newer models wherein that area has moving parts that are plastic, be especially careful. When you flip it over, you just might find the phone number for direct tech support for that unit. Good Luck and Happy Sewing!
Jun 05, 2012 | Brother SE400 Computerized Sewing Machine
My jvc lcd shutt down every time and i dont know the rason
I can honestly say I have been quite happy with it and its performed pretty well with very few problems and is still going today.
First of all congratulations on getting so many years of heavy use (2002 - 2012) on your JVC VCR.
I have a HR-S3911U and a HR-S5912U from the same era and my 3911 has seen a million miles and both my units are still going strong. I did experience a similar problem with my HR-S3911U but instead of the eject function my problem was with a sticking guide-pin. I did a have similar ejection problem with one of my 1985 Super Beta Hi Fi machines. Really it sounds like the exact problem as you describe. What I did was I opened up the unit and watched carefully - it was just a sticking moving part. My JVC guide-pin problem was just sticking as well - after a gentle push into place the guide pin has not stuck since. I don't suggest using any grease unless you really have to. I suggest you open the unit - if you have a video camera video tape the ejecting and play back in slow mo to see if you can catch the problem. Sounds like a sticking moving part which can be common on any VCR.
..couple times its had issues with dirty heads as i would get a message appear on screen.
I'm very surprised that in the past you had "dirty heads" messages pop up on screen as I have never seen that message on my JVC machines and I do use them a lot and very rarely clean the heads. Proper tape storage is very important. Trying not to use the same tape over and over again also helps keeping the tape path reasonably clean.
I think it could benefit from the heads being cleaned. I don't even really know what are the heads. Is it that big round drum? One thing I did notice is that when I load a tape, it straight away wraps the tape around that drum and the drum spins away and just idles there constantly rubbing on the tape before i have even pressed play. I have left tapes in there for days and days, so I assume this cant be good having that thing spinning away on the tape for such a long time?. I am not sure if this is normal or not but I wont be leaving tapes inserted in the VCR long periods now.
The heads are tiny little things inside the big round drum. I will show you if you post a picture of your unit with the cover off.
The tape staying wrapped around the drum with the drum spinning is normal but the drum should stop spinning five minutes after you load the tape as long as you don't touch play, rec ,ff or rewind. This is called a "long pause" (the tention is a little eased and is not rubbing hard as a normal pause would) and the long pause is there so the unit will immediately start playing or recording if you push play or rec within 5 minutes of loading the tape. If the drum does not stop after 5 minutes of sitting idle then your VCR has a malfunction and you should not leave tapes in the machine idling.
I am concerned about your heads clogging up - that is not normal unless you don't take proper care of your tapes - is there very high humidity in your area? That could cause problems.
Sorry I posted this in a hurry but will go into more detail later if need be.
Porsche Parts.
May 27, 2012 | JVC 32 Class 1080p 60hz Lcd Hdtv - Black...
I have a sylvania VCR/DVD combo and the VCR has trouble playing my tapes. It gets stuck and then the tape gets caught and I have to take the top off to get it out. I also have a sylvania TV with VCR...
i suggest you to buy a Maxell VP-100 VHS Dry Tape Video Head Cleaner, the head of the VCR is dirty that cause the tape get caught or stuck. hope this help you
Jun 06, 2011 | Sylvania DV220SL8 DVD Player/VCR
I have a sony TC-660 reel to reel player, it had been in great condition, and i love using it. All of a sudden however, the reels will ONLY move in one direction (clockwise for the left, and counter...
In order to maintain tape control and tension the reels always pull lightly in opposite directions during PLAY mode. The capstan moves the tape in the desired direction at a precise speed. If the capstan doesn't engage the tape BETWEEN itself and the pinch roller you'll get the reels battling over control of the tape. Check the tape routing.
May 25, 2010 | Quantegy 456 Reel-To-Reel Recording Tape
The machine is hard to use and damages the tape , the foot pedal is stuck
Hello use a Q tip with alcohol and clean the metal pin in the center of unit close to the head make sure don’t put a tape when you do it make sure the spindle move too otherwise the unit will eat the tape if your pedal is broken her is a replacement http://www.tvps.com/Products/ECS-Sony-IN-25-Heavy-Duty-Foot-Pedal---New__VE-IN-25.aspx
Dec 01, 2009 | Sony M-2000 Desktop Cassette Transcriber /...
Wheel is not setting up to type correctly
The keeys were getting caught in the plastic guide. Tood guide off and now no more problem!! Thanks anyway!!
Jun 03, 2009 | Swintec Office Equipment & Supplies
Raytheon 80 VHF
Look for harness connectors at St.Vincent DePaul
Mar 17, 2008 | Radio Communications
No cable
try going into the menu of the tv and changing the tuner type from ANT to Cable
Jan 28, 2008 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Toshiba M-752 Video Casette Recorder
Take the top cover off, and see if there is an obvious reason for the no-eject, as in tape spooled out and wrapped around something. Next, is the tape drawn back into the tape housing? Under normal operation this is done before eject. A defect in the tape itself, or in the VCR mechanicals can cause a no "pull in" condition. Otherwise, you could carefully try to assist an eject- push eject, lift lightly on the tape. Sometimes the entire carriage mechanism can be removed with tape in place, but often, screws holding this in place are obscured by the tape, and, if carriage is gear driven, proper gear alignment must be reestablished. This can be a tricky problem, getting tape out without damaging anything, especially since late VCRs are made rather fragile to start with.
Aug 14, 2007 | Toshiba W522 VHS VCR
VHS carriage stuck
THERE IS A SENSOR SWITCH THAT TELLS THE MACHINE THE TAPE IS LOADED ... SOUNDS LIKE IT IS STUCK. PROBLEM IS ACCESS WITH COMBO'S. THEY ARE A PAIN TO GET AT. THE WHOLE BACK COVER TO THE TV MOST OF THE TIME HAS TO BE REMOVED,... I KNOW ITS NOT MUCH HELP BUT THE MANUFACTURES KNOW THAT... HOPE YOU CAN GET TO THE TRAY INSIDE. Joe_Rex
May 01, 2007 | Sylvania SRCD227 27 in. TV/DVD Combo
Philips DVD740VR DVD Player/VCR Logo
236 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
