Question about G7 Productivity Systems VersaCheck Gold 2005 (vcg5-2067) for PC
I wrote down my key as 1Kl01-NP13D but is says invalid when I enter it.
Invalid username
re register with a different name
Feb 02, 2014 | Computers & Internet
Invalid cd key windows XP
Make sure that you enter it EXACTLY as the key reads. All capital and lowercase letters, O and 0 look similar, B and 8 look similar. Try it with dashes and without dashes.
Good Luck!
Jun 03, 2012 | THQ Red Faction Guerrilla for Windows
I tried making a pin code for my lg GU29of model and it asked me what the default one is i typed what it said and it kept saying invalid pin after saying invalid a few times it switched me to puk code and...
Your PUK is listed on your account. You can call your customer service and they should be glad to provide that for you.
AT&T allows you to check that yourself if you log into your account online.
It's a rather long number so make sure you can see it clearly, or write it down before you sit down to type it in. NOTE: You only have 10 attempts to enter the PUK before it will lock your SIM permanently and you'll need to purchase another SIM to replace it.
Before trying the PUK (which is a PIN Unblocking Key), power your phone off and then back on. Then enter the PUK. Once you enter the correct code it'll ask you to enter a NEW PIN. Remember that one as that will be your new PIN.
If you get it wrong enough times it'll go to the PUK again.
Dec 18, 2010 | Cell Phones
What am I doing wrong?!?!?! I just bought an RCA Universal Remote. I'm following the direction to program the remote. It says to press down on the component key and enter the code afteryou press the...
Manually turn on the TV.
Locate the TV Code list provided with the remote
Find your brand. It might have several numbers to choose from.
1. Press and hold the TV key. The Indicator Light blinks, then remains lit.
2. Use the Number keys to enter the first 3 digit code. If you enter it correctly, the TV indicator
Light will turn off. If it doesn't, then you entered an invalid number.
Note: If you enter an invalid code the LED will flash rapidly for 2 second. Start over at Step 1.
3. Aim the remote at your TV and press the ON-OFF key. If you've entered the correct code the
TV will turn off. If it doesn't, restart process at Step 1.
If you follow these carefully and it doesn't work, you might have a defective unit. Be sure the code numbers are correct.
Oct 27, 2010 | RCA Universal Remote Control
Lost my internet, wont load so need settings please
  • Navigate to your cellular provider's website or call its customer service line. Access the "Support" section of the website or ask for the technical support division. Find the "Access Point," "MMS" and "Wap Gateway" settings and write them down.Power on the HTC phone and then press the soft key on the left side to bring up the main menu screen. Scroll down through the menu and highlight the "Settings" option. Press the square button at the center of the phone to access the settings menu.Choose the "Connections" option from the settings menu. Scroll down through the new list that will appear and choose "GPRS." Highlight the "New" option and press the center button. Choose "Connects To Internet."Scroll down to the "Internet" heading and choose "Change." Key in the Access Point that you wrote down earlier. Scroll down and press "Done.Navigate back through the menu to the "GRPS" option. Press "New" again, and this time, choose "Connects To Wap." Choose the "MMS" option. Key in the MMS settings you wrote down earlier.Return to the main menu screen and then select "Messaging." Highlight "MMS" and press the right soft key to bring up a second menu. Choose "Settings," and then choose "MMSC Settings."Press "Edit" and enter in the "MMS" settings again. Scroll down to "WAP Gateway" and enter in the information you wrote down earlier.Power cycle the phone by turning it off and then back on to complete setting up the WAP settings.
  • Oct 01, 2010 | HTC Cell Phones
    I have accidentally turned the child lock on and then turned of the tv and when i switch it back on it comes up locked on the screen and none of the buttons respond and i do not have the remote controll...
    Get a Magnavox (or Philips, same company) brand universal remote and try this. I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set), so I don't know if really a solution.
    Philips sets use 0711 as the override code to defeat parent lock. You may need to enter the code twice if it says "invalid code" the first time.
    Using the remote control:
    Press the MENU key. Scroll up or down until you reach AUTOLOCK or SMARTLOCK. Press the "right arrow" key. Enter code 0711. Enter it again if it says invalid code.
    Once in the AUTOLOCK or SMARTLOCK menu:
    Scroll to BLOCK. Press the "right arrow" key. Scroll to BLOCKING OPTIONS. Press the "right arrow" key. Scroll to MASTER DISABLE. Press the "right arrow" key. This should unlock the parental control.
    Hope this works for you. Thanks for using Fixya!
    Mar 12, 2010 | Philips 28PW6305 28" TV
    I have a philips magnavox ms2730 c tv 27 inch , my parental lock is enable but i didnt enable it and i cant get it turned off, i was hopping i couldnt find a default password .
    I found this info at a tech website, but I haven't tried it myself (never have used parental lock on any set).
    Mar 05, 2010 | Philips MS2730C 27" TV
    My product key is invalid.
    Uninstall the software.Reinstall and activate with the key.
    Jul 17, 2009 | Dell Studio Desktop
    I have cd key. but when i enter it ,it says INVALID .
    I have found nero9 serial key bcz our nero9 serial key is invalid
    Mar 08, 2009 | Roxio Easy CD & DVD Creator 6...
    Invalid product key error
    what is you operating system?
    Dec 01, 2007 | Acer Aspire 3680 Laptop
    G7 Productivity Systems VersaCheck Gold 2005 (vcg5-2067) for PC Logo
    26 people viewed this question
    Top G7 Productivity Systems Computers & Internet Experts
    Jax Planet
    Jax Planet
    Terry Hair
    Are you a G7 Productivity Systems Computer and Internet Expert? Answer questions, earn points and help others
