Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Ice maker kitchenaid
Ice maker stopped working.
removed ice maker and ice tray thawed and cleaned. reinstalled ensuring correct installation
new water filter with 8 litres flushed through for air bleeding.
model KSRA25CNSS00
what now?
  • 11 more comments
  • dougww Aug 01, 2008
    it is turned on...a switch...the ice tray has an infrared or led that sencses a high ice level. the light for power flashes on and off red.
  • RBHC Aug 03, 2008
    just had the exact same thing happen to me. The light is flashing red.
  • Paul Purdef Aug 05, 2008
    Red LED light is on. Looks like water not going into Ice maker.
  • webheads7 Aug 06, 2008
    The same thing happened to our fridge(installed in 2003), coincidentally at the time I replaced the water filter. After reading the owners manual I checked for any ice blockage- none. I removed the filter for 24 hours, and the water dispenser continued to work but no ice. So I reinstalled the filter(properly each time!). Since it appears the same water line runs into the unit for both ice and water, the fact that the dispenser works indicates to me that the water line is not the problem. However, there is no water filling the ice maker trays. I am temporarily using ice cube trays manually. The red light in the freezer, above the ice maker on/off switch, is flashing constantly. I could find no reference to that indicator light in the manual. Does anyone know what that light means? Any other leads?
  • bongo herber Aug 11, 2008
    Having similar problem- this is after other weirdness where the coil-defroster seems to have gotten stuck 'on', making the freezer side melt down. Turned the whole fridge on/off (unplug) seems to have reset that, but now the ice maker doesn't fill/run. The LED on the ON/OFF switch is 'on' sometimes, like right after I plug it back in, but is mostly 'off'.
    Wonder if a lightning strike got to something in there.
  • normanday Aug 14, 2008
    after water company turned water main off to do work, ice maker did not work. Water dispenser is working. We turned off refridgerator and thawed and restarted still no water... HELP
  • Dave Murphy Aug 16, 2008
    I pulled the hopper and filled a cooler. Then nothing! I can't figure how it could be. Then I tried resetting the filter counter. Somewhere along the way I got one dump. Doesn't Kitchenaid look at this??
  • gonjohar Aug 17, 2008
    ice maker don't get water
  • Anonymous Aug 20, 2008
    ice maker will not fill, have cleaned all parts, led light flashs on and off. what can I do?
  • shray Aug 21, 2008
    Kitchenaid Superba Architect KSCS23INSS side by side refrigerator. We have replaced the water filter. cleaned the hopper . the red light flashes.will not fill the ice tray, water in door is working. It is 2 1/2 yrs. old. What can we do to fix this problem.
  • Anonymous Sep 06, 2008
    Refrigerator ice maker was overflowing, spilling water/over flowing into the freezer box. Continued to make ice, but created a ice build-up in the ice tray. Removed ice maker and cleaned out; and put back and know it will not fill ice maker with water. Checked electrical connections and insured water was on and still not working. (filling ice tray)
  • Anonymous Mar 16, 2014
    Ice maker
  • Anonymous Mar 21, 2014
    new installed water not going to ice tray
  • 876 Answers
You did remember to turn it back on? Mine has a handle that detects when the tray is full and you flip it up to turn it off and down to turn it on. Good Luck
Posted on Aug 01, 2008
I have a kitchenaid french door KFIS25XVMS9. The ice maker has stopped working.
If ice build up in the supply pipe sounds as water fill valve is dripping
May 22, 2014 | Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker quit
if ice maker is cycleing then it is either water frozen at the tube where water comes in. if it is then shut off refrig. remove icemaker and thaw tube out with a hair dryer. makeing sure not to melt plastic in the back panel of freezer. if it is plastic. if it is not plugged then it is either a bad water valve or the watervalve switch in the icemaker.
May 26, 2012 | KitchenAid Refrigerators
Ice maker not filling...already turned off ref let set for 3 hours to thaw still not working
Noticed you did not list your model number of
your Kitchenaid Refrigerator. I see a model number KSRD22FKST above your post
is that correct? If yes there are a couple things that may be causing this. If
the ice maker mold/tray is
full of ice and will not
cycle most times the ice maker thermostat Click Here=> KSRD22FKST while there look at item number
27 in photo. That is your ice maker's thermostat that tells the ice maker when
ready to cycle and fill with water again. The part Number is=> 627985
they also request that you order the sealant for ice maker thermostat=
Jan 09, 2011 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker stopped working. removed ice maker and ice tray thawed and cleaned. reinstalled ensuring correct installation model KSRA25CNSS00 what now?
take off the cover to your icemaker and make sure the 2 tabs in the center of the main gear are in tack and not broken or bent. if they are, the ice maker module will need to be replaced. if that is okay, check the fill tube in the back of the freezer that goes to the icemaker and make sure it is not frozen. if it is, it will need to be thawed. your water filter may be plugged and need replaced. if all those are ok, then there may be an issue with the water valve itself. Joe
Nov 18, 2008 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker Infrared light doesn't light
Each mold tray has a heating element that is turned on to free the ice cubes from the mold tray and allow them to fall into the ice bucket when the tray is rotated into harvest position. Sounds like that is not being turned on... or is defective..
Sep 18, 2008 | KitchenAid KSRG25FK Side by Side...
Ice maker quit - LG refrigerator model LFX25960ST, ice maker PN 5989JB0001A
I have the same problem.
Ice in the gears.
Splash from opening and closing the door when liquid water is present seems to be the logical problem.
I had cleared the ice before, thoroughly dried the icemaker and reinstalled it. It worked until I adjusted the icemaker to make large cubes.
I will reinstall it and see how long it last. I will also complain to Sear about the short life of this device.
Dec 27, 2007 | LG LFX25960ST Stainless Steel French Door...
Ice maker won't fill
leaky solenoid? could cause ice build up
Jul 08, 2007 | KitchenAid Superba Architect KSCS25INSS...
Ice Maker troubles
THERE IS A HARVEST CONTROL (SENSES THAT THE ICE IS PRESENT AND SWITCHES MODE TO HARVEST)... THAT MAYBE THE PROBLEM BEFORE YOU CAN SAY ITS THE MOTOR MODULE. IF YOU HAVE A BAR THAT IS VISIBLE OVER THE BIN ... TRY LIFTING IT ALL THE WAY UP WHEN YOU HAVE ICE IN THE TRAY... IT SHOULD SWITCH THE MODE TO DUMP THE ICE. I NEED TO KNOW IF ANY OF THIS WORKS OR NOT BEFORE I CAN GO FURTHER. GOOD LUCK .... YOU CAN WRITE ReckingerJ@aol.com make sure to type (Fix-Ya) in the subject bar.
May 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
924 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
rugby prop
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
