Question about Toshiba Satellite M45-S355 Notebook
My satellite M45 S355 keeps turning off right after it boots. No matter what I do, it immediately turns off. I want to restore it to factory settings, or at least delete all my files so I can get rid of the computer.
    Problem Solver:
  • 8 Answers
If you are not concerned with getting the machine running and just want to get the files removed from the hard drive then I suggest removing the hard drive from the machine and plugging it into a caddy that can be used on another computer to delete the files.
Posted on Mar 13, 2011
Toshiba m45-s355 WinXP sp3, freezes in normal mode after 15 seconds. No error msg. Works fine in safe mode. Steps taken: Deleted partition and reinstalled from mfr disk. Chkd hard drive and memory with...
On the safe mode .
right click on My Computer >>> manage >>> device manager >>>locate processor >>> ( on the second processor >>>right click >>>disable) restart your unit.
Start your unit normally
Aug 16, 2011 | Toshiba Satellite M45-S355 Notebook
My toshiba satellite m45-s355 seems to be coughing up a weird problem.Whenever i press the shift key these characters - "NB~A" props up and the whole system goes awry.I can figure out that it's a...
like other prblem on keyboard it seems your fn key was stuck, it can caused the keyboard was dirty, just open the keyboard then remove all the key on your keyboard then clean it using alcohol wait until dry then set the key again
Jan 14, 2011 | Toshiba Satellite M45-S355 (PSM40U073001)...
Goes to windows screen then restarts over and over
seems like a driver crash,,
restart computer
keep pressing F8
Select safe mode
Click No you want to use system restore
restore your pc to a few days back when it worked good
(follow on screen instructions)
That is you should be fine..
Nov 01, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
Toshiba m45-s355 reformat from usb
Hi
Thak you for yor query
To ensure the CD/DVD is clean please try booting from a known working PC, from what you are describing it may not be your CD drive
If the same thing happnes on another PC then it is the CD/DVD that is faulty, however if it works, then you can try to hook up a external drive, the laptop may defualt to it after trying all the other options i.e. CD rom drive, HDD etc
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If this has been useful please leave positive feedback/vote/Testimonial - it will be highly appreciated
Feb 12, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
What are the steps in updating BIOS on a Toshiba Laptop, Satellite M45-S355 System
Please download the file from the link below then extract it and read the readme.txt file for the step by step instructions carefully and remember this is very risky process so be careful.
http://cdgenp01.csd.toshiba.com/content/support/downloads/sm45v20.exe
Feb 08, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
I want to connect my toshiba satellite m45-s355 to my tv. i cant seem to find out if it is HDMI compatible.
Your Notebook is NOT HDMI. HDMI is a little slot connector, and is clearly marked as such if the PC has it. Close to the Video out port.
Jan 22, 2010 | Toshiba Satellite M45-S355 (PSM40U073001)...
Windows beta 7 drivers for toshiba m45-s355
You have to find all of the drivers off of the Microsoft site, specifically under Windows 7 beta..since it is a beta version there may be no drivers available..
Good Luck
Mar 02, 2009 | Toshiba Satellite M45-S355 Notebook
Pci modem and ethernet controller
hi buddy!
what kind of driver you need?
here is the site where you an find your driver or installer ok thnx
http://www.gzrcw.net/drivers/toshiba/Satellite/drivers_1132.html
just choose ok.
PS:
pls rate me if my solution solve the issue and you need more further information. but if is invaluable solution rate me fixya.
Jun 10, 2008 | Toshiba Satellite M45-S355 (PSM40U073001)...
Boot Up problem on a Toshiba Satellite M45-S355
Well, since the thread was posted, I've had an M55 come in with almost the same symptoms. I believe, in this case anyway, the video module's solder joints have started to break away from the motherboard. Very frustrating diagnostic on this.
Wish I had more help. I'd be happy to keep you posted on how this one comes out.
Thanks
Feb 09, 2008 | Toshiba Satellite M45-S355 (PSM40U073001)...
Boot up and down
I've had a couple of machines with similar symptoms.
The remedy will be one of a few.
Instead of a recovery, you may need to do a full system install.
The most likely problem is the heat sink/fan is getting clogged with debris, thus causing the system to run hot, which includes the video module. Cleaning this out is definitely something that needs to be done regularly in any case.
Also, the lcd cable may be slightly loose where it connects to the lcd.
Finally, it's possible that the video module is going bad... not much you can do about that.
Hope this helps.
Good luck
Oct 18, 2007 | Toshiba Satellite M45-S355 (PSM40U073001)...
Toshiba Satellite M45-S355 Notebook Logo
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
