I have a turntable/8-track/stereo console. The turntable does not work. It there a manual I can purchase? The 8-track may not work either...I don't happen to have one to try.
  • 336 Answers
Need the Make and Model.
Posted on Mar 13, 2011
Does old Zenith Allegro Console Stereo - 8 track/AM/FM/turntable, have a belt drive phono? I can see metal gears to drive the stuck turntable .
The manufacturers of such items would usually buy in such hardware as record turntables from fairly standard catalogues.
One popular brand of turntable was the BSR but the design of other brands were similar. The metal gears aren't for driving the turntable but to drive the multichange mechanism so when one record has finished playing another will drop from the stack loaded onto the extended centre spindle.
This type of turntable is driven by a synchronous motor with a multidiameter spindle via a moveable idler wheel equipped with a soft rubber tyre. Lack of maintenance causes many problems and as the rubber tyre ages it tends to harden and lose traction on the inside of the steel turntable so when the record reaches the end and the metal gears engage there is insufficient torque and everything stops.
It is for that reason many older examples have had the multichange removed or disabled.
Removing the turntable centre motif should reveal a circlip which when removed will allow the turntable to be removed for maintenance.
Jun 07, 2017 | Zenith Televison & Video
Can my turntable be adjusted
Jody, the arm the needle is on, usually adjustable with a dial on the end that can lighten, or put more weight on needle to help it track better on records. Other then that, the belts normally are changed to address slow speed issues. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Jensen JTA 220 Instruction Manual Page 2
http://audio.manualsonline.com/manuals/mfg/jensen/jta220.html
How To Calibrate Your Turntable For the Best Possible Sound
How to Adjust Tracking Force
Apr 09, 2016 | Jensen Jta-220 3-speed Stereo Turntable...
Clarinette 107 stereo cassette 8 track and record player. stereo works, but record player will not work. how do i find the problem?
I'm assuming you have a belt driven platter. Lift up the rubber mat, turn the platter it to where the motor spindle is, and see if the belt is still on. For more information or further questions, please visit my website at audioserviceclinic.com. Thank you.
Dec 12, 2013 | JVC AL A158BK Turntable
I have a problem with a Sansui turntable
Linear tracking tonearms probably don't move much under manual control. It would still help if we knew the model number.
May 17, 2010 | Audio Players & Recorders
Daytron All in one Turntable, 8-track & fm
if the turntable is belt driven.... try replacing it... maybe the belt is worned out
Jul 19, 2009 | Audio Players & Recorders
Zenith Allegro console stylus
I have the same model with the 8 track player, original manual, and original receipt dated 1975.
Jul 15, 2009 | Audio Players & Recorders
Philco Console On/Off Switch
It sounds like the knob part has has lost grip on the spindle of the switch, due to age. The knob part is designed to pull off (though sometimes they have an allen screw to keep them on) for service. You could try and pull it off! However it could (due to its age) have decayed and so might break up. If you do try to pull it off, turn it to the off position and when you put it back on put the knob pointer at the off point.
However it is safe to operate at the present.
On the 8 track the fixes and myself would need to know more details. Like: does it play, can you put a tape in etc, before giving a verdict.
Jun 25, 2009 | Audio Players & Recorders
Replace needle on old Admiral turntable
what type of needle does a gemini turntable need?
Apr 14, 2009 | Audio Players & Recorders
SX-1600 + KD-491F
Hi again,
It would seem that you posted the problem here also. With your kind permission, I will repost my excerpts of my responses that others may benefit on similar concerns.
A. Most current receivers no longer include a PHONO input. Perhaps what could be done is to purchase a phono to line level pre-amplifier to go along in your purchase for a new receiver.
I was made to understand that the Pioneer SX-1600 is prone to speaker output problems which could either be:
1. the speaker relay (protection); and/or
2. the amp, STK4191II Stereo Module.
Either should be relatively easy to work on and perhaps you can try the services of a locally available qualified electronic technician since the repairs would not be too specialized. The service manual may be of help (or at least a schematic , they may be downloaded from here and here).
B. To recap what you need is a receiver that can accommodate:
4 - Pioneer S-DF1-K (15-100W, 8 ohms)
1 - Pioneer PD-F407 25 Disc CD Player
1 - Pioneer CT-300 dual tape deck
1 - Kenwood KD-491F turntable
C. Possible choices are (keeping in mind that the power output should be less if not equal to 100 watts and a turntable/phono input):
i. Onkyo TX-8522 Stereo Receiver;
ii. Yamaha RX-397 100 Watt Natural Sound AM/FM Stereo Receiver;
iii. Sony STR DE695 AV receiver;
iv. Teac AG-790 200 Watt Stereo Receiver;
v. Denon AVR 888 - AV receiver - 7.1 channel.
Some of the above also includes feature(s) to hook up to your video system. Some may even require a fifth speaker (subwoofer).
Incidentally, you can also choose another brand/model even without a turntable/phono input. As initially posted, a turntable/phone to line level pre-amplifier is only required. Here are some examples:
a. XP200 Turntable Preamp - Nano Series;
b. Pyle® Pro PP999 Phono Preamplifier;
c. Pro-Ject Phono Box Turntable Preamplifier;
d. Radial J33 RIAA Turntable Preamp Direct Box
Good luck with your project.
Apr 29, 2008 | Audio Players & Recorders
81 people viewed this question
 Grubhead
Grubhead
