Question about Craftsman 20 hp 42 in. Deck Yard Tractor
I have a 20 hp Craftsman mower that has sat for two years. I did a basic fluid changes: oil, gas., and filter. It was hard to start, but would only run unevenly with the choke pulled fully out and full throttle. I opened the fuel bowl and the float seemed to move freely. I checked the plugs, they looked clean. However, it had no power to run the blades (stall out). It would run strong, when I spray carborator fluid in to the carb. The fuel filter fills up only about 1/2 way and the fuel pump squirts strongly. Any thoughts? Thanks.
  • Nelson Bartley Mar 27, 2011
    I decided to take it in to a small engine repair shop and they fixed it by only changing out one of the two coils; one was firing very weakly. None of your solutions were in the ballpark.
    Brigadier General:
  • 4,044 Answers
You need to have the carb cleaned or rebuilt and more than likely replace the fuel tank if you have a tank under the seat. That long fuel hose gets gummed up easily when it sits for long periods if gas is left in the tank. This is also the problem with the carb. The gas that was in the carb when it was stored dried out and gummed up the float and needle valves. The cleaner that is added to the fuel tank won't do the job, it isn't strong enough and you can't get enough to run through the carb to do any good.
Posted on Mar 13, 2011
  • James Young Mar 27, 2011
    I appreciate the information. Typically the troubleshooting process starts at the Carb and goes out to other systems. Without being able to test personally we have to start somewhere and sometimes it works out that we aren't right with the first solution. Again, thanks for the information.
Mower can not start
Does it have spark? Does the engine get fuel? If you spray starting fluid into the air filter will it start up?
Sep 20, 2016 | Craftsman 675 Series 190cc 22" Briggs ...
Craftsman riding mower starts rides a few minutes then stops
Make sure that when you check the oil that the mower has sat I say for at least 5mins. Your mower might have an oil sencer. If not I think it might be the coil gettin hot and shorting out.
Aug 23, 2009 | Garden
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Won't start at all
your air filter could be clogged. Also, you can remove the plug and spray a small amount of starting fluid in and replace plug and see if it starts.
Jul 04, 2009 | Craftsman Garden
Craftsman riding mower shuts off after approx 20 mins of use.
ran into this problem twice this season, about drove me crazy - finally traced the problem to the anti-backfire solenoid [the little cylinder at the bottom of the carburetor that holds the float bowl on] - after running fine for 20 minutes or so [it varied], the coil would release the plunger and shut off the gas flow. as soon as you turned off the key and turned it back on, it would start back up - replace the solenoid and problem vanished
Jun 10, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
My craftsman rotary lawnmower wort start i changed the spark plug
a mower will hold 20 oz of oil. however most times it is changed you do not not get it all out. so only 16 oz is needed. if you overfilled the oil. this would cause hard starting. or did you have the mower tipped on it's side for to long, oil can sometimes seep past the piston out thru your intake valve and into your carb as well as destroy you air filter. you might get by with a new oil change and a carb cleaning.
also has this unit been sitting for a while does it have fresh gas. and No water in the tank/carb
Mar 16, 2009 | Craftsman Garden
Not getting gas to combustion chamber, leaking gas from exhaust
Definitely the carburetor. Take it off and look for something clogged. Look carefully at the gaskets. Look for water and dirt in the float bowl.
Nov 23, 2008 | Craftsman 20 Hp 42" Deck Lawn Tractor
Craftsman 20 hp 42 in. Deck Yard Tractor Logo
42 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
