Question about Pioneer DEH-P2500 CD Player
I have a p2500 and its great. Can I connect my red and white audio cord attached to my ipod to the red/white jacks on back of radio? then listen thru aux?
  • 23 Answers
Those cables are for audio out only you need an IP Bus adapter to connect the AUX input. the CDRB20 or CDRB10 is what you need. the CDRB20 allows for more inputs as well such as CD changers, and XM radio tuners.
Posted on Mar 13, 2011
CAN I USE SA-GX130 RECIEVER WITH IPOD
Yes, you can. Go to a local electronics store or go online and buy a cable (we used to call them patch cords back in the day) with a 1/8" STEREO plug, (also called a mini phone plug) on one end and two phono plugs (also called RCA plugs) on the other end. They're available in various lengths -- 12" is a good choice. We're talking less than $10 here.
Connect the RCA plugs into an appropriate pair of unused INPUT jacks on the back of your receiver -- CD, VCR1, Tape Monitor/VCR2 will do. DO NOT use the phono jacks. The red plug is for the right channel. You can leave the cable plugged in. Then whenever you want to listen to your iPod, insert the mini phone plug into the iPod's earphone jack, switch the receiver to the input for the cable, and start playing. You may have to increase the volume on your iPod to avoid having to turn the receiver all the way up (or down) to listen, but after that you can use the receiver's volume control.
Oct 28, 2014 | Panasonic Technics Sa-gx130 Receiver...
How do I hook up my ipod to my pioneer vsx d409 ?
The best way is to use a 3,5mm stereo jack to 2 RCA cable like this:
You can easily find one like this at your local audio/electronics shop or buy one on line. You have to connect the RCA at any free stereo input at the back of your Pioneer (like aux or cd). Take a look at this picture:
After this you can use the 3.5mm stereo jack for connecting not only your ipod but every mp3 player or other device has an earphone jack. Just plug the 3.5mm jack at the earphone jack and rise the volume at the portable device up to the middle of the volume range and set your Pioneer input selector at the stereo input that you connect the 2 RCA before (aux or cd)
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 13, 2011 | Pioneer VSX-D409
I have hk3385 receiver and Ipod Touch 4G. I have the cable to connect them. Where do I hook the cable on the receiver (or do I?) and which buttons will play the Ipod music. No video, just music
The manual suggests that you use "A / V 3" (audio / video input 3) for your iPad / iPod audio input. These are the RED and WHITE jacks on the front lower right hand side of the receiver. The YELLOW jack is for composite VIDEO, and need not be connected for "audio only" programs.
Turn the volume on the iPod / iPad to MINIMUM (assuming the receiver volume is at a "normal" setting for the radio, CD, etc.). Connect the cable between the iPod / iPad and the A / V 3 RED and WHITE audio jacks. Select A / V Input 3 on the receiver. Find a song you want to listen to and select PLAY in the iPod / iPad. Slowly adjust the volume on the iPod / iPad up to a comfortable level. If there is distorted sound, adjust he receiver and iPod / iPad volumes up and down as needed. Generally, neither should be set very low or very high.
You can download the owners manual here.
I hope this helps & good luck. Please rate my reply - thanks!
Jan 20, 2011 | Harman Multimedia HK 3385 2 Channels...
How to I use the stock radio amp to run an ipod?
You can use any of the following methods
  1. Connecting the iPod via headphone jack
    All you need is a simple Y cable, which is available from any home-electronics store. Connect the small plug to the headphone output of your iPod--or any portable audio player. Then connect the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox.
  2. Connecting the iPod via iPod dock
    To connect using the iPod dock, you first need to purchase an iPod dock accessory. Using the same type of Y cable, connect the small plug to the matching jack on the rear of the iPod dock. Then, plug the red and white RCA-style plugs to the matching inputs on the back of your stereo receiver or boombox. This method provides a line-level connection that maintains a volume level to your stereo system and allows the iPod to recharge.
  3. Connecting the iPod via wireless FM transmitter
    You can also connect your iPod to your stereo wirelessly. You'll need to purchase a compatible wireless FM transmitter--there are several available--and connect it your iPod. Once your transmitter is connected, simply tune any nearby radio to the correct frequency, and you'll be listening to your own iPod-powered mini radio station.
Thanks for using Fixya
Proton
Sep 07, 2010 | Yamaha Royal Star XVZ 1300 A Motorcycles
Auxiliary too quiet when using my iPod!
clean all conects with acohol and cheak for shorts
Jul 08, 2010 | Pioneer DEH-P7700MP CD Player
How can I hook up my ipod without the ipod docking
use your headphone jack, you will need an adapter cable that converts the signal to left / right male RCA jacks. (available at radio shack or on ebay)
these can plug into any red / white inputs EXCEPT phono I use the input labeled CD for my blackberry to listen to MP3's and stream music from Pandora.com
Dec 30, 2009 | Onkyo Tx-sr507 A/V Receiver
I have a audio/video multi-channel receiver VSX-D810S digital processor, probably about 7 years old. How do I hook up my ipod to play music out speakers in my home, same as cd's?
Check Radio Shack, thay make an adaptor with a white and red audio plug that can connect to an input on the receiver (AUX) the other end goes into the headphone jack on the iPOD.
Aug 17, 2009 | Pioneer Audio Players & Recorders
Question about a Shelf Stereo System
You can use any analog Audio input out of 3 at rear of this system to listen laptop sound. Audio Cord is required to hook up and its look like red-white RCA pins at one end and other end is like headphone stereo jack for laptop. Audio Cord is available at Sony Part Center.
Hope above info will help you.
Sep 06, 2008 | Audio Players & Recorders
Aux location
There is a RCA cable that comes off the back of the radio and also another cable for 3.5mm (mini-stereo jack) that also comes off the back of the radio. The RCA jacks can be used for "AUX" or "Sub-woofer" and the 3.5mm jack is just for "AUX". Your ipod can use the audio output jack or the headphone jack and plug that into the 3.5 mm jack on the back of the radio. You will need a "3.5mm male" to "3.5mm male" stereo cord that can be purchased at Radio Shack or Best Buy. Then you select "AUX" on the display with the source button to listen to it. You may need to go into the menu and activate the "AUX" input. Check your owners manual for details.
Aug 13, 2008 | Kenwood KDC-MP435U CD Player
Connecting ipod
Yes you can connect your i-pod to your sa-ht 930. You can buy a connection at Walmart for $5 bucks or you can go to Tareget and buy a monster connection for about $25 bucks. I bought the monster connection and works great. All you have to do is connect it to the AUX in the back to the white and red jack in put. Once you connect it change the input selector to AUX and you're ready to go.
Dec 08, 2007 | Panasonic sa-ht930 Home Theater Audio...
Pioneer DEH-P2500 CD Player Logo
171 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
