Question about Zyxel Prestige 660R Router (P660R)
My wireless router from Zyxel reset and is not on my home network any more, it is broadcasting an unsecure signal, how do I get it back on the network? FYI I have two routers one in the basement and one on the third floor, they are connected to the internet through eithernet phone jacks. The one upstairs is the one that reset and now broadcast a completely new unsecure signal. I tried getting to it by typing in http://192.168.1.1 but I get a error from google.
  • 345 Answers
Zyxel does use 192.168.1.1 for default ip but in order to get in to settings you have to be pisicaly connected to it via ethernet cable. Once you connect to it type that ip and user name will be admin and password can be few things. First i would try to leave it empty, if not try admin lower case, if not try 1234, if not try word password. Once in the router just rename you network or other name for it is SSID to what ever it used to be called and make sure you choose secure connection and put in pin as it used to be. Hope this helps.
Posted on Mar 13, 2011
    Scholar:
  • 97 Answers
The easiest way to be able to access the router settings in this case, will be to provide a direct connection between your PC and the Zyxel router (using a network cable) and then type in that address.
If the address still doesn't work, double check the router's IP address by opening the Command Prompt (it's under Programs -> Accessories) and typing in "ipconfig", then hitting Enter. The IP-address you're looking for is listed under "default gateway".
(Also, make sure your computer isn't using a fixed IP, set it up so it's dynamically assigned an address by the Zyxel router.)
My compaq presario v2000 laptop cannot detect the wifi signal of Zyxel router. It can detect all other router brands. I'm sure that my Zyxel router is sending signal because I can detect it using my...
I would guess that all the other wireless routers are broadcasting using the G wireless standard 802.11g and your router is only broadcasting using the newer N 802.11n standard. Your laptop only supports B/G. Check your settings on your router and either change it to G or dual G/N mode so your older laptop can find the network
Sep 17, 2011 | Zyxel Communications NBG416N 11N 150N Wlan...
Laptop stopped connecting via wifi to home network.
The wireless settings in the Belkin has been setup with encryption.
You can restore the Belkin back to the factory default by powering up the Belkin and press the RESET button for 7 secs.
It is not wise to leave your wireless router unsecured, anyone can access your network and Internet connection and use up your allocated download limit. Once you exceed your download limit you could be slug with addition charges - this depends upon your contract with your ISP.
For details on securing your wireless router and configuring the wireless card in the laptop, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Dec 31, 2009 | Belkin (F5D7231-4) Wireless Router
I got a new router (Netgear W..8.)for my home
try puuting the wireless access point on the middle and atleast 5 ft of the ground this will increase your signal slightly also make sure that there is no cordless phone especially the base near the wireless access point.
Sep 15, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
Laptop does not detect wireless from Zyxel 660 router
Dear! You will have to enable wireless conection to access the router and internet. Check your adapter settings and enable wireless conection. Your problem will be solved.
Thanks
Jul 28, 2009 | Zyxel Prestige 660HW Wireless Router...
Setting up wireless for the first time. what's
you need to use station mode and it`s not like it`s unsecure.every network in the beginning is unsecure but you have to secure it using wep or wpa.take care
Jul 06, 2009 | Zyxel G-220 802.11g/b Wireless Adapter
Lenovo laptop cannot seem to find the linksys wireless g. we have two WIFI at the office one is linksys VOIP (secure) and linksys wireless G (unsecure). why is it that lenovo laptop only sees the secure...
make sure that the linksys VOIP(secure) router is broadcasting it's SSID or signal, otherwise it will not reflect even if you refresh the wireless network. If the router is broadcasting SSID but the lenovo laptop is not detecting it, try to re-install the wireless software for the laptop using the software from lenovo.com, just click Support then Downloads and drivers.
May 13, 2009 | Linksys Wireless-G Broadband Router
HELP!!!!!! Trying to enable wpa-psk security on my laptop?
You should set the security on your computer wifi card to wpa-psk and then type in the securitycode which is written in your Zyxel Router.
If this is not possible with your networkcard, change to wpa or wpa2 inside the Zyxel. And do the same procedure with your networkcard, when detected the Router.
May 04, 2009 | Zyxel P660HW-D1 Router
Can't connect my Ipod touch to my router?
You must be sure to what router you are trying to connect. I understand you have a ZyXel and a linksys. You must have 2 wireless networks. Your wireless network must be secured, so you just have to use the correct password. I need more details. Try this http://technicalsupport.blog.friendster.com
Feb 08, 2009 | Linksys Wireless-G WRT54G Router
Problem maintaining wireless signal
Changing channel wont help,you should use specific ip setting then automatic ip setting
Jan 19, 2009 | Dell TrueMobile 1184 Wireless Broadband...
WIFI Connection
Ensure the router is able to broadcast b + g radio signals, select it to do both rather than just one or the other.
Mar 15, 2008 | MSI Wireless-G RG54G3 Router
Zyxel Prestige 660R Router (P660R) Logo
216 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
