Question about Dell Inspiron E1505 Notebook
I cant retain my operating system hard drive what do i do?
  • 4 Answers
You will have to reinstall. The manufacturer (Dell) should have either provided you with a disc you can insert, or a recovery partition to install from. If you cannot find a disc, turn your computer on and immediately you should see a Dell logo, and on the bottom of the screen are some instructions. It will say something like f2 for startup or similar. Find the key combination for "recovery" and press it. Follow the on screen instructions.
If nothing here works, contact Dell and request a recovery disc for your operating system.
Posted on Mar 13, 2011
Can I change my windows 7 computer to XP with an XP disk
yes --
But you will loose all of your files and folders when you format the hard dive to install win xp
you cannot run 2 operating systems on the one hard drive unless the hard drive is partitioned ( in effect having 2 hard drives on the one disc) as it causes massive conflicts in operation
Why any one would install an out dated , unsupported operating system like win xp in place of win 7 beats me
of course if you insist in doing it you could always install and extra hard drive in the computer and run it as an extra hard drive and install the win xp on it and still retain all of your files and folders
Sep 09, 2017 | Computers & Internet
I have an Asus Eee pc R101D netbook, Cant get it to fully boot up, operating system is Windows 7 Starter, I have no Re-installation Disc, Also cant get my external Disc drive to work from the USB slot, I...
your operating system is located on the hard drive if you still have the old one and it works put it back in make a back up copy on cd remove and reinstall new on and load operating system to new hard drive.
Mar 11, 2015 | ASUS Computers & Internet
I have Hitachi Deskstar 7K160 HDS721616PLA380 160 GB SATA Hard Drive bios is detected but we cant format
If the operating system can't format the hard drive then the chances are that the drive is either failing or Failed.
Mar 19, 2012 | Hitachi Deskstar 7K160 HDS721616PLA380 160...
I wish to Upgrade My HP Pavilion ZD8230US 100GB ATA HDD to one that is faster and has more Maybe as high as 500GB. SATA type drive would be great to have but unsure if I can install SATA Drive in this...
yes you can upgrade your hard drive but still on ATA,if you upgrade in SATA you need some converter from ATA to SATA .and since it's a laptop i think its hard to do that thing.
Sep 13, 2011 | Computers & Internet
MODEL IS VAOI VGN-NR21M_S HARD DRIVE FAIL, CANT INSTALL NEW OPERATING SYSTEM ON NEW DRIVE AS WINDOWS NOT PICKING UP NEW HARD DRIVE, IN BIOS THER IS NO OPTION TO SET IT TO AUTO DETECT, HELP!!
Hi !
For some reason, some hard disk will be damage due to bad sector and you cannot do anything about it not reinstall any operating system.
If the Hard Disk Drive failed to install the operating system, the hard drive is damaged and cannot be reformat. The only solution is to replace new Hard disk drive to install the operating system.
Jan 07, 2011 | Computers & Internet
My macbook has a grey screen with a file and question mark
This means it can't find the operating system. Try taking RAM chips out and re-inserting firmly. Also, make sure you got the right kind of RAM chips in the two slots as Macs are picky. Also, make sure you got more RAM memory than you need so the Mac will run super fast. If none of these RAM tricks help, then re-install the operating system by doing an archive and install so you can retain your data. Alternatively, you can take the hard drive out and insert it into an external drive case, then install a new hard drive into the laptop, and do a clean install. Then you can extract the data from the old external hard drive.
Nov 06, 2010 | Apple MacBook Mac Notebook
Hi guys..i got a problem with my laptop cq40.i cant install vista os.3 type os i had tried.but none of them can install.otherthing,is it my cq40 cant use windows xp sp3?
you may need to format your hard drive before installing any operating system on your laptop. also try removing the hard drive, use an ide/sata adapter and connect it via USB or install inside another computer.
use THAT computer to format your hard drive and install your operating system initially and then remove it and place it back in the laptop to finish the process.
Nov 26, 2009 | Compaq Computers & Internet
New hard drive operating system loaded, now cant find hard drive
check the cables it properly connected or not. after start up press F8 key to check the installed hard drive is detected or not. if it is not, check with BIOS settings
Thanks Good Luck
Appreciate to rate as "Fixya"
May 09, 2009 | HP Pavilion ze2000 Notebook
Partmgr sys
did the computer originally come with windows xp or an older operating system?looks like you may have some hardware issues.download ultimate boot cd from this link.Follow the directs to burn the image to disc.Boot from the CD and run memtest to check your memory,then run any of the hard drive diagnostic tools from the hard drive manufacturer.Let me know what happens after that.If none of the hardware fails I will recommend using one of the hard drive formatting tools to do a low level format on your hard drive and try installing the operating system again.note,if you have files that you need on the hard rive you'll lose them if you reinstall the operating system without backing them up.
Aug 21, 2008 | Computers & Internet
Dell Inspiron E1505 Notebook Logo
Alun Cox
