Question about Optimus STAV-3670
I HAVE A OPTIMUS STAV-3770 RECEIVER AND HAVING PROBLEMS HOOKING UP SURROUND SOUND TO MY NEW LG 42" 42LD550 SYSTEM. CAN'T GET AUDIO OR VIDEO THROUGH MY DVD PLAYER. ANY ASSISTANCE WOULD REALLY BE GREAT. THANKS,BENNIE WALLS
  • 2 more comments
  • brwalls Mar 13, 2011
    i also can't get any audio from surround sound system for tv
    DVD PLAYER NOT ONLY CONCERN, NO SOUND AT ALL COMING OUT OF SURROUND SOUND FROM TV
  • brwalls Mar 19, 2011
    THANKS PAUL, DVD PLAYER WORKS,SOUND AND PICTURE COMES THROUGH TV. I CAN NOT GET ANY SOUND THROUGH MY SPEAKERS ON MY STERO, IT WORKED ON MY OLD TV. IS MY STERO TOO OLD AND DOESN'T HAVE THE SAME HOOKUPS?
  • brwalls Mar 24, 2011
    GOING TO GET NEW SURROUND SOUND. THANKS ANYWAY
  • 592 Answers
Hi, Bennie.
I am going to take a try at helping you out with this today.
First, make sure that the DVD player works.
Attach it up to another tv, and make sure you get both audio and video.
If you do, then we go on to the next part.
If not, then the player has the problem.
Let's say that it works on the other tv, ok?
So, if that is the case, then it may be something as simple as having the input settings wrong on your receiver.
Sometimes, this can be from static discharge, other times bad cables.
Also, make sure that tape monitor 2 is not turned on, if it is you won't get anything out of your receiver unless the sound is run through the tape 2 jacks.
There also may be a burnt out fuse, or connection inside your old receiver that has gone and bit the dust.
After all, the receiver model you list was originally made in 1999, so it is well past life expectancy for it.
I know this may or may not be what you were wanting to know, but I tried.
I hope that it does help you in some way, and good luck.
Posted on Mar 14, 2011
    President:
  • 1,768 Answers
1. check the user manual for the DVD player and the setup for sound via your surround sound device.
2. check the cables to the DVD player and the RCA connectors
Posted on Mar 13, 2011
    Brigadier General:
  • 3,513 Answers
Hi
An hdmi cable is an easy one cable connection for both audio and hd video to your TV so its working perfectly. if you have a home theatre audio system that is separate from your TV, you will need to hook that up as well. You will need to plug in a cable from the audio output on your DVD player to an audio input on the receiver box for your sound system.
Does the cable box have any other outputs? They should be active. In particular if there are RCA connector outputs (looks like round silver connectors that protrude from the back of the cable box, generally three in a row with one colored red, one colored white - they are the audio - and one colored yellow for the video you won't be using) they would need to be routed to your stereo. If the cable box doesn't have outputs either then you're going to need another box, like the VCR you don't want to use.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Mi receptor optimus cuando enciende aparece power off y se apaga en pocos segundos
tengo un problema con mi stav-3770 y cuando lo enciendo me dice power off que debo hacer en ese caso ??
Jan 08, 2013 | Optimus STAV-3770 Receiver
When I turn on my receiver the "overload comes on ant it cuts off!
You were lucky the overload protection circuit kicked in, congradulation on finding it.
Mar 14, 2012 | Optimus STAV-3770 Receiver
How do I set up the surround sounds to my T.V. using the optimus 3770 audio reciever?
Does your TV HAVE surround sound? THAT would be different.
Some simple text intructions for thge receiver...
http://support.radioshack.com/support_audio/47464.htm
Feb 04, 2011 | Optimus STAV-3770 Receiver
When I turn my optimus STAV-3770 on it reads poweroff and then cuts itself off..please help me
unfortunately most stereo mfgs. install a protect (shutdown) citcuit if it detects an internal short (bad amplifier )or a external short( bad speaker)....disconnectl speakers see if it still shuts down if so there is a genuine component failure inside..however if it stays on then in all likliehood its a bad speaker
Sep 07, 2010 | Optimus STAV-3770 Receiver
I need a new remote to replace the old one for a optimus stav 3770
Buy a universal remote, program it manually and try the Yamaha codes first.
Sep 06, 2010 | Optimus STAV-3770 Receiver
Can I connect a stav 3770 optimus to a directv dvr
sure...red and white out of the dvr into any input on the 3770 and it should work if its setup and working properly. good luck
Feb 10, 2010 | Optimus STAV-3770 Receiver
Reciever connection problem
I am having problems connecting my Advent AW 10 wireless speakers up to my STAV 3770 reciever. What jacks to I connect to with my RCA cable to make a connection?
Dec 22, 2007 | Optimus STAV-3770 Receiver
242 people viewed this question
Top Optimus Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Craig Butler
Craig Butler
Are you an Optimus Audio Player and Recorder Expert? Answer questions, earn points and help others
