Question about Sony Playstation 3 (PS3) Console
Can you use a HP computer monitor with a Playstation 3 console instead of a TV?
    Problem Solver:
  • 11 Answers
It all depends on the monitor.
If it have a HDMI plug or video component it would work just fine.
Posted on Mar 13, 2011
Mate has brought his ps3 around it is set on hdmi but i dont have tv have the av leads but screen is blank
  1. While the PlayStation 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PlayStation 3 beeps twice (approximately 5 seconds), then release it.
  2. The PlayStation 3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Aug 14, 2010 | Sony Playstation 3 (PS3) Console
No video or sound
  1. Make sure the HDMI cable is connected to the HDMI OUT port on the back of the PLAYSTATION 3 system. Connect the other end of the HDMI cable into the HDMI Input port of the TV or display monitor.
  2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive power button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light --> green light --> then back to red light). This will ensure that you have held down the power button long enough to reset the Video Output Settings.
  3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).......
Jun 30, 2010 | Sony Playstation 3 (PS3) Console
My TV screen says that ( not supported mode) and I have the play station on HDMI2
"no signal" showing on tv screen
Jun 29, 2010 | Sony Playstation 3 (PS3) Console
I have a playstation 3. there is power but no communication with tv. i have tried new rc cables as well no luck please help. tnx
Jun 28, 2010 | Sony Playstation 3 (PS3) Console
Everything is hooked up and the ps3 turns on but it doesn't show up on the T.V
Jun 27, 2010 | Sony Playstation 3 (PS3) Console
PS3 Display settings issue
Carry out the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Nov 09, 2009 | Sony Playstation 3 (PS3) Console
Use HP screen as a tv screen for playstation 3
Unfortuantely, some computer have ouput plugs only. What this means is that they send signal to external source only such as another monitor or tv..check all the plugs to see if it says input/out
I am pretty sure it only transmit signal.
I hope this helps.
Apr 10, 2009 | HP Pavilion DV5234US Notebook Laptop
HDMI green screen
1-HDMI is available in several versions. The PLAYSTATION 3 is compatible with HDMI version 1.3 or higher, which will take full advantage of Blu-ray Disc™ high-definition video. There are also "Type A" and "Type B" connectors. The PLAYSTATION 3 uses the 19-pin Type A connector, which will allow resolutions up to 1080p.
The HDMI cable is not included with the PLAYSTATION 3. If you are using an HDMI to DVI converter, you may wish to remove this adaptor.
2- The resolution output (i.e., picture quality) of the PLAYSTATION 3 will depend on three factors:
The type of cable used and the inputs available on the TV or display monitor.
The maximum resolution the TV or display monitor can support. The PLAYSTATION 3 can output two types of resolution: HD and SD. Refer to the TV or display monitor's owner's manual to check which video modes are supported.
The maximum resolution programmed into the source material (movie or game). Refer to the software packaging for information on maximum resolution details or contact the publisher directly.
3- Try connecting with the supplied AV Cable instead of the HDMI to see if you can get a successful installation. This will help determine where the problem may be with your particular HMDI setup and/or equipment.
4- Disconnect any coaxial cables at the point closest to the television. Signals sent through coaxial cables may cause interference with the sound and picture outputted from the PLAYSTATION 3 which results in buzzing and humming noises from your display and speakers.
Nov 29, 2008 | Sony Playstation 3 (PS3) Console
Connecting It to my Flat LCD monitor
There's a connector that costs like $80 on ebay. Good luck trying it out. I almost did, but ended up getting an HDTV instead. Good choice, I'd say. Good luck!!
Mar 21, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
