If your Samsung tv is struck by lighting is it repairable or does it need to be replaced? Could other things go wrong after that repair is complete?
  • 8,617 Answers
Depending on the model number, most samsungs can get by with just replacing the misc. power deflection board. But need the model number in order to help you further. Please post your model number , respond to this same post when replying.
Posted on Aug 01, 2008
Trying to repair a samsung led tv. It was struck by lightening. There are 4 boards in the tv. Do you think if I replace all 4 boards it would work? Could the lightening have damaged the led screen?
any answer here will be pure guessing. and the cost versus the risk of not working by replacing all four boards may make it worth buying a new tv instead.
if you were to try and fix it i would not do anything more than trying to fix or replace the power supply board. . if the power surge has gone further in the electronics. its rarely worth trying to fix
Nov 14, 2016 | Samsung Televison & Video
Samsung DLP - won't turn on
lightening means ,it seems to be a big problem .I think repairing may not worth,because the repairing will be very high for this problem ,so repairing is not suggested from my point of view
Jul 03, 2008 | Samsung HLN567W 56" Rear Projection HDTV
My TV got struck by lightning what part do I need to get it fixed is a VIZIO E50-C1 LTCWSKBR 2151192
Needs to be diagnosed. Unfortunately this type of damage can range from a few parts to literally the entire TV being toast. I used to be a repair technician and did component level repairs. I have seen lightning fry 1 or 2 diodes all the way up to completely destroying the tv.
Oct 13, 2016 | Televison & Video
TV lamp has been replaced, still won't come on, no picture. When turned on, I can see a blue, kind of sparking light and noise starts and does this about three times. TV powers down and does this again....
Samsung DLP TV Repair - No Picture - Replacing ...
? 2:41
https://www.youtube.com/watch?v=pBTgk_C5FVU
Jun 11, 2012 - Uploaded by ShopJimmy.com
DLP TV Repair No Picture Bad Lamp Bad Bulb TV Won't Turn On DIY Samsung DLP TV Repair How to replace Faulty LampTutorial Click Here to ... Rating is available when the video has been rented. ... is a replacement for the following DLP Rear Projection TV models: ... SAMSUNG HLR6167WX/XAA
Samsung DLP problems - Help! - ecoustics.com
www.ecoustics.com > ... > Home Video Forum > Projection TV Forum
Oct 26, 2009 - I have attached a picture of to show where the "Light Tunnel" is located. Upload ... So now I have a Samsung HLN5065W/XAA that I am willing to part out or sell as is. ... I replaced the ballast but the TV still won't turn on. .... The lamp has been sitting on a shelf until two weeks ago, when the TV went dark. Samsung DLP Light Ballast
Apr 10, 2009
Archive through October 26, 2009 - Samsung DLP problems ...
Apr 8, 2009
Samsung DLP Flashing Standby light
Jul 1, 2006
More results from www.ecoustics.com
Jan 19, 2016 | Samsung SELECT HLR6167WX/XAA Rear...
I am looking for the complete repair kit for a samsung 51 inch plasma tv model number PN51D490A1DXZA.
Samsung LCD / Plasma TV Capacitor Repair Kit ...
www.amazon.com > ... > Capacitors
Amazon.com, Inc.
Rating: 4.4 - ‎86 reviews
Samsung LCD / Plasma TV Capacitor Repair Kit, Replacement Parts: ... 1-220uf 25v; 4-2200uf 10v; 6-1000uf 25v; 6 Inch Solder and Solder Wick; Cleaning Swabs ... pump + Solder wire + Solder wick + CAPACITORS Replacement)-COMPLETE KIT ... In my case, the OEM capacitors did not look bad, but I replaced them all ...
Samsung PN51D530 Plasma TV Repair Kit, Capacitors ...
Amazon.com, Inc.Samsung PN51D530 Plasma TV Repair Kit, Capacitors Only, Not the Entire ... Save on the full line of Powerblanket heating solutions. ... and 8 inches of 0.1 inch (2.5 mm) copper de-solder wick are included in the kit. .... Made Easy · Look.com
EASY MOST COMMON TV REPAIR EVER!!! - YouTube
? 13:13
https://www.youtube.com/watch?v=SXqSg2A5b7I
Jan 6, 2012 - Uploaded by Tampatec
Must See TV FIX EASY COMMON Samsung TV Repair Repairing LNT LCD PLASMA TV FIX SERVICE VIDEO TUTORIAL ... if you go to get tv repair kit- http://tampatec.blogspot.com/ easy ways .... The YSus/Zsus boardlook to be ok but I'm wondering if I need to replace the YSUS board> Any thoughts?
Jan 05, 2016 | Samsung Televison & Video
Tcl tv repair
There could be several things going wrong. You could have damage to the power supply and or main board. I would recommend a professional diagnosis to pinpoint the problem.
May 04, 2013 | TCL L32D20
Lighting struck the apartment about a week ago, tv was plugged in when lighting struck apartment. Tv does not turn on anymore.
Best to take it to a repair centre as lightning damage can cause either minor fault such as an internal fuse blown or major problems that would make it uneconomical to repair. Ask for an estimate for the cost to repair.
Oct 01, 2009 | Broksonic CTGV-5463TCT TV
Samsung tv hln567w
This was a $4000 TV 5 years ago. I own one, and it is still a very good TV. The biggest thing that can go wrong (and is worth repairing) is the light bulb can go out & it costs about $200 to replace. If anything else major goes out, it is probable better replaced than repaired.
Feb 23, 2009 | Samsung HLN567W 56" Rear Projection HDTV
Samsung le40r74bd LCD TV
hi is the power still coming on? if yes no need for power . have u put anntenal & change the chanels b4 then to see if sound will come .if ye s its yuor backlight inverter u can also disconet ur inverter plug & power on  the tv & change channels if works change ur inverter if dead change your ad or mainboard .
for replacement , lcd parts .com. will help
Nov 09, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
